Question about GE SpaceMaker Microwave Ovens
Need to replace Model JVM16308K 01
Just want to find one the same with new number
I need to replace the waveguide in my Thermador MBBS / 01 microwave.
Waveguide "cover"I presume? The waveguide is part of the chassis and cannot be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 26, 2011 | Thermador MBBS Microwave Oven
Kenmore oven-microwave 911 41479791 I get E 01 error.
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2010 | Kenmore 63662 / 63664 / 63669 Microwave...
I have a 1993 1000 wt microwave the turntable was not work are there still parts these are the numbers I can find on the door 565383 10/01 ( model) HG34314163 ( serial)
You can find helpful exploded view diagrams and order parts by entering your full model number here.
NOTE: Enter your model number like this: 56-5383-10-01
The typical turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
Sep 26, 2009 | Tappan TMS062E1 Microwave Oven
My microwave is dead following a lightning storm M406 01 Can this be fixed
If it just blew the inside fuses yes if your power line was hit by lightning it may be toast but need the model number to tell you where the fuses are.
Aug 26, 2009 | Jenn-Air Microwave Ovens
Glass Tray replacement needed
Those model numbers are not correct. That's likely why you're having trouble.
For model number JVM1790SK01, the part number is WB49X10114.
That's available here.
Mar 04, 2009 | GE JVM1790 1000 Watts Convection /...
Button names wearing off
No, sorry. You'd have to order a new control panel assembly.
For model number SCA1001FSS001 it's part # WB07X10439 for $66.15.
You can find helpful exploded view diagrams and order it by entering your full model number here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Jan 28, 2009 | GE Advantium 120 Convection/Microwave Oven
How to replace both door hooks on BOSCH MICROWAVE/GRILL
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 23, 2008 | Bosch HMT9626GB Microwave Oven
I can't get my clock set. I push options, 3 and 1, then when I put in the time, nothing happens. I need to know if I can use a ceramic turntable out of my old Microwave Convection oven. My oven...
In case your owner's manual is missing, you can download it here.
If you're still having trouble after consulting the manual, please reply back.
The ceramic turntable (actually ceramic coated metal) will be fine as long as it doesn't have chips or cracks where arcs can occur.
Also, for even heating and longer turntable life, don't place your food in the center, but slightly off-center instead.
If you need to order a new turntable, enter your full model number JES1290SK here http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
May 08, 2008 | Microwave Ovens
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
22 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
