Question about HEWLETT-PACKARD ProBook 4520s Notebook
Green screen laptop
Screen green problem
I have a green screen on my acer aspire 5315 laptop
hi, last time i had a green screen on a laptop, it was a bad connection due to wires that get damaged inside the swivel hinges, try pressing around the area of the screen and around the hinges. if the screen becomes ok then that is the fault.
jim
Feb 21, 2015 | Acer Aspire Computers & Internet
Why is my screen green? i have a new laptop hp. i must have done something to it but i don't know what.......
It is likely some connector inside the laptop is partly dislodged.
Either bring it in for servicing or try finding a skilled friend to do this, but since you describe the laptop as new...
May 07, 2014 | Televison & Video
Green screen laptop
Press the "Function" key along the top row of your keyboard to toggle an external display; this key is different on each manufacture's laptop. If the external display has the same problems, your computer's video card or software is the problem.
Laptop Screen Is Distorted & Green ' Chron.com
smallbusiness.chron.com/laptop-screen-distorted-green-71653.html
Sep 03, 2013 | Aspire Computers & Internet
Getting a vertical green line across my laptop screen
SOUNDS LIKE YOUR SCREEN IS CRACKED OR THE LED INSIDE THE SCREEN
Jul 14, 2012 | Computers & Internet
My laptop has a green screen on start up
Green Screen? Never heard of that, normally its a Blue Screen if there is a problem.
Give us more details on what happens when you hit the power button. Does anything appear on the screen? Do the laptop try to boot? Any lights, beeps, fans running, hard drive spinning?
Apr 07, 2012 | Computers & Internet
I have a laptop toshiba l500d series. My question is the screen turns green only the black parts all the time. What would be causing this problem. Thanks
Hi, the screen may turn green when the Graphic Driver is corrupted. Please re-install the Graphic Driver in the Computer. The Graphic Driver can be downloaded from the Laptop Manufacturer website. Restart the computer after installing the Graphic Driver. If the issue persists, restart the computer and try pressing F2 Key to enter BIOS (Basic Input Output System) setup, then check if the screen displays green color. If the screen displays green color in BIOS setup then the issue is related to Hardware of either display or graphic card of the Laptop. In this case, please contact the manufacturer of the Laptop to initiate the service under Warranty. If the laptop is not under Warranty then service charges may apply.
Apr 17, 2011 | Computers & Internet
HI, shows blinking green line of about 2mm at the bottom of the screen of my VAIO. Could you advise to resolve the issue
Most of the times this is a screen issue. Meaning that you will have to change your screen eventually.
To be sure, connect the laptop to an external monitor and look at the display of that screen.
If you see the same green line, then the motherboard could be defect.
If you do not see the green line, then there is something wrong with your laptop screen.
If the screen is malfunctioning, the first thing you should do, is open the laptop, and check the wiring of the screen. If this does not solve the error, you should replace the screen.
Mar 07, 2011 | Sony Computers & Internet
When I move the The laptop screen turns green and fuzzy
Restart the notebook and press F10 to enter into BIOS which should be blue in colour. The move the laptop and check if the screen turns green and fuzzy.
If the screen turns green and fuzzy in the BIOS, then the isuse might be hardware malfunctioning of the screen and your notebook needs to be repaired.
Jun 08, 2010 | HP Compaq Presario CQ50-110US Laptop
Screen goes green jiggle the screen and it clears up
tienes un problema en el la cinta flex de tu lapto tambin puedes tener soldadura fria
Aug 24, 2009 | Compaq Presario M2000 Notebook
HEWLETT-PACKARD ProBook 4520s Notebook Logo
12 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
