Question about Actiontec HPE200AV (HLE200AV0-01K) Network Adapter
Actiontec hpe210avp connection problems
Connection problems won't sync
Axim x51v won't sync
Guys it's probably down other sync software on your system like phone sync, I had the same problem yesterday, sometime ago I had installed software for my HTC phone, check in add/remove programs & uninstall anything that sync with your computer, then reinstall activesync.
welshcob
Jan 03, 2013 | Dell Axim X51 Pocket PC
Have a GT704WG Actintec router and am having a
check channel must be on 11 for windows computers
Feb 12, 2010 | Actiontec GT704WG Wireless Router...
When power switch is turned on the Power light is rapidly flashing & the 4 Ethernet lights are flashing. The box is Actiontec GT704wg
I do not have a solution to the problem. However, I am having the same problem. This morning the Actiontec GT704WG power and ethernet lights were rapidly flashing. The modem was non-functional. I could not even connect to the modem through the browser to see if I could find a problem.
The problem lasted a couple of hours. Then all of a sudden the modem started working again. I won't be able to tell if the problem recurs until I restart the modem. And if the problem does occur again, I won't be able to connect to the internet.
Oct 08, 2009 | Actiontec GT704WG Wireless Router...
Actiontec GT704WG doesnt connect to internet
HI! all your computer is connected except for one, you are connected to to the local network but cant get an internet connection, I dont see any problem with your wireless connection bcoz you are connected to the lan, check the security settings of your browser on your windows vista, go to internet option and security, lower it down to medium security, so that you can access the internet or try using other browser like firefox or google chrome.. check your firewall settings as well on your windows vista..
Aug 08, 2009 | Actiontec GT704WG Wireless Router...
Desktop wont connect to internet but laptop will!
repair the conection and also try a diffrent ethernet wire sometimes it could be bad
Jun 05, 2009 | Actiontec GT701C DSL Modem
Nonexistant customer service by Actiontec
After my second call to Actiontec ended with the help desh hanging up on me, Actiontec did respond to an emailed plea for help and prompty provided a complex script which they labeled confidential to address this problem. The bottom line seems to be Verizon either installed hardware that is incompatable with an Exchange server or they did not configure the insallation correctly. In so many words, Actiontec feels it is a Verizon problem. I wish me luck in getting to the right place to deal with that, even though I am a Verizon stockholder.
Mar 27, 2009 | Actiontec GT704WG Wireless Router...
CAN I USE AN ACTIONTEC G704WG IN THE FOLLOWING CONFIGURATION: 1. CONNECT THE G704WG TO MY PC, ETHERNET TO ETHERNET 2. COMMUNICATE WITH MY NEARBY HP LAPTOP WIERELESSLY, BACK AND FORTH. THANKS, WAYNE...
yes that is possible connect your PC to the actiontec using the lan cable. set your wireless network, then have you other hp join the network.
you can share folders, and printers, and also have your HP connect to the internet through that actiontec.
Jan 06, 2009 | Actiontec GT704WG Wireless Router...
Actiontec GT701-WG won't operate wirelessly
In looking on the internet the unit is a DSL gateway. Trying to use it on cable internet is not a real good way to set up your network because I believe the router is waiting for a DSL sync before the services turn on. I would spend the money and pick up a Linksys or Netgear G router, there around $50.
Jun 01, 2008 | Actiontec (GT704WG) Router
Wireless light is green but i don't receive any signal on my laptop?
Check to see if the SSID is being broadcast. That could probably you be your problem.
Thanks,
Jan 02, 2008 | Actiontec GT701WG Router (actiongt701wg)
Actiontec HPE200AV (HLE200AV0-01K) Network Adapter Logo
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
