Question about Titan TI-7700 Massage Chair
Weight limit of adult for ti7700
What is the maximum weight of an adult for this chair
How much weight support according to specifications
(You didn't say which chair.) From a warranty sheet that came with a chair: "Warranty is limited to normal usage, not exceeding 40 hours per week and 250 lb. weight."
Tempur-Pedic seating (Raynor Group), model TP4100 chair. $300 (December 2015).
Cheaper chairs can have lower ratings.
Nov 18, 2015 | Furniture
Owners manual what is the weight limit
There is no maximum passenger weight capacity listed in the owners manual for my Boulevard S-50, and no maximum passenger weight capacity for the Marauder 800 (which is almost exactly the same bike) listed anywhere that I can find on the internet. The front and rear springs are adjustable for passenger weight, but I would suggest the maximum weight is limited by the rear tire capacity stamped on the sidewall and what weight you feel comfortable handling. Don't forget to include the weight of the motorcycle (about 456 pounds) and the weight of the gasoline (about 6.0 pounds per gallon).
Sep 08, 2014 | 2004 Suzuki Marauder 800
How much combined weight is allowed on the 1999 800 suzuki maurder
As I answered to the same question posted by G. Moore:
"There is no maximum passenger weight capacity listed in the owners manual for my Boulevard S-50, and no maximum passenger weight capacity for the Marauder 800 (which is almost exactly the same bike) listed anywhere that I can find on the internet. The front and rear springs are adjustable for passenger weight, but I would suggest the maximum weight is limited by the rear tire capacity stamped on the sidewall and what weight you feel comfortable handling. Don't forget to include the weight of the motorcycle (about 456 pounds) and the weight of the gasoline (about 6.0 pounds per gallon)."
What is the weight limit for hauck infinity
Hi
We would recommend you contact Hauck directly for assistance -
Home
Sep 02, 2014 | Hauck Infinity Stroller
What is the maximum weight that the Alps Mounaineering dual action chair can hold?
This chair is awesome due to its size and how sturdy it is. This chair was designed to carry up to 275 lbs and built so you can sit on it for hours on end.
Feb 16, 2014 | ALPS MOUNTAINEERING Dual Action Chair
What is a folding beach chair?
A folding beach chair is a type of chair that's made of lightweight materials and can be folded. These chairs are also very easy to move around because they're so light.
Aug 19, 2012 | Garden
How much weight can an electric massage chair handle? I am overweight and want to buy a massage chair; however I would hate to spend the money and in the end damage the chair or void the warranty.
Each manufacturer has their own weight limit published, so I advise asking in advance. From my research, it seems that most chairs can hold up to 270lbs; although there are some models that have a higher capacity.
Aug 06, 2012 | Furniture
What is the gross weight limit that a 2002 Pt can carry ?
The maximum gross vehicle weight is 3973 pounds. The 2002 PT Cruiser's curb weight (AT) is 3190 pounds; the curb weight (MT) is 3108 pounds. Thus you can't have more than about 800 pounds of cargo/passengers. The max trailer load is 1000 pounds (for the 2010 and probably for the 2002).
I hope this helps.
Jul 13, 2012 | 2002 Chrysler PT Cruiser
The VA is buying me a new power wheelchair. The chair alone is about 375 pounds. They are going to install a Reese hitch and a carrier. I purchaced a Rear Power Chair Load Leveling & Air Suspension...
the system your describing is fine for your vehicle, just remember that the car will turn and drive a little different from the standard weight schedule and factory specs,, however , it will be just like having 2 Big adults in the vehicle all the time, so you should have no worries, the ****** weight your seeming to be worried about is within the limits, here is that described
If the ****** of the trailer does not exert enough downward force on the tow vehicle's hitch ball -- meaning that the trailer's ****** weight is too light -- a dangerous condition called trailer sway could result. If the ****** weight is too heavy, the steering of the tow vehicle will be affected.
Sep 07, 2011 | Mercury Marquis Cars & Trucks
What is the maximum weight load?
There is no real correct "max" weight. The bikes suspension travel will produce limits in handling and top speed as the weight increases, It should be able to carry to 2 adults with ease, say 180kg, If you are carrying big loads, then additional tyre pressure would be advisable. Upgrades in rear spring rates would be advisable also if you intend to do touring with heavy loads. You can get a full service manual here for the correct pressures to run and suspension adjustments you can make for high loads. Cheers
regards robotek
Jan 17, 2010 | 1994 Honda VT 600 C Shadow
Titan TI-7700 Massage Chair Logo
56 people viewed this question
Top Titan Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Titan Furniture Expert? Answer questions, earn points and help others
