Where is the bridge rectifier on an Insignia tv
Insignia white noise coming out of speakers not when muted
try adding .01mfd disc capacitors across bridge rectifiers diodes(all the 4 diodes),If the devise is old try replacing filter capacitors.and isolate transformer secondary leads if they are very near recifier board.
Jun 30, 2014 | Insignia 2.0 Speaker System (2-Piece)
No red light or power
I've had about 3 or 4 similar sets like this....all have had a flash-over around the bridge rectifier to metal chassis. (you will clearly see the flash-over on the metal chassis). Clean back the print re-solder bridge rectifier,fit a new fuse (usually around 4 to 6.3 Amp)
Feb 15, 2014 | Samsung LN32A330 32 in. LCD TV
Hdmi port not working on plasma tv
Contact the authorized service center to rectify this fault. In most cases, the main board might need replacement.
Jul 23, 2013 | Insignia 42" LCD Flat-Panel HDTV
Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
I have waveing in my tv
Hello
Picture waving can be due to many reasons. The first reason is ariel connection. Check it first for tight and not loose contacted. Second one is due to the main filter capacitor connected across the main rectified power supply DC. If the capacitor goes value reduced or opened, waves may occur. If this is the reason, picture will show blooming effect also. Check the mair rectifier bridge also. gopakumar1@hotmail.com
Oct 18, 2010 | Orion STV2763 27" TV
WHEN PUT ON THE TV,THE INTERNAL FUSE BURNED
check input circuit. trace bridge rectifier circuit.. make sure its good.. check tranformer or line filter.
Fuse is probably burning as a precaution because there is a problem in the input section.. either ac side or after bridge
Dec 16, 2009 | Daewoo DTQ-20V1FS 20" TV
Converting ac to dc voltage
You need to transform the voltage to a level that you require, then 'rectify' your voltage to DC, with a bridge rectifier. There are many different types of rectifiers for different uses. Look on the web for electronics, bridge rectifiers.
Jul 10, 2009 | Dryers
Power will not come on
EEEEEEEEh check the power supply, from your power cord , fuse, rectifier bridge diode, whith out forget that the old TV got the bad connection in old solder!!!!
Dec 26, 2007 | Polaroid TTM-2401 TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
