Question about Kenwood VR-405 Receiver
Different Audio options from an older receiver
I have an older Kenwood Receiver (VR-405), that processes dolby digital 5.1...it has no HDMI output. The HDMI plug only goes from the TV to the bly ray disc player
I just got a Blu-ray disc player...Am I able to get sound from a blu-ray disc when it only has PCM 5.1?
The receiver has no DTS...can I not play any blu-ray disc that has only DTS-HD MA 5.1, or is there a way to bypass that?
  • 757 Answers
If your receiver has a multichannel input and the player has the multchannel output then that is the only way you can get surround sound from it with source inputs that it cannot decode, such as DTS. The player will then do it alone.
However, in the setup menu of the blu ray player you should be able to change the audio output to downmix to 2ch audio...at least you'll get to watch the movie.
Posted on Jun 18, 2009
2 Suggested Answers
  • 6 Answers
SOURCE: Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Posted on Jan 10, 2010
I need to hook up my Kenwood vr-207 to a satellite HD receiver and blue ray player. How do I hook up the component cables. I am not sure where to plug in the "in's" and "outs".
In's always go to Out's.
The VR207 has no component video inputs, just a composite video output so you can use your TV for the receiver's On Screen Display.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/vr207.pdf
Just run your BluRay and Cable box HiDef HDMI, component, s-video, composite video, whatever (in that order of preference) to a matching input on your TV or monitor.
As a rule you should run the best audio from each of your video sources to the VR. There is no compelling reason to ever send good audio or video to a device that has little (or no) use for it.
Unfortunately, the VR207 has no digital audio inputs, so the best it can muster regarding surround is Dolby Pro Logic derived from 2-channel inputs.
BUT, if you have a DVD, BLURAY player or cable Box with 5.1 analog outputs you can let their internal circuitry decode Dolby Digital programming to true 5.1 for input ("DVD/6CH") to the VR207.
Feb 05, 2011 | Kenwood VR-207 Receiver
Kenwood vr-405 turns on only momentarily and then shuts off
your receiver has a bad audio output ic.replacing ic will take care of the problem
Apr 10, 2010 | Kenwood VR-405 Receiver
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
How to hook up a kenwood audio-video surround receiver vr-405 to a 46" Bravia tv?
hello all you need is a good pair of RCA cables.
Use the audio output on the TV
run it to the VIDEO 1 input on the receiver
as for your DVD player vcr etc you can either run them directly to the tv as it will output whatever sound is playing to the receiver.
or
use the receiver as a video switcher and connect your components directly to it.
remember your receiver will need to be set to the input you use. ie: video 1 / dvd etc..
Hope that helps
Jan 10, 2010 | Kenwood VR-405 Receiver
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Dec 27, 2009 | Kenwood VR-405 Receiver
Oct 24, 2009 | Kenwood VR-405 Receiver
How do i use the dolby digital
You have to connect your dvd player to your kenwood receiver by using the digital port.
DVD ------------ Digital out
Receiver ------------- Digital input
Apr 09, 2008 | Kenwood VR-405 Receiver
Kenwood VR-405
more info would be nice. If you're using optical, make sure its securely in both the tv and your vr-405 receiver. I have owned the vr-405 since 2000 and i just purchased a sony 32xbr6. HDMI into the TV, optical out to the receiver, it sounds amazing!
Dec 01, 2007 | Kenwood VR-405 Receiver
Kenwood VR-405 Receiver Logo
283 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
