Question about Dyson Dc 41 Ball
The brushes are not turning
Only a month old
    Master:
  • Dyson Master
  • 815 Answers
Hey, this is Jeremy with Crucial Vacuum,
There are 3 potential reasons as to why your Dyson DC41 roller brush is not working:
1) The brush bar may be blocked by debris that was picked up by the vacuum. To remove the blockage, switch your vacuum 'OFF' and unplug before proceeding. Then, lay the vacuum down and try to remove anything that is lodged in the roller brush. If you still cannot clear the obstruction, you may need to remove the base plate to gain better access to the bar.
2) The roller brush may be set in a position that is too low for the type of surface that you are working on. Vacuums have different recommended heights when working on carpets and hardwoods. Try switching the brush "on" or "off" based on what type of surface you are working on.
3) If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace if needed.
You can purchase replacement parts for Dyson direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dyson.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Posted on Jun 08, 2015
Why does the power brush turn on even when turned off?
If it is 6 months old, it should be under warranty. Call wherever you purchased the vacuum and ask how they handle warranty claims.
May 15, 2015 | Vacuums
Brushes jammed. not turning round
Start by replacing the belt if it is over 6 months old. Stretch belts lose elasticity.
Feb 27, 2015 | Vacuums
Brush not turning and there is a smell
Your belt has most likely burned in half, this happens from an object getting caught in the brush roll, a brush roll that does not shin freely i.e. debris under the end caps or usually and old stretched out belt that has been slipping; belts can stretch out in 6 months whether you use the vacuum or not.
Remove the brush roll and old belt, inspect for damage, clean out the area and instal an new belt or the same brand and type. It should be good as new.
Oct 30, 2013 | Vacuums
Vax 2300
If the roller brush cannot be rotated easily by hand, it is likely that debris is jammed inside the end caps.Make note of the direction arrows on the end caps as you remove the roller brush. You will need to know this for reinstallation. The end caps are fastened with stop nuts. Removal of one will allow the inner shaft to be extracted for examination and cleaning. An old toothbrush is a good cleaning tool. Reinstall the inner shaft and stop nut. Check for free rotation of the brush roller. Place a new belt over the brush roller and reinstall the brush roller, being careful to observe the position of the arrows on the end caps. Inspect the motor shaft and remove any old belt residue before installing the new belt on the shaft.
Jun 30, 2013 | Vacuums
The vacuum is not suctioning. Fuller FB 90T
First replace the belt if it's over 6 months old. Stretch belts lose elasticity. It may still turn the brush roll but when vacuuming the carpet it may be slipping and not turning fast enough. Make sure bags and filters are good.
Sep 07, 2011 | Fuller Brush FB90T Bagged Upright Vacuum
Hose attachment doesn't work
If there is sufficient suction at the end of the hose, the brushes should turn. Temporarily cover the rectangular opening that contacts the carpet/upholstery. This increases the suction to the air turbine, and may start it. The only other thing the user can do is to try to turn one of the brushes to assure the components rotate internally. It will not rotate easily.
Sep 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a velocity pet lover 1900 only 2 months old
You have broken the rubber belt that drives the brush. Flip over and remove the old belt and replace it with a new one.
Jim
Jun 10, 2009 | Electrolux EL1000A2 Pronto Bagless Stick...
Brush will not spin any longer
If the brush won't spin at all, it's either the drive belt or the roller beater brush is clogged. Pet hair can quickly clog a vacuum. Turn the unit over and see if the brush will rotate by hand. If yes, it's probably the belt. Also look for debris and clear as much out as possible. You may have to remove the bottom plate and clean the bottom of the unit out. If you do have to go that far, it would be best to replace the drive belt and thoroughly clean the vacuum.
Apr 19, 2009 | Bissell 3920 Bagless Upright Vacuum
I cant get the power brush to work is there a reset button? the vacuum is only 2 months old dirt devil 12amp bagless featherlite
can you turn the brush by hand? if it turns real freely the belt is broke or the brush siezed up make sure there isn't any carpet strans wrapped around the ends of the brush otherwise the brush won't turn.if its the belt make sure you clean the motor shaft before you put on the new belt,the old rubber from the old belt will make the new belt run unevevly and break again..good luck
Apr 06, 2009 | Dirt Devil M085850 Featherlite Bagless...
Hoover WindTunnel, month-old belt, now too large to turn brush
I suspect you have been bitten by the Chinese bug.
A very large percentage of replacement parts for all manner of appliances and vehicles are now being conterfeited in China who we should know by now has no respect for the intellectual property of others and a flood of low-quality stuff is being made as 'knock-offs' since they are generally easy to fabricate with fairly primitive means. Our eldest son just returned a supposedly 'new' steering pump for his (US) car but this one at least had China as the origin shown on the package.
Make sure though that the brush roller turns freely and isn't being impeded by trapped thread in the bearings.
Mar 21, 2009 | Hoover U6630-900 WindTunnel Bagless...
Dyson Dc 41 Ball Logo
94 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
