Question about Sony CDX-GT630UI Car CD/ MP3 Player
NEED THE BACK PICE FOR THE STERO
JUST NEED THE BACK WIRES FOR THE STERO
Dash lights gone after installing stero fuses ok but i did have 4 wires left over after stero in stall are the dash lights fed from the stero
the dash lights dont get fed from the stereo , you may have dislodged the wiring connector from the rear of the dash , give them all a push back on , don't worry about the spare wires , they will be for an electric aerial etc
Jun 30, 2014 | 2005 Kia Sorento
I need to know which wire is the hot wire, going from the car to the car stero
red wires in auto electrics is the nominal power wire. Use a circuit light tester and if it comes on when the ignition switch is on, or in the accessories position then that is the hot (power )wire.
Dec 23, 2013 | 2001 Buick Regal
I'm trying to wire in a newer factory ford am/fm cassette player/cd changer in my 95 ford explorer but the plugs are slightly different and contain more wires, just need some schematics . The 95 came with...
go to a store were they sell car stero an take your radio an tell them u need a wiring harsent to plug in the radio an plug into the plugs on the car you have dont go to walmart the dont sell them its going to be from car stero store.
Jul 30, 2010 | 1993 Lincoln Mark VIII
I am doing a stero in a 2001 silverado with a 6.6l disel and there are 3 wires on the back of the factory stero the after market stero only have one will i need to wire the other 2 in
The best thing to do is use a factory wire adapter. The main wires you need to worry about are power, battery memory, ground and speaker wires. If you have a power antenna you will need to wire in the remote (normally blue or light blue). The only other wire should be an orange wire for the dimmer on the radio face. This one is not necessary for normal operation. Make sure you have the main 11 wires wired in. Ignition, battery, ground and the 8 speaker wires.
Apr 27, 2010 | 2001 Chevrolet Silverado
I put the headdeck back in and pinched a wire have i blown the fuse in the stero or car fusebox? there no power in it atm the stero i mean
take it back out check for naked wires and if insulated good ,then look on back of the deck there should be a fuse if its bad replace it ,and check the fuse box under the hood and on drivers side under the steering wheels left side fuse box,theres 3 fuses usally to the stereo check them all.if my info was of any help to you please leave a comment thankyou.
Sep 02, 2009 | Kenwood KDC-MP228 CD Player
How do you check the fuse on my dual car stero
it shud be in the back of ur unit rite where the wires are ,plug th wires off & ur fuse shud be rite there.
Jul 12, 2009 | Dual XDMR-7700 CD Player
TAKE OUT STERO
First you need to go to Schoche.com and Purchase a Small Blue Box that will let you convert the Audio wires into RCA Jacks. Got one for my 2007 Scion Xa Worked Great! You will still need to run your wires for the amp and Run RCA Cables to the Stereo. This box will cut into the Rear Speaker wires and still allow the Speakers to work while allowing you to Connect the RCA Cables for the Amp to the Box.
Jan 18, 2009 | 2005 Scion xB
Stero wiring
Most likely the cable you are referring to is the lead in cable wire for the antenna. Below is the standard color of wires and where they are connected.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | 1994 Ford Explorer Limited
Stero wire diagram/ 1995 dodge Intepid
use a test light with ignition off when u find power connect it to yellow(memory) then on acc when u find power conect red connect black to earth blue is optional (power antenna) find the speaker wires colors at the back of each speaker and connect the two of the same color to each speaker striped wire + no stripe - hope this helps
May 22, 2008 | Car Audio & Video
Sony CDX-GT630UI Car CD/ MP3 Player Logo
14 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
