Question about Scotsman Kitchen Appliances - Others
Need to ajust water flow on a cme256wc
What should the heard ps be
  • 100 Answers
Being that this is a water cooled ice mach...are you referring to adjusting the water to bring the head pressure down or up...need more info...
Posted on Jan 14, 2015
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Water pressure from city side should be. (Minimum 20 psi ) Maximum (80 psi ) If sump tray is filling up and water valve is cutting off then water supply is ok. If you are not getting enough water over the evaporator plate then you need to make sure the distribution tube is not stopped up with. if it is clear then replace the water pump.
Posted on Nov 19, 2014
No hot air comeing out of heater on my 1992 lincoln town car.blower and water or ok lust no hot air cimeing out of ducks?
Hi,if you are not loseing water the best thing to start with is a simple kit that will flush out the rubbish that bilds up in the water channels,all you do is put the aditive in to the system by way of exspansion tank or radiater cap then let the car idle untill recermended time is up,then flush system and refill with the the recormended amont of anti-freeze.
you should be able to buy the item at eney good car spares shop.
Hope this was some help.
ps sometimes things just need cleening or ajusting rather than renewing.
Dec 23, 2013 | 2006 Pontiac Grand Prix
Same problem with rinnai V1200.starts ok and as soon as you want to ajust cold water,the hot water line gets cold.**** all design
These units need water flow/pressure to work. If you use a mixer to get the right temperature as soon as you try to increase cold to make the water colder you unfortunately reduce the hot flow. Fairly complicated fault to explain, all continuous flow units have the same flaw. Solution is to try and increase flow and the best way is to take any water filters or restrictors out of your tapware. Most taps have the located in the end of the spout. Unscrew the end and remove any restrictors. Shower roses are a bit more tricky to find. This fixes 99% of these problems.
Dec 22, 2010 | Rinnai Water Heaters
Water is hot until you adjust the shower temperature to warm from hot, then heat unit shuts off and it is 100% cold. Shower head is low flow so wonder if the flow is below minimum for heater to fire?? Can...
These unit is design to operate at a specific flow rate and cannot be ajusted if you need to have a warm shower you will need to get a bath remote where you can turn down the temp whenever you need without disrupting the flow rate
Jul 21, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Caulky white film everywhere? help! and what is a salt chamber?
CHECK FOR TEMPERATURE OF WATER SHOULD BE AROUND 140 DEGREES TO DISSOLVE SOAP AND CLEAN DISHES. IF YOUR WATER IS CLEAN DO YOU NEED A RINSE AGENT OTHER THAN CLEAN WATER.
Mar 09, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
I HAVE A MAZDA 323 1999 MODEL CAN ANYONE TELL ME HOW TO ADJUST THE HANDBRAKE PLEASE please note it is a 1999 model but it wont let me put that year in
your handbreak connects to the rear breaks follow the cable from your break drum where the 2 meet is the ajustment give it a squart of penertrating oil before ajusting as it has been open to the weather also there is further ajustment where the cable enters the hand break lever good luck ps if this dosent do the trick i suggest you cable is fully streched you will need to fit a new one
Nov 15, 2009 | 1986 Mazda 323
After cistern refill outflow into toilet bowl continues to dribble in - and you can see a slight flow into the bowl and every so often we hear the cistern refilling a small amount to compensate.
hi i would suggest your ball valve in the cistern needs ajusting remove the top of the cistern you will see the ajustment screw at the end fo the ball **** arm hope this helps
Nov 15, 2009 | Duravit 0910100005 Happy D Toilet Cistern ...
Inadequate hot water supply
Tankless Water heater tempature is regulated by the rate(amount) of water flowing through the device. To get warmer water for the hot side, slow down the elbo stop leading into the device. Since it is a shower,and you did not say one handle or two.You will have to slow the rate for the cold as well , if one, unless it is an ajustable valve. The drawbacks to the tankless heaters.
Jan 18, 2009 | Rheem Tankless Hot Water Heater...
Kitchen Appliances - Others Logo
69 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
