Question about Liebherr CI-1650 30" Built-In Bottom-Freezer Refrigerator
Liebherr ci 1650 not holding temperature - Liebherr CI-1650 30" Built-In Bottom-Freezer Refrigerator
Liebherr problems
Is the temperature, inside, of the freezer, at least zero? Other than that, good luck.
Sep 07, 2014 | Liebherr Refrigerators
Ice build up inside refrigerator Liebherr K3150
may be you have a bad temperature sensor or bad control board.
Mar 01, 2010 | Liebherr K3150 Refrigerator
Oil capacity for 3.0 crd
Lubricants and capacities
Engine oil options
Ambient temperature range Cold climate
Engine oil grade SAE 5W/30
Engine oil classification API/ACEA CI/C3
Ambient temperature range Moderate climate
Ambient temperature range Hot climate
Engine with filter(s) litres 9,5
Jan 25, 2010 | 2006 Jeep Grand Cherokee
Fan not working, temperature too cold
You may need a man. Mine was doing the same, The sensor repair kit costs £35 the labour £60, both plus vat, so that was £109.25 in 2009.
Repair men seem thin on the ground and therefore his traveling time may add up. I believe, repair men pay for a course, and then charge like a wounded bull as they are the only ones that can do anything necessary
Apr 22, 2009 | Liebherr K3660-20 Refrigerator
We have a liebherr 7082 214 model. We cannot set the temparature for the freezer. after a few seconds the temperature digits disappear and two flashing lights appear
The two flahing lights are normal if the freezer is warm. It will display temperature when it gets cold. If it doesn't get cold there is another problem.
Jul 31, 2008 | Liebherr Refrigerators
Fridge and frezeer not working
Liebherr embraco compressor....compressor fluid leaked while moving, what is the fluid? is it easy to replace?
Dec 06, 2007 | Liebherr KTS 1534 Comfort Compact...
Liebherr CI-1650 30" Built-In Bottom-Freezer Refrigerator Logo
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
