Question about YouTube Videos
LG VR5906LM Robotic wheel repair - says "check the wheels" but it isn't turning properly it is hard to turn
- says "check the wheels" but it isn't turning properly it is hard to turn then the other one
  • 48 Answers
Check if there are some threads or hair lapped over the wheels
Posted on Mar 21, 2014
My steering wheel is getting hard to turn in my Lincoln L's and I have power steering fluid
it sounds like do you have any leaks ?sounds Like the Pump IS wearing Out
Apr 25, 2015 | Lincoln Cars & Trucks
Why does the low voltage breaker kick off every time in turn the vacuum on?
Check to see if the ENTIRE suction system is free of debris. Empty your vacuum bag. Ensure that the brushes/wheels are moving and not jammed. Check for proper voltage to the system. If all of these items are ok, then it needs to be serviced.
May 16, 2014 | AquaVac Tigershark Plus Robotic Automatic...
P0321 and p0322 on a 02 passat
Trouble Code: P0321
Ignition/Distributor Engine Speed Input Circuit Range/Performance
Possible Causes:
Engine speed sensor has failed or is damaged.ECM has failed.Sensor wheel is damaged or doesn-t fit properly.Sensor wheel spacer isn-t seated properly.
Trouble Code: P0322
Ignition/Distributor Engine Input Circuit No Signal
Possible Causes:
Nov 18, 2012 | Volkswagen Cars & Trucks
Brakes pulsate when you put them on. When I take off from a complete stop it feels like the brakes are not releasing immediately.
Pulsating brakes are often caused by warped brake rotors. In order to check for a brake that isn't releasing I would suggest lifting one wheel at a time, applying the brakes and immediately checking if that wheel turns freely. Repeat on all 4 wheels. If you find one that isn't turning freely you'll have to address the problem with that brake.
Jun 18, 2011 | Chevrolet Blazer Cars & Trucks
Robot is in the pool and seems to be on (water is moving above it) however the wheels are not turning
If the wheels stop working on these pool cleaners, it is usually something lodged in the drive train. Check the wheels and axles for leaves, cloth, or other debris and remove if necessary.
Sep 04, 2010 | Smartpool Dolphin Robo - Kleen Above...
Drive wheels are not turning, there is power to the pump
With the simple construction of the pool cleaners, usually a lack of movement means that there is something jammed in the impeller or the drive system. Check for obstructions in the wheels, axles, etc. and make sure that your debris chamber is clear.
Aug 19, 2010 | Smartpool Dolphin Robo - Kleen Above...
Wheels will not turn
If these automatic pool cleaners seem to be working properly but the wheels are not turning, it is most likely debris or tree leaves that are caught in the axle bearings. Check to make sure that you do not have any obstructions. Whatever you do, do not turn the drive wheels by force. This may cause damage to the drive gear train.
May 23, 2010 | Smartpool Dolphin Robo - Kleen Above...
Roomba 560 goes in small circles like it is in "spot mode". Wheels are clean and push up and down and turn easily.
Its likely to be a sensor problem, Either the cliff sensors or one of the 3 wheel drop sensors are the most likely problem.
Oct 08, 2009 | iRobot Roomba 560 Robotic Vacuum
Discovery brushes won't turn. All bearings clean.
usually fibre jammed in wheel / brushes. try small hook run around spaces in unit toremove usuall human hair
Sep 14, 2009 | Roomba Robotic Floor Bagless Vacuum
Front wheels lock up and will not turn
Check your impeller and your front and rear wheel axles. Many times with these automatic pool cleaners, debris (such as leaves) can get jammed. This might cause the wheels not to turn.
Jul 06, 2009 | Smartpool Dolphin Robo - Kleen Above...
YouTube Videos Logo
59 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
