How do I work on TV without being electrocuted
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 136 Answers
If you don't know then i suggest you don't,even after you unplug from the power outlet there are capacitors within the set that can remain charged for a long time and can deliver a nasty shock,One capacitor in particular on the power supply board can be rated at up to 400volts
so please don't risk it..
Posted on Jun 01, 2014
My TV will not stay on I have to keep pressing the power button but will not turn on
The power supply could be failing. It is just able to start but can't continue.
May 11, 2016 | Televison & Video
Electrocution when connecting TV
You have a major electrical fault. You need to get a TV repair man to check this out.
Do not turn this TV on as you maybe electrocuted.
May 15, 2012 | Olevia LT37HVS 37 in. LCD HDTV
TV no longer powering up. Red power light blinks 10 times, stops, then repeats. Tried holding down the power button, turning off the tv for a while, plugging directly into wall instead of surge...
Bad or blown capacitors. Look on circuit board for domed, bulging or leaking capacitors. USE CAUTION!! high voltage capacitors can electrocute you. They should be properly discharged before working on circuit board
Jun 28, 2011 | Panasonic Viera TH-46PZ85U Plasma TV
I have a 32" LCD
Bad or blown capacitors. Look on circuit board for domed, bulging or leaking capacitors. USE CAUTION!! high voltage capacitors can electrocute you. They should be properly discharged before working on circuit board.
Jun 26, 2011 | Sanyo Televison & Video
I bought a runco pl42c and the green light comes on and then clicks off and the red light comes on... Is there anything special needed to get this tv to work?
Jun 26, 2011 | Televison & Video
TV WONT STAY ON
Check your remote power button, make sure its not lose or faulty and turning your TV off for you. Also check the batteries, some times dying batteries cause small problems. Not very often but still a factor.
Now check your power button on the TV itself, make sure its not lose and causing the TV to turn off.
Also check your cables, and your power cord, make sure it is plugged in securely to a working power outlet.
Please use caution when dealing with power related tasks. As not to get electrocuted.
Aug 21, 2010 | Sylvania LC320SS8 32 in. LCD Television
Green & red tint
Most likely nothing you can do to fix this. CRT TVs use 3 colors to make an image on the screen (Red, Green, and Blue). If you're only seeing red and green then chances are the blue has stopped working. You can replace certain parts in the TV but for a 27" TV you'll probably end up paying more for the repair than a new TV.
I don't recommend taking the cover off and trying to fix TV yourself without training. CRTs have a lot of electricity stored in them (even after turned off) and you could accidentally electrocute yourself.
Apr 06, 2009 | Daewoo DTQ-27S5FC 27" TV
TV won't turn on.
Stevenson
the fact that you got shock is because something is not right inside the tv. You need to have that tv check because a manufacturer will not fabricated a tv that can electrocute anyone, specially when you turn the volume. Static electricity is always present in front of any tv that might be the cause of why you got shock. By removing your coat, and touch some metallic object you may get electrocuted, because of static electricity. Please, I want you to have that tv check, I can check that tv for you. I felt something is wrong inside the tv, and something is loose inside like pennies and toys objects. That's my impression. My e-mail address Stevebuy31@hotmail.com
Jan 02, 2009 | Akai PDP4225M 42 in. Plasma Television
Weird sound coming from the inside
TV needs some kind of service and dust inside to be removed.
Regarding sparks sound, it can be leakage of high voltage of Fly-back Transformer. Qualified tv technician can check and repair it as high voltage risk is involved here.
Thank you.
Sep 23, 2008 | Sony KV-27FS12 27" TV
RCA TV 32V434T transformer?
When the HVT goes out, it will take the HORZ output, in short, you will hear a high pitch noise for a sec, when pluged in. As to your question, Its not a hard repair, however its not what I would call a begainer repair. This is what make the high voltage (about 32,000 volts) for you set to work. If you DO try it, becareful. And don't forget to change Horz output p# 274762. After changing the parts, unit will not run for more then 10 seconds. You have to use a volt meter and set the G2 for 290v, with no signal and blue screen. + or - 5 volts will cause unit to shut off.
Tvman
Jul 14, 2008 | RCA 32V420T 32" TV
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
