Question about Lifetime Brands Vasconia 8qt Pressure Cooker 5057075 Kitchen & Housewa
Seal ring needed
Gasket bad
Have low compression on top cylinder of 06 Optimax 75hp
if this an outboard
4 stroke --valve clearance, burnt valve , head gasket, rings
2 stroke -- inlet reed valve, rings, crankshaft seals,head gasket
compression testing should be done dry and then wet( several pumps from an oil can to seal off the rings during the test)
no difference indicates bad rings or valve, head gasket
an increase in readings indicates bad rings
Apr 13, 2018 | Cars & Trucks
Engine oil coming up thru #4 spark plug hole
you have a bad head gasket or a crack in the block or a bad valve seal
Mar 15, 2015 | Cars & Trucks
Oil leaking from toyota camry 1992, 1994 model
You don't say what engine it has. The 4-cyl was a better than the V6 for oil leaks.
The V6 had oil leaks from
-rear bank cam cover gasket
-distributor o-ring seal
-oil filter bracket o-ring seal
-crankshaft nose oil seal (less common)
-rear main bearing oil seal (expensive, just leave it)
The 4 cyl leaked oil from
-camshaft cover gasket
-rear main bearing seal (expensive, leave it)
May 21, 2012 | 1991 Toyota Camry
Have oil in the number one spark plug well
have someone , ( or you ) do a compression check on the motor,, that will tell you if you have a blown head gasket,, or a bad intake gasket , Hopefully its just a simple valve cover gasket that has a O ring for the spark plug seal , I couldn't tell by your question if the plug had oil on the top or on the base, so I gave you both things to check
Sep 08, 2011 | Saturn LS Cars & Trucks
2003 honda shadow 750 ace water pump gasket leaking. Can I replace the gasket only?
There is a round o-ring that seals the water pump to the motor (oil seal). Then there is a shaped cover o-ring that seals anti-freeze into the pump. The cover o-ring is also replaceable. If your pump has coolant leaking it is probably coming from a small weep hole in the bottom of the pump. Check where the leak is carefully, my guess is that the water pump seal is bad and you actually need to replace the water pump assembly. To see a break down of the pump look here.
http://www.bikebandit.com/houseofmotorcycles/2002-honda-vt750cda-shadow-ace-deluxe-black/o/m2894#sch94027
Mar 17, 2011 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
I have an exhaust leak at the manifold. Do I need to replace the flange gasket and the O ring. My question is will I ruin the flange gasket when I disassemble it to replace the O ring?
Yes, any type of gasket or seal on your exhaust will not reseal properly. Exhaust seals have a "crush seal" . Once crushed will not be reusable.
Please take a moment and rate my answer........Thanks
Dec 01, 2010 | 2002 Jeep Liberty
I found oil on 2 spark plugs telling me the head gasket is blown. Ive never replaced one before what can you tell me?
Oil on the plug does not indicate a head gasket.
It could be a bad ring, valve guide or valve seal.
A leak down test will comfirm a head gasket leak
A compresion test will confirm a ring problem.
Oil consumption and smoke indicate ring and valve problems.
If it smokes on stat up, most likely valve guide or seal.
If if smokes when you drive and let off the gas quickly from speed, then most likely a ring or cylinder wall problem.
Good Luck
Oct 05, 2010 | 2006 Saturn ION
Rubber gasket
Feel around the seal, in the groove behind the seal face. You'll find a spring at the bottom. With a small screwdriver, lever the spring over the seal face. Work the steel ring off. Fold the seal inside the washer. Unplug the washer, Remove the door, and set aside. Locate your panel screws and remove the front, exposing the drum and basket. There are usually additional screws under the dispenser trays too. Disconnect the door lock wires. Locate the other spring/ring assembly on the outer drum, and remove. Orient your new seal properly and reassemble. The only difference on the reassembly is that, when you are putting the rings back on, start 180 degrees from the spring, and work the ring back on until you get to the spring. Carefully lever the spring back over the seal face, being careful not to damage your new seal.
Best regards, --W/D--
Aug 08, 2009 | GE Energy Star WCVH6260F Front Load Washer
2001 525 oil getting in to number 2 cylinder
Valve guide/seal, Piston rings, head gasket. Getting oil fouling on plug?
Jun 07, 2009 | 2000 BMW 5 Series
1999 tt-r250 blowling LOTS of smoke all of a sudden
The seals in the valve guides are going bad or the cylinder head is not down tight > letting oil into the cylinder, or you have a bad head gasket and "O" ring seal. The problem could be any one of the three causes noted above.
Try tightening down the cylinder head. It may fix the problem. If not then the fix is to pull the cylinder head and inspect the head gasket and "O" ring seal if one is present. If the gasket is dirty and oily then replace the gasket & "O" ring. Consider lapping the valves while the head is off. This will give the valve face and valve seat a fresh mating surface thus providing more power.
If the gasket is clean and dry then the shop will need to replace the valve guides. Be sure they also lap the valves.
Please rate this solution. Thanks
Apr 12, 2009 | 2002 Yamaha TT-R 250
Lifetime Brands Vasconia 8qt Pressure Cooker 5057075 Kitchen & Housewa Logo
42 people viewed this question
Top Lifetime Brands Home Experts
john h
Tom Chichester
Are you a Lifetime Brands Home Expert? Answer questions, earn points and help others
