Question about Jack Rabbit Tonneau Cover - Reviews & Installations -
How to change fuel filter VDJ200
How do you remove/install the filter into housing
    Master:
  • 424 Answers
Posted on Jan 08, 2017
Looking for step by step instruction to change my fuel filter on my 2006 2500 cummings 4x4 quad cab
fuel filter housing on driver side of motor. need the correct size of socket to remove the lid. unscrew lid and pull straight up to remove filter. remove old filter from lid and install new filter and seal. drain old fuel/water from housing. then reinstall filter into housing. tigthten lid then make sure the petcock is closed from draining it earlier. bump the starter a couple times to fill the filter housing then start engine. clean any spilled fuel and your done.
Sep 25, 2011 | 2006 Dodge Ram 2500
Where is the fuel filter on a 1985 s15 2.8
Not sure about this particular one but if you don't see it in the fuel line anywhere it may very well be in the carburetor. Simple to change just remove the inlet fuel line from carburetor and then unsrew the filter housing and remove old filter. Clean out housing and install the new filter and inspect the seal for the filter housing for damage. To be safe, perform this with the engine cold.
Apr 23, 2011 | 1985 GMC S-15
Oil filter is spinning in the housing. scared to try to take it out
i believe that that your car has a cartridge filter (paper filter) that goes into a housing and has a cap that you take off to get to it the filter presses into the cap then you screw the cap back on most of the cartridge filter fell off of the caps and sit in the housings by the time you change your oil next.
chris
Mar 11, 2011 | 2002 Saturn L-Series
I need "step by step" instructions on how to replace the fuel filter on my 2001 Dodge Ram 3500 pickup. Thanks !
Here you go if it is a diesel:
A. FUEL FILTER REPLACEMENT:
The fuel filter is located inside of the fuel filter housing
1. Unscrew and remove fuel filter cap at top of fuel filter housing. To unscrew, attach tool to 6-sided hex center of cap. Do not loosen cap at outer edge. The fuel filter cap is designed to remove filter while pulling up on cap.
2. Remove O-ring from cap and discard.
3. The filter is retained to cap with little fingers. Carefully pry a couple of them off from old filter.
B. FUEL FILTER REPLACEMENT:
1. Thoroughly clean inside of filter housing, cap, etc. with clean diesel fuel
2. Fill filter housing (canister) with clean diesel fuel. NOTE: If you do not do this, you will have to manually bleed air out of system later. No fun.
3. Snap new fuel filter to bottom of cap.
4. Install new O-ring
5. Apply lihgt film of clean diesel oil to cap O-ring
6. Load filter/cap into housing.
7. Tighten cap to 25 ft. lbs. torque. Do NOT over-tighten.
Sep 03, 2010 | 2001 Dodge Ram 3500 Truck
Where is the fuel filter on a 2000 Mazda Millenia 2.3 V6
Fuel Pump-Mounted Filter
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Properly relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable
    • Fuel pump cover plate
    • Fuel lines from the fuel pump
  4. Raise the fuel pump from the tank.
  5. Remove the fuel filter assembly.
To install:
  1. Install or connect the following:
    • Fuel filter to the fuel pump. Lower the pump assembly into position
    • Fuel lines
  2. Start the vehicle, check for leaks and repair if necessary.
  3. Install the fuel pump cover plate.
Inline Filter
Exploded view of an in line fuel filter and related components
  • Air intake hose and/or filter housing, if necessary
  • Fuel line clamps, if equipped
  • Fuel lines from the filter and plug the openings
  • Filter clamp bolt/nut by loosening them.
  • Fuel filter from its mounting bracket
  • NOTE Note the direction of the flow arrow on the filter so the replacement filter can be installed in the correct position.
    To install:
      • Fuel filter in its mounting bracket, making sure the flow arrow is pointing in the proper direction
      • Fuel lines to the fuel filter
      • Air intake hose and/or filter housing, if removed
    2. Pressurize the fuel system and check all connections for leaks.
    May 24, 2010 | 1998 Mazda Millenia
    Looking for fuel filter on 2004 chevy silverado ss 6.0, not on frame rail
    Here is the steps for the removal and replacement...getting you the picture and location next. 6.6L Engine
    1. Disconnect the negative battery cables.
    2. Drain the fuel from the fuel filter as follows:
      • Install a hose on the water drain on the water-in-fuel sensor.
      • Place the other end of the hose into an approved container.
      • Drain as much fuel as possible from the fuel filter housing.
      • Tighten the water drain on the water-in-fuel sensor.
      • Water-in-fuel sensor harness connector
      • Fuel filter from the fuel filter/heater element housing
      • Water-in-fuel sensor from the fuel filter
    Exploded view of the fuel filter (2)—6.6L engine
    To install:
      • Water-in-fuel sensor in the fuel filter
      NOTE Check the fuel filter/heater element housing and the filter for a dislocated filter seal or foreign debris. Contamination on the filter/heater housing may cause leakage at the fuel filter. Coat the seal with clean engine oil.
      • Fuel filter on the fuel filter/heater element housing
      • Water-in-fuel harness connector
      • Negative battery cables
    2. Prime the fuel system:
      • Pump the primer located on top of the fuel filter 30 times or until stiff.
      • Try to start and run the engine. If the engine does not start, repeat the previous step.
      • Allow the engine to run for 5 minutes at idle.
      • Check for fuel leaks and clear all Diagnostic Trouble Codes (DTCs).
    May 07, 2010 | 2004 Chevrolet Silverado 1500 Crew Cab
    How to remove fuel filter housing 97 ford f-350
    FIRST YOU NEED A SUITABLE CONTAINER.PLACE UNDER FILTER DRAIN HOSE OPEN THE FILTER DRAIN.NOW YOU HAVE TO REMOVE THE TURBOCHARGER ASSEMBLY.REMOVE THE THE BAFFLE AND THE AIR INLET CROSSOVER MANIFOLD.REMOVE THE TWO CAPSCREWS SECURING THE FUEL FILTER BASE TO THE CRANLCASE.DISCONNECT THE WATER DRAIN HOSE FROM FILTER. DISCONNECT THE FUEL OUTLET HOSE LOCATED BETWEEN THE FUEL AND FILTER HOUSING.AND THE FUEL RETURN HOSE FROM THE FUEL PRESSURE REGULATOR VALVE.DISCONNECT THE TWO FUELSUPPLY HOSES THAT CONNECT THE REGULATOR BLOCK TO THE CYLINDER FUEL RAILS.LOOSEN THE CLAMP AT THE FUEL PUMP END OF THE HOSE WHICH CONNECTS THE FUEL FILTER TO THE INLET OF HIGH PRESSURE STAGE AT THE FUEL PUMP.DISENGAGE THE WIRING HARNESS FROM THE RIGHT SIDE OF THE FILTER HOUSING.DISENGAGE THE ELECTRICAL CONNECTIONS FROM THE WATER IN FUEL SENSOR AND THE FUEL HEATER.REMOVE THE FUEL FILTER.USE A PRYBAR TO REMOVE THE FUEL FILTER CAP AND THE FILTER ELEMENT WILL COME OUT WITH THE CAP.DEPRESS THE ELEMENT LOCKING TABS AND REMOVE THE ELEMENT FROM THE CAP.TO INSTALL CLEAN THE MATING SURFACES AND INSTALL THE FILTER ELEMENT ONTO THE CAP MAKING SURE THE TABS ENGAGE.INSTALL THE FILTER CAP AND PRESS DOWN FIRMLY BUT GENTLY TO ENGAGE IT.ENGAGE THE WIRING CONNECTIONS TO THE FUEL HEATER AND WIF SENSOR.ENGAGE THE WIRING HARNESS TO THE FILTER HOUSING.TIGHTEN THE CLAMP AT THE FUEL PUMP END OF HOSE WHICH CONNECTS THE FUEL FILTER TO THE INLET OF HIGH PRESSURE STAGE AT THE FUEL PUMP.ENGAGE THE TWO FUEL SUPPLY HOSES THAT CONNECT THE REGULATOR BLOCK TO THE CYLINDER HEAD FUEL RAILS.CONNECT THE FUEL OUTLET HOSE LOCATED BETWEEN THE FUEL AND FILTER HOUSING AND THE FUEL RETURN HOSE FROM THE FUEL PRESSURE REGULATOR VALVE.CONNECT THE WATER DRAIN HOSE TO THE FILTER.INSTALL THE 2 CAP SCREWS SECURING THE FUEL FILTER BASE TO THE CRANKCASE.INSTALL THE AIR INLET CROSSOVER MANIFOLD AND BAFFLE.INSTALL THE TURBOCHARGER ASSEMBLY.
    Apr 03, 2010 | 1997 Ford F350 Crew Cab
    How do i change the fuel fitler in a 03 power
    should have a cover on top of the engine, lift cover , there will be a cylindrical Fuel Filter housing with a lever on the side and a cap on top. remove the cap, remove the old filter & install the new filter & the NEW seals. use the little lever to drain the old fuel & any water from the fitler housing & start engine per normal Diesel starting procedures
    Oct 08, 2009 | 2003 Ford F Super Duty Chassis Cab
    Where is the fuel filter on a turbo desail
    Your fuel filter is mounted on the rear of intake manifold, under air cleaner or on rear firewall.
    Just a little hint on replacing it, remove your fuel tank cap to release pressure or vacuum in the tank. I'm sending you a diagram the fuel filter assembly so it will make it a little simpler for you to replace your fuel filter. Start by removing the filter element nut. Remove filter element by lifting straight out of filter housing. It is not necessary to drain fuel from filter housing when changing the filter element.
    Installation, ensure mating surface between filter element assembly and filter housing is clean. Install new filter element by aligning widest key slot located under element assembly cap with widest key in filter housing assembly.
    Tighten element nut by hand. Bleed air from fuel manager/filter assembly. Connect a hose to air bleed valve and place other end of hose in a container.
    Disconnect fuel injection pump shutoff solenoid wire. Crank engine for 10 to 15 seconds. Allow starter to cool down for one minute between cranking intervals. Repeat procedure until clear fuel is observed at the air bleed hose.
    Close air bleed. Connect injection pump shutoff solenoid wire and reinstall fuel filler cap. Start engine and allow to idle for five minutes. Check fuel manager/filter for leaks.9df1ca0.gif
    Oct 03, 2009 | 1994 Chevrolet C/K 2500
    Changing fuel filter on 2006 dodge ram 2500 diesel
    Jan 21, 2009 | 2006 Dodge Ram 2500
    Jack Rabbit Tonneau Cover - Reviews & Installations - Logo
    Top Pace Edwards Vehicle Parts & Accessories Experts
    Richard Petch
    Level 1 Expert
    Robert Rankin
     Brian Main
    Brian Main
    Are you a Pace Edwards Vehicle Part and Accessory Expert? Answer questions, earn points and help others
