Question about Sanyo DS24424 24" TV
Xbox sound but just blue screen
Only blue screen displayed, but sound works with component cables
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
I have an Emerson lc320em9 3 model tv and I can't
Make sure your X Box is switched to component and not hdmi.
May 02, 2012 | Emerson Televison & Video
When I play a gane the sides of the screen cut off
If you have a widescreen TV, your resolution is likely the cause of this. See if your TV has a resolution setting in its menu. Don't worry if it doesn't, some TV's only have one default resolution.
Check what type of cable you are using to connect to the TV. If you are using composite cables (red, white, and yellow) and you have a flatscreen/HDTV, you should switch to component or HDMI cables. (Your Xbox may have came with component cables. They are the red, green, and blue ones, if it did and you aren't using them, use them.)
Once you're using component or HDMI, the problem should be solved. If it is not, change the resolution on the Xbox. To do this, go to System Settings > Console Settings > Display and mess around with the settings in that to find out what works for your TV.
Apr 20, 2011 | Microsoft Xbox 360 Console
How do i hook my XBOX-360 up to this tv and get 1080i resolution? Thanks, Mike
You should be able to get 1080i with the Input/DVI port or the component video in ports of the TV. I believe the easiest option will be to set the XBox A/V switch to HDTV and use a component video cable (red, green, blue) from the XBox component out to the TV Component In. (with the audio out going to your TV or speaker system). Turn on the X-box and the My Xbox > System Settings. Then Console Settings > Display and chose the 1080i.
Set the TV Net Command (remote) and the Device settings for the input jack in use (component 1/2). Adjust the A/V menu for the Display before playing long.
Wen you change inputs, you will see a status screen for the settings for the TV input.
I hope this helps.
Sep 14, 2010 | Mitsubishi WS-48513 48" Rear Projection...
XBOX 360 composite output works fine. Component
You say the component video is no good? Well this usually happens when it is wired up incorrectly, Ensure you have the right colors in the right jacks at each end, it is real easy to get mixed up... make sure Red goes to Red, Blue to Blue and Green to green, all alongside each other, NO ALSO using Component you MUST also run 2 more cables for the Audio, they are Red & White NOT the Red from the "Other" Video input, BUT the AV Red & White jacks, beside each other on the units. So all in all there are 5 cables taking the Video, 3 R, G, B. + The Audio, R & W.
Mar 02, 2010 | Microsoft Xbox 360 Console
Plays dvds on xbox 360 fine, but no picture for games/dashboard
already solved it. thanks. i couldn't see the xbox settings blade because of the blank screen so switched my component cable to the tv setting instead of the hdtv setting, then i could see the dashboard in non-hd and switched the resolution to 720p while simultaneously switching the component cable back to the hdtv setting. that worked.
Jan 02, 2009 | Sharp Televison & Video
Hello my name is steve
1. Make sure the Cable is properly connected to the back of the Xbox.
2. Make sure the Cble is properly connected to the inputs on the TV (Color coded if using component or composite cables).
3. Look on the large part of the cable where it plugs into the Xbox. There is a switch with two settings: HDTV and TV. If using the component cables (Green, Blue, Red + White Red), turn the switch to HDTV. If using the composite cables (Yellow, White, Red), switch it to TV.
4. If the problem persists, contact Microsoft at 800 4MY - XBOX . It's a toll free number but it isn't 24 hour.
plz Rate"
Dec 17, 2008 | Microsoft Xbox 360 Console
Xbox and tv = no sound
Yes, those cables are quite common. Check any electronics retailer like Best Buy or Walmart.
Aug 25, 2008 | Microsoft Xbox 360 Console
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
Sanyo DS24424 24" TV Logo
11 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
