Question about Toshiba Satellite Pro A210-EZ2203X Notebook
A message appear is 'BOOTMGR is missing'
I try to run a repair and set up but it's too slow.Any solution
    Problem Solver:
  • 22 Answers
Re install the operating system...
Posted on Apr 28, 2014
2 Suggested Answers
SOURCE: when i turn my laptop the message appears saying
I recommend getting it reformatted to be honest goto a pc store it won't be much :)
Posted on Dec 14, 2009
BOOTMGR is missing,
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Check your optical drives, USB Ports, and floppy drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable disc, external drive, or floppy disk.
  3. Reseat all internal data and power cables. BOOTMGR error messages could be caused by unplugged, loose, or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  4. Perform a Startup Repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR.
    Even though a Startup Repair is a common solution for BOOTMGR problems, don't worry if it doesn't fix your problem. Just continue troubleshooting - something will work.
  5. Write a new partition boot sector to the Windows system partition to correct any possible corruption, configuration problem, or other damage.
    The partition boot sector is an important piece in the boot process so if there's any issue with it, you'll see problems like "BOOTMGR is Missing" errors.
  6. Rebuild the Boot Configuration Data (BCD). Similar to the partition boot sector, a corrupted or incorrectly configured BCD could cause BOOTMGR error messages.
    Important: The following troubleshooting steps are much less likely to help fix your BOOTMGR problem. If you've skipped any of the above ideas then you may have overlooked a very likely solution to this problem!
  7. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  8. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, please understand that you will lose them all if you continue with a clean installation of Windows!
  9. Replace the hard drive and then install a new copy of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
SysFlashwww.sysflash.com
May 29, 2013 | Lenovo IdeaPad S10-3t 0651 Notebook
I NEED TO INSTALL NEW OS ,BUT CAN'T CHANGE PRIORITY CD DRIVE ,THERE ARE PASSWORD PROTECT ,AND I TRY TO PRESS CTRL+ESC OR DEL+ F2 ALSO SHOW SHORTLY AND APPEAR BOOTMGR MISSING MESSAGE ,I HAV
BIOS passwords can be reset in two ways:
1. using software 2. using hardware.
I would first try resetting using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html
CmosPwd - Cmos password recovery tools
http://www.syschat.com/download121.html&act=down
Good Luck!
Jun 26, 2012 | Acer ASPIRE 9410-4933 COMPATIBLE LAPTOP...
PC will not boot, BOOTMGR is missing. What do I need to do?
I assume it's Windows 7.
Check that the BIOS is set to boot from CD/DVD as the first boot device and then put the Windows installation disk into the drive. If done correctly then the PC should boot from the CD/DVD and then just follow the on screen instructions (follow the instructions and select the repair option).
Jun 08, 2012 | Computers & Internet
How can i boot my Windows Seven OS if the "bootmgr is missing"? I'm installing windows seven but when windows start copying files but error message appears that required files for the...
What you need is bootable DVD/CD for installing or repairing Windows 7 to get missing 'bootmgr' or repair corrupted bootmgr...If there are files corrupt on your CD, you can get new one from shop you have purchased..Maybe just need to clean up your DVD/CD, so your DVD drives can read properly the files installation..
Aug 07, 2011 | Computers & Internet
Missing bootmger
Fixing the "BOOTMGR is missing" error isn't too hard; here's how.
The day before yesterday I was testing out a program with several system utilities built in. One of its components left my computer in a bit of a mess - no icons anywhere and other assorted woes. I had set a system restore point before I ran the program, so I thought I'd do a system restore. System restore gave me a message that it couldn't restore my files. I decided to restore a disc image I had made a short while back. When I booted up the computer I got a message:
BOOTMGR is missing
Press Ctrl+Alt+Del to restart
I stared at it the white letters on the black background for a few minutes, while the cursor blinked back at me. After some searching (on another computer) I had some solutions.
Barring any hardware errors, here's how to fix that error:
  • Insert your Windows Vista or Windows 7 disk into your DVD player and restart your computer.
  • The next screen you see should have the Language, Time and Currency and Keyboard boxes.
  • In the lower left side there are two options: "What to know before installing Windows" and "Repair your computer."
  • Click on "Repair your computer"
  • Windows will then try to find the installation directory for Vista or Windows 7, depending on what you have.
  • Next up is a screen with a box called Recovery Options. Click the first option, Startup Repair.
  • You'll see a Startup Repair box with the message "Startup Repair is checking your system for problems..."
  • When it's done, it will prompt you to reboot. If there is more than one problem it may reboot again to continue repairing.
  • At this point, you can remove the DVD, reboot and everything should be working.
Two sites I found helpful are BOOTMGR is Missing at about.com and cyberstorms How to fix "BOOTMGR is missing" in Windows Vista
If the method outlined above doesn't work, try Solution #2 at the cyberstorm link.
Oh, restoring the disc image went fine and all is well. All my data was backed up (somewhere other than the hard drive Windows is on) so that was one thing I didn't need to worry about. Windows Vista and Windows 7 are the only Windows operating systems where this message appears; XP users don't have to worry about this one.
Mar 29, 2011 | Computers & Internet
Bootmgr missing
Causes of BOOTMGR ErrorsThere are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Another reason you might see BOOTMGR errors is if your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. Fixes for BOOTMGR Errors
  2. Perform a startup repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR. Continue troubleshooting if this does not resolve the issue.
  3. Check your floppy and optical drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
  4. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
  5. Reseat all internal data and power cables. BOOTMGR error messages could be caused by loose or malfunctioning power or controller cables.
  6. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  7. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows.
  8. Replace the hard drive and then perform a new installation of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
BOOTMGR Errors Apply To BOOTMGR issues apply to Windows 7 and Windows Vista operating systems only. Windows XP does not utilize BOOTMGR. The equivalent function in Windows XP is NTLDR
Whish you the best luck.
Mar 06, 2011 | HP Computers & Internet
Bootmgr is missing
BOOTMGR is missing
Feb 18, 2011 | Acer Computers & Internet
Bootmgr missing
Hi
Thank you for your query
If bootmgr is missing then im afraid you will have to reformat the PC,
To reformat please do the following
1) Put your recovery CD into your drive and then restart PC
2) Follow the onscreen instructions to recover your PC
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 18, 2010 | Computers & Internet
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
Vista with bootmgr is missing message
put your recovery disk or vista OS disk and repair the boot...
Mar 25, 2008 | HP Compaq Presario C500t Notebook
Toshiba Satellite Pro A210-EZ2203X Notebook Logo
21 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
