Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Pool pump I added the recommended amount of salt to my pool,waited the 24 hrs (longer now) cleaned out the titanium plates of any dirt as recommended and i am still getting error code 91...is it possible i have to add more salt? I don't want to add more salt and then have to drain pool and add fresh water as this water already cost me 350.00 bucks as i am out in the ''stix'' and i will not have another water truck come in to top my pool up again...i think i've already been ripped off enough this week with this system and the salt and the water.....very $$$
  • sharonsteph Jun 15, 2009
    Thanks..I'm going to give that a try tomorrow...do you think that is all i should have to add as i'm far from any stores so i have not been able to get any salt for a few days. I have just been leaving my pool pump on 24/7 to keep the water circulating(sp?) I added 80pds to start off with as recommended.
    well i just got off the phone with "intex" would not give me any advice other than send the system back. Would not tell me if i should or shouldn't add salt etc....do they not understand that sending this back and waiting for a new one will take time...summer will be over!!!!!I'm going to add another bag and hope that all goes well.yes they do stand behind their product as last year i bought the new "ultra frame pool" again had the water trucked in...filled up the pool and the pool had leaky seams,they told me to send it back,i explained how i paid for the water and was not draining it to wait for a new pool etc...they told me i had 90 days warranty and to use it lots before all the water was gone lol. needless to say it rained and rained here so there was no need to top off the pool and we used it as much as we could and sent it back in the fall and they sent us a new one.
You may have a hard water problem. Remove and inspect the unit containing the plates. You'll be able to see build-up. I was surprised to see how much it had coated the plates after only a month of use. Cap end and soak with vinegar. Re-install. Check regularly. Also, with the initial salt startup, a 16'x48" requires 120 pounds, the first time your low salt light comes on, the manual says to add 30 more lbs. That's a total of 150 lbs. Speed up the salt dissolving process, mix it up physically and aim the return down into the water, remove the skimmer if you have one so intake and circulation is maximized. Run for 24 hrs. Make sure you have a more than adequate pump with a clean filter. I replaced mine with a larger Intex pump.
Posted on Jun 25, 2009
    Problem Solver:
  • 11 Answers
We had the same thing happen! We added about 20 pounds more of salt, waited about 4 hours to make sure it had dissolved (with the filter pump on that came with the pool) and it worked. We thought we had added enough to begin with too but apparently not. The key is to wait until it's dissolved before trying again. Hope that helps, good luck!
Posted on Jun 14, 2009
  • reichlfamily Jun 15, 2009
    I would keep the pump running as this filters the water, but wait until the salt is completely dissolved, at least a few hours, before running the saltwater system. Your manual for your saltwater pump should tell you how much salt to add when it tells you that you need to add salt, I'd make sure you have at least that amount on hand for any future problems. Hope this helps! If not, contact the company for sure, they are pretty good about their customer service and if you have a faulty saltwater system, they will stand behind it!
Started my salt water system soon after adding a bag of salt. Now I'm getting a low flow warning even though there is plenty of flow. What could the problem be.
You may think you have good flow, but the sensor that always is confirming the proper amount of flow is telling you that it is not!
Especially if you have a Toy system. The filters that come with these systems are way too small and will clog quickly and provide a restriction of water flow.
Test naked Try this (after waiting 24 hrs and if problem still persists) take the filter out of filter housing and see what happens? Does the error go away? If so, then replace with "New" filter, not a cleaned one. Filter elements get clogged, with metals & minerals, that you can't see with a naked eye. It may look clean, but is not.
If all this is still creating a problem (with no filter element in place) then you may have a faulty flow sensor?? But I would not go there immediately because the sensor is probably just doing its job.
Apr 27, 2015 | Intex Automatic Salt Water System for ...
We have a Krystal Clear Saltwater System Model CS8110. We are first time pool buyers. We set up the pool last week and despite several "boosts" the chlorine level is very low. The pool store...
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
Jul 15, 2011 | Intex Automatic Salt Water System for ...
I have an Intex Krystal Clear Saltwater System, model CS8111. My problem is green water. I had been out of town for a few days and when I came home the pool was green. Also the low salt light was on. I...
If your salt is at the correct levels required for your pool and your still getting the "91" code on your LCD screen do not add more salt you need to clean the plates on the chlorinator. Look at your manual and it gives you instructions on how to remove, clean, and replace the chlorinator section on the pump. Reminder, if your PH and/or alkalinity levels are off you'll be cleaning the plates often because of the scale build up. I personally run my pump 4 hrs daily and I have never had a problem with green water however, once it did become cloudy (white) I began treating with algaecide and changing filter every 3 hrs. It cleared it right up. I love the Krystal Clear System.
Jun 26, 2011 | Intex Automatic Salt Water System for ...
I have forgotten how to set my salt water system to initially chlorinate the water after i added the salt. It keeps beeping and the code says no salt is detected.
Could be a couple of things. Have you put the right amount of salt in according to the tables (I find I always have to add a bit more then the tables say). Have you let the salt mix completly by stirring up any salt laying on the bottom of the pool and by running the pump for at least 24 hours before turning on the salt generator. Depending on how large the pool is you may need more than 24 hours before turning on the salt generator. If still doesnt work than you can try adding more salt a little bit at a time over a couple of days. Also check to see if the electrolytic plates need cleaning. Unscrew the large grey connector to the left of where the wire goes into the sensor and look inside the unit on the left)
Apr 04, 2011 | Intex Automatic Salt Water System for ...
I have a Intex Pool that is 18 ft by 52 in. I have a Salt water chlorinator unit and I am tryiong to start up my pool. I added 80 kg of salt which is the recommended amount for my pool and then I ran my...
I have a krystal Clear deluxe Satlwater system recently the water went green(lots of rain) I added more salt and have run the pump extra time. It is better but not back to normal. Do I have to shock it and how do I do that? What and how much do I put in for an soft set pool 18 x 48.
thank you
Jun 17, 2010 | Intex Automatic Salt Water System for ...
Low salt alarm on Intex system
so what does the test strip say. Should be as close to 3000ppm as possible anything close and under 2700ppm will trigger a low salt also you must run filter only for 24 hours to thouroughly mix the salt before trying to turn on the generator
Jun 14, 2010 | Intex Automatic Salt Water System for ...
No chlorine being produced
although you are close to the amount of salt that is recommended all pools are just different enough that the salt table is just a starting point if you do not have enough salt it is still possible to not trigger the alarm but not produce enough chlorine.
Start by getting a salt test strip kit and get your pool to 3000ppm this may take a day or so since you really need to filter and circulate the pool for 24 hours in between adding salt
Once you get the salt right then move on to generating
also do not worry about total chlorine you just need to concentrate on free chlorine this is the amount available in the pool to do it's job and dont forget to ad a stabilizer to help hold the chlorine level on hot sunny days
Jun 05, 2010 | Intex Automatic Salt Water System for ...
CLOUDY SALT WATER POOL
salt does not solve your problem.
People do no realize that all the salt does for you is that it eliminates having to pour regular chlorine in.
Everything else stays the same as a normal pool with just plain ole h2o
The dilema is that intex filters are to small for the job that needs done especially in your case now that you have the dreaded green monster
your solution is to first get it cleared up
shock your pool with 2 gallons of liquid chlorine and then filter filter filter
You will need to brush the dead algea and vaccum once or twice a day for a couple of days and you must clean that cartridge 3-4 times a day with the garden hose
you will be surprised how much green it will trap
once pool starts to clear and the chlorine level starts to come back down from Mars you can start using your generator again.
you will need to find the amount of time thatorks for you but 3-4 hours will not cut it in the hot weeks
Chlorine consumption is due to #of bathers, heat ,sun, rain so any given day will dictate a different amount of generation needed keep it high so you do not get algea again about 3.0
you also got algea because you were not stiring up the pool enough you again need to filter filter filter every day
try to find some of my other postings with more specifics
Aug 13, 2009 | Intex Automatic Salt Water System for ...
We switched to the saltwater system and the water is cloudy
hello way too much for me to type if you want to call I can go through it have a pad of paper and pen ready
Mark
586-625-2300
Jul 19, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
967 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
