Question about Konica Minolta Office Equipment & Supplies
Konicaminolta bizhub c353 magenta background while printing
Magenta background while pringing the document
SOURCE: document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Posted on Jan 07, 2008
Kevin Hayes
  • 167 Answers
SOURCE: multiple copy error
Turn OFF sorting and/or grouping in the finishing tab.
Posted on Dec 05, 2008
taminol
  • 62 Answers
SOURCE: Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
Posted on May 26, 2009
  • 95 Answers
SOURCE: WHY IS THERE A BLINKING ORANGE LIGHT ON BIZHUB
That is not much to go on, but it is possible that the print job got sent to the wrong tray. Say you printed a job to tray 2 which has legal paper in it, but the job is formated for letter it could lock down printing until the job is canceled and sent to the right tray. If there is an error code try and shut machine off and on using the main power switch inside front door.
Posted on Jun 04, 2009
TheChiefGeek
  • 7 Answers
SOURCE: Our KonicaMinolta Bizhub C280 Internal Error C2555
You didn't mention the size of the job size, but it sounds like a memory problem. If you have a service contract or it's still under warranty, contact your rep before you start opening things up.
The following is if you don't have a service contract. If the bizhub has been working with no problems in the past, try reseating or replacing the RAM. I've had to replace RAM that started causing problems on classroom computers. If you bought it refurbished (used) check to see the 2GB RAM that supposed to come with the bizhub hasn't been removed or replaced with smaller memory.
Posted on Oct 20, 2010
How do I correct error c4152?
Magenta Print head (print head has the LASER inside of it that writes the image on the drum) in this case it is the magenta LASER. Open and close the front door to reset. If it comes back replace the print head. Normal done as a set of all four. (Black, Magenta, Yellow, and Cyan). Worse case is the relay board is bad or the Image control Board$$$$$$$$$$$$$$$$.
Try this site as a start:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 04, 2015 | Konica Minolta Konica Bizhub C353 Drum...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
C-4152 error c353 bizhub
magenta LASER located under the Magenta (red) image unit
Dec 23, 2013 | Konica Minolta Minolta Bizhub C353 Copier
I have konica minolta bizhub c353 i have problem
Most likely it is your magenta cartridge or magenta developer unit.
did you recently change cartridge?
Are you using original cartridge?
Nov 13, 2010 | Konica Minolta bizhub Office Equipment &...
Multiple copy error
Sep 24, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
54 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
