Question about Whirlpool Duet GHW9150P Front Load Washer
Washer fix noise
Unevenspin cycle
  • Whirlpool Master
  • 5,323 Answers
LOUD NOISES IN washing MACHINE;
LOT OF THINGS TO CHECK, THE BELT LOOSE OR WORN, THE CLUTCH, THE TRANNY, THE BEARINGS BOTH TUB SEAL AND BEARING, THE REAR DRUM BEARING, the balance or counter weights.
THE DRIVE PULLEY- If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
THE TRANSMISSION, THE MOTOR COUPLER, THE MOTOR DRIVE BEARINGS,
THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
The drive coupling connects the motor to the transmission and consists of two plastic drive forks with a rubber coupling between them. One of the drive forks is attached to the drive motor shaft and the other is attached to the transmission input shaft. As the motor shaft rotates, the rubber coupling between the drive forks absorbs the torque to prevent the forks from breaking. Normal use will create wear on the coupling and eventually the drive forks may slip and cause a vibrating noise. If the transmission seizes or if the spin basket cannot turn freely, then the coupling may fail and again you may experience a vibrating noise. Most models will require you to remove the cabinet to access the drive coupler. Disconnect power from the appliance before attempting any repairs.
A worn drive block will usually have a pounding sound, like hammering metal, during spin when it first starts. If there is enough interlocking tab left on the drive block, you'll see it finally engage at top speed with an empty basket.
In a transmission lock up the holes get enlarged in the rubber isolator and the studs break off the motor and transmission couplers. This is usually caused by the abrupt motor reversal between the agitate and pump out functions. If you hear a loud bang every time the motor reverses, the coupler is getting loose. An obvious sign of a failed coupler is a pile of black rubber shavings under the washer. If the motor runs and the agitate and spin functions don't work, the studs may have broken off the coupler (old coupler design) or the coupler may have broken at the shaft (new design) and you need a new coupler kit. The coupler can also just crack around its center hole allowing it to slip on the motor or transmission shaft hampering those functions.
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Front load washers often use a self contained electric drain pump and the motor may be worn or damaged and require the complete pump to be replaced. Remove any foreign objects or replace the worn or damaged pump, thencarefully tighten the hose clamps and check for leaks before installing the cabinet or front panel.
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
washer fix noise - 23877311-izj50bzy441rirqhwblyybfs-2-20.jpgges/23877311-izj50bzy441rirqhwblyybfs-2-20.jpg" alt="23877311-izj50bzy441rirqhwblyybfs-2-20.jpg" class="h_mwasher fix noise - 23877311-izj50bzy441rirqhwblyybfs-2-27.jpgxya.net/uploads/images/23877311-izj50bzy441rirqhwblyybfs-2-27.jpg" alt="23877311-izj50bzy441rirqhwblyybfs-2-27.jpg" class="h_mi" />
Posted on May 12, 2015
Samsung front load washer, jerks and makes noise when it first starts spinningthen it smooths out, and works fine.
on many machines that is normal, the shaking continues until the load is distributed relative evenly around the spinning drum. It is also possible it is the main bearing but I am not sure. The noise I am talking about would have been there since new. These links may help. Washer has noise during spin cycle Whirlpool Maytag Sears GHW9100LW1 Washer is Making Loud Noise
How To Fix Washing Machine Making Noise During The Spin Cycle
http://www.partselect.com/Repair/Washer/Noisy/
May 28, 2016 | Samsung Platinum Front Load Washer -...
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washer won't spin and makes noise on spin cycle
Sounds as if it just a broken belt. Take the back off and find where the belt is located to see if broken. Depending on the washer they can be easy to fix
Jan 05, 2013 | Washing Machines
Whirlpool model #WFW9150W front load washer. Washer makes lots of noise when operating
If it sounds like a freight train in spin cycle most likely it is your bearings. If it makes a clunking noise during the wash cycle you have a broken support. The best way to tell is to spin the basket by hand and listen for the noise. Check to see if the basket is making circles and not ovals. Pull back the rubber seal and look signs of the basket rubbing against the outer plastic tubs. If is either one of these it is cheaper to buy a new washer than to fix it. Fixing it involves rebuilding the machine. If it only makes the noise when it starts to drain you need to check your pump for foreign objects.
Jul 12, 2011 | Whirlpool WFW9150W Front Load Washer
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Washer gw11us
If it makes it through the cycle from start to finish ,consider yourself a lucky one.If it breaks I don't recommend fixing this.
May 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Apr 15, 2008 | Washing Machines
Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
Jun 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Dec 07, 2006 | GE WBSE2090A Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
