Question about Sony VPL CS1 Multimedia Projector
Both the LAMP/COVER and FAN/TEMP indicator lights come on, not blinking
Have been using this projector for several years on the road. Unit has worked flawlessly. Suddenly both the LAMP/COVER and FAN/TEMP indicator lights came on, not blinking. Replaced bulb, worked fine ONCE, then, on next boot-up, same thing... both the LAMP/COVER and FAN/TEMP indicator lights came on, not blinking. I went through reset operation when bulb replaced, and have removed/replaced bulb again with same symptoms. Any help?
  • Anonymous Mar 26, 2014
    indication light temp,power and lamp light is on
  • 105 Answers
With both lights solid. according to the manual all it says is (there is an electrical failure inside the unit, please take to an authorized servicer). if you are able to do this yourself you will need the schematics and a voltmeter to start testing your voltages. your lamp is fine so dont waste your money replacing that anymore. if you would like the service manual send me an email to fixya@markservicepro.com.
Posted on Oct 30, 2007
Red power, blinking red temp
if the Lamp error and Temperature error lights are flashing red this means that there are two separate errors.
  • A flashing lamp light means the lamp failed to ignite. It could be a lamp driver problem or lamp failure. Replace the lamp to resolve the issue. If the issue is not resolved, then service the projector.
  • A flashing Temperature light signals a fan error. Turn the projector off and allow it to cool down. If the light is still flashing after the projector is turned back on, service the projector.
Goodluck..
Feb 25, 2008 | Hitachi CP-X250 Multimedia Projector
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
Lamp goes off and on.
This sounds more like a heat thing to me rather than a lamp problem. Is there any indication (blinking light?) when the unit shuts down? I would expect to see a temp light blinking or on.
Try cleaning the fan area and verify that the air filter is clean as well.
Update this with what you find.
Thanks,
Dan
May 03, 2010 | Sharp Notevision PG-M20XU Multimedia...
BLINKING TEMP LIGHT ON HP VP6110 PROJECTOR
All projectors are cooled by the use of a fan. The light chamber has its owned fan to extract the excessive heat generated by lamp. Check to see if this fan, close to the fan is operating.
Mar 23, 2009 | HP Digital Projector Vp6110 Multimedia...
BenQ MP612c projector has three orange flashing lights
you can go to the BenQ website and download a manual for your particular projector. It should tell you what the lights indicate.
Feb 01, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
Sony VLP-SC50 lamp shuts down and temp/fan light blinks
that means the fan is broken... say to call sony customer support. Probably gonna charge you an arm and a leg to fix it so im gonna try to nstall a new fam myself
Feb 03, 2008 | Sony VPL SC50 Multimedia Projector
Lamp will not strike error message
this can sometimes indicate either an overheating issue, a lamp service life problem, or that the cover to the lamp housing has not been secured properly.
Dec 14, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Wont start up
Pls clean the filters and check the lamp by opening the lamp cover. If lamp looks okay in all aspects then send the projector to any engineer to check the ballast unit of the lamp.
Viren
+919814903739
Nov 26, 2007 | Dell 1100MP Multimedia Projector
Sony VPL CS1 Multimedia Projector Logo
1,673 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
