Question about Vehicle Parts & Accessories
Windshield wiper won't retract
Wipers won't park
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 189 Answers
Either you have them on delay or you have to adjust them
Posted on Sep 09, 2014
2005 ford escape wiper and washer has no power. cant hear it engage when on but was working a week ago. how can i troubleshoot it and find the fuse
Hi Justin , Do you know what a SJB - smart junction box is and where it is located on you escape ?
Windshield Wiper Operation
The smart junction box (SJB) supplies power to the multifunction switch from the SJB fuse 25 (20A) when the ignition switch is in the ON or ACC position. The multifunction switch supplies power to the windshield wiper motor for the HIGH or LOW/INTERMITTENT input, depending on the multifunction switch position selected. The SJB also supplies power directly to the windshield wiper motor from fuse 25 (20A) when the ignition switch is in the ON or ACC position for RUN/PARK operation. When the multifunction switch is in the LOW, HIGH, or INTERMITTENT position, power is supplied to the windshield wiper motor, which moves the wipers off the park position. Once the wipers are off the park position, an internal switch in the windshield wiper motor switches to the run/park position which directs power to the wiper switch then back to the wiper motor. This maintains power to the windshield wiper motor to complete the wipe cycle. When the cycle is complete, the internal switch in the windshield wiper motor switches back to the park position. If the multifunction switch is in the LOW or HIGH position, power is supplied from the multifunction switch and another wipe cycle starts. If the multifunction switch is in the INTERMITTENT position, the windshield wipers remain parked until the internal relay in the multifunction switch supplies power to the windshield wiper motor. The internal relay supplies power after a time delay that is determined by the 1 of 9 intermittent switch settings.
Jan 08, 2017 | 2005 Ford Escape
2007 Pontiac g6 wipers stay in upright position
Hey Derek , here is how the wipers park position is suppose to work !
Windshield wiper motor park operation is controlled by the body control module (BCM) using an input from the park switch within the wiper motor assembly. The BCM monitors the windshield wiper motor park switch circuit to determine if the windshield wiper blades are at the bottom of the glass. The circuit will be pulled to ground by the wiper motor park switch while the windshield wiper motor is operating. When the wiper switch is turned to the OFF position while the wiper motor is somewhere in mid-cycle, the BCM will continue to operate the motor until the wipers reach the park position. If the ignition is turned OFF while the wipers are in mid-cycle, the wipers will stop immediately where they are. The BCM will park the wipers the next time the ignition is turned ON.
The wipers will not park when they are commanded ON and OFF with a scan tool. The BCM will park the wipers the next time the wiper switch is turned ON and OFF.
The BCM provides stall protection for the wiper motor by monitoring the park switch. If the park switch does not transition for 3 seconds while the wipers are operating, the BCM will assume that the wiper motor is stalled, and will de-energize the wiper relay until the wiper switch is cycled OFF and ON again.
Check for a voltage signal on the yellow wire at the wiper motor assembly , this is signal to the BCM ! If there is no signal you need to replace the windshield wiper motor assembly ? If there is a signal need to have Tech 2 scan tool hooked up to see if The BCM is the problem ! Relay #39 an #40 are the high an low wiper relays in the under hood fuse block ! Do you have a volt meter ,do you know how to do electrical testing ?
Sep 21, 2015 | Pontiac Cars & Trucks
2006 honda civic windsheild wiper won't park
For the Honda civic 2006, a 24 inch windshield wiper is needed for the passenger side and 28 inch windshield is needed for the driver side.------------------------------------------------------------------------
ELM 327 1.5V USB CAN-BUS Scanner
Apr 03, 2013 | 2006 Honda Civic Coupe
99 Suburban Windshield Wiper Issue.
It sounds to me as though both of the wipers have slipped. The operation of the wipers sounds fine except they do not park in the correct location. To fix this, start the wipers and then turn them off to ensure they think they are in the parked location. At the base of each wiper there is a small cover that can be easily removed with a small screwdriver. Underneath each cover you will see a nut. Loosen the nut somewhat and reposition each windshield wiper to the proper park location. Once done, tighten the nuts securely but do not over tighten, then reinstall the caps. Cycle your wipers on and off a few times to ensure the wipers park correctly. I have owned a lot of vehicles and ALL of my GM vehicles have had this problem.
Oct 19, 2017 | 1999 Chevrolet Suburban
I recently changed my wiper motor in my 2003 Hyandai Accent. Now the windshield wipers will not stop at the bottom. When I turn thw wipers on, it goes donw first then up then back and stops in the middle...
Remove the linkage from the wiper motor. Turn the wipers on then off. This will set the motor in the park position. Move the wipers by hand to there normal off position. Reinstall the linkage onto the wiper motor. The wipers should now park or stop in the correct position.
Sep 08, 2011 | 2003 Hyundai Accent
Windshield wipers won't cut off and I'm having trouble locating the fuse box to turn them off
The fuse panel is located behind the left hand side of the instrument panel. In your car, the Park switch appears to have failed ON it to park the wipers. the park switch is an integral part of the wiper motor assembly, so replacement would mean having to replace the wiper motor assembly as a unit ... good-day!!
Aug 13, 2011 | 1992 Ford Tempo
2000 Saturn LS, windshield wipers park in the middle of the windshield. How can I fix this?
The wipers are parking in the middle because the timing mechanism is off. Once they start doing this it seems to continue to happen so the 1st suggestion is to replace the wiper motor. If U don't want to spend the $ right now it's a pretty easy fix to reset the timing. Park the wipers & remove the wiper arms. Then remove the plastic cowling that covers the wiper motor & the motor assembly. Turn the wiper assembly over without turning the motor. Remove the nut on the arm of the motor. Repostion the arm pointing away from the closet wiper directly inline with the short arm. reassemble.
Oct 24, 2009 | 2000 Saturn Ls 4dr Sedan
Need to get a programmer dont know where its at
  • Windshield Wipers Continue to Run When Turn Signal and Windshield Wiper Switch Are Turned OFF
  • Damaged turn signal and windshield wiper switch .
  • Damaged windshield wiper motor .
  • Damaged windshield wiper control module.
Pin Number Circuit Circuit Function 1 57 (BK) Wiper Motor Ground (Park) 2 28 (BK/PK) Wiper Module to Wiper Motor (Park Switch) 3 65 (DG) Wiper Motor Power (Park Feed) 4 61 (Y/R) Wiper Motor Common (RUN) 5 56 (DB/O) Wiper Motor LO 6 58 (W) Wiper Motor HI
Windshield Wiper System The windshield wiper system consists of :
  • Windshield wiper motor (17508) (F-type).
  • Washer system.
  • Windshield wiper control module.
  • Turn signal and windshield wiper switch (13K359).
The windshield wiper control module is:
  • Located at the instrument panel fuse panel.
The windshield wiper motor is:
  • Attached to the cowl top extension (021A36) .
  • Connected to windshield wiper mounting arm and pivot shaft (17566) .
The turn signal and windshield wiper switch features a:
  • Rotary wiper switch.
  • Push type washer actuator.
OFF/Low/High Speed
  • Has a two-speed, permanent magnet, three brush electric windshield wiper motor .
  • The windshield wiper motor has a brush rigging that permits selection of low or high speed.
  • When the turn signal and windshield wiper switch is in the LO position, the common brush and the blue/orange wire brush are used, and the windshield wiper motor operates at low speed.
  • When the turn signal and windshield wiper switch is in the HI position, the common brush and the white wire brush are used.
  • In HI position, electric current will bypass a portion of the armature winding causing the windshield wiper motor to operate faster.
  • When the turn signal and windshield wiper switch is moved to the OFF position, the windshield wiper motor will continue at low speed until the park switch outer contacts open.
  • When the park switch contacts open, the windshield wiper motor stops in the park position.
Interval
When the turn signal and windshield wiper switch is in the interval position:
  • The wipers make single wipes separated by pauses.
  • The rotary switch is on the end of turn signal and windshield wiper switch .
  • The length of the pause can be set from approximately 1 to 17 seconds.
  • Length of pause decreases as the rotary switch is rotated away from off.
  • Length of pause increases as the rotary switch is rotated toward off.
While in the interval wiper mode:
  • It is normal to hear a slight click at the beginning of each on/pause cycle. NOTE: When using interval wipers, the first wipe may not occur until after a pause of up to 17 seconds.
May 27, 2009 | 1994 Ford Mustang
Windshield wipers
From your owners manual:
Fuse#11 30A , Wiper Run/Park
Relay, Wiper Hi/LO Relay, Windshield Wiper
Motor, Rear Washer Pump Relay
U will also need to check the relays if the fuse is ok, the relay, it is the underhood fuse box
Relay #202 — Front Wiper Run/Park Relay
Dec 18, 2008 | 2001 Lincoln Navigator
Vehicle Parts & Accessories Logo
47 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
