Question about Trend Micro InterScan Messaging Security Suite for SMTP 5.0 Full Version for PC
NONAMEFL ZIP attachment
I need the full zip code of 32080
Those numbers depend on the address. They usually designate a block, though sometimes a single number may be assigned to a building.
Dec 18, 2016 | Miscellaneous
My attachment is not showing up yahoo
In yahoo, the attachment shows up at the lower, left-hand side of the message window when complete. Be sure you're allowing the time required for it to upload before sending.
Also, there's a limit on size & type of attachments. If you're trying to send an ".exe" file (executable file which launches something when clicked)- you first must compress it as a .zip to send (for safety reasons). 7-Zip, from sourceforge, will do the trick. Once installed, right-click your file--> add to archive, name it, & change the type to ".zip" (most universal) format.
Now, try attaching.
Cheers!
May 06, 2014 | Computers & Internet
I need to know how to zip a file
hi,
select all your files.right click.compress files. done.rename your zip.
Feb 18, 2014 | Apple iBook G4 Mac Notebook
I can sign in to Hotmail, but I can't open any of the messages
Windows Live Hotmail allows users to view attachments within a Web browser or save them to the system's hard drive.
If Hotmail can't open an attachment, the problem lies with an incompatible file format or Hotmail's automatic blocking service.
You may need new software installed on your computer IE: adobe . direct x , zip for opening unfamiliar formats, while blocked files are permanently inaccessible from within Hotmail.
Accessing these files requires action by the sender or forwarding the file to a different email client.
Incompatible File Format
Occasionally a sender may attach a file that simply doesn't work with any software you have installed on the system.
Attempting to open the attachment will result in a "Windows cannot open this file" message or similar error display.
Many programs use very specific file formats that don't operate with most other software, such as Photoshop's PSD image files or Microsoft PowerPoint's PPT files.
Ask the sender to convert the file to a more widely compatible format, or install the appropriate software on the system to open the attachment.
Blocked Attachments
Hotmail blocks attachments it believes may contain unsafe or otherwise malicious code.
This includes any and all executable file types, including MSI, EXE, HTML, STC and COM files, along with many others.
Attachments blocked in this way result in a "Windows Live Hotmail has blocked some attachments" message when viewing the email.
While this service does block many real threats to system security, Hotmail may occasionally deny access to an item from a trusted sender.
Unfortunately, these files become permanently inaccessible once blocked by Hotmail, and accessing them requires using a workaround outside the Hotmail application.
Only attempt to access attachments you trust as safe.
Forward Workaround
While Hotmail cannot open blocked attachments, it allows users to forward the message with the blocked file still attached.
Send the file to a different email client, and open the attachment using that account instead.
Note other clients may have different security measures, but some will still block access to executable files and other potentially harmful data.
Compression Workaround
Ask the sender to package the attachment into a ZIP, RAR or other compressed file format before attaching.
Hotmail will not block any file type located inside a compressed archive.
Both Windows and OS X can create compressed ZIP files, and free utilities such as Zipeg and 7-Zip can create many other types of archives as well.
Some email clients, such as Gmail, will not allow users to send some file formats, even when packaged into an archive file.
Hope this helps
Nov 04, 2012 | Computers & Internet
How do I attach a photo to an email using Yahoo classic email?
compose new mail click on attach file >>browse for the file to be attached .. continue to mail it will attach the document
Apr 25, 2010 | Yahoo Mail
I can't send an Omniform attachment via Microsoft Outlook even if I convert the attachment to an HTML document.
I am not sure if this has been solved here but you can send the attachment as a zipped file. Right click on file. Choose send to. Choose zip file. Now attach zip file to email.
Jan 05, 2010 | Generic Memory Computers & Internet
Many people have trouble or are unable to retrieve my attachments because they are imbedded. Is there anyway of creating attachments that aren't imbedded? I frequently send .ai & .psa files fro my work...
Zip the attachments before adding
Also make sure the user receiving the attachment has a programme available that will let them view the attachment once extracted from the zip file.... if in doubt and there is a free viewer for that file type then add it to the zip archive if it is not too large > 1MB
Sep 28, 2009 | Computers & Internet
When i send an attachment on yahoo mail it says remove why is this ?
  • Compress the attachment file using the zip software and attach the file with yahoo. click here for zip sofware
  • yahoo will accept only some file format.
Hope this help
Feb 18, 2009 | Yahoo Mail
Iomega zip drive problem
I'm trying to re-install iomegaware zip 100 & it tells me it does not support windows 2000 so I need to update drivers. Can you please help me figure this out as I rely on my zip for backups. I have version 21.1.
thanks very much
Marlene
Dec 31, 2007 | Iomega (32453) External ZIP Drive
Trend Micro InterScan Messaging Security Suite for SMTP 5.0 Full Version for PC  Logo
272 people viewed this question
Top Trend Micro Computers & Internet Experts
esiapco428
esiapco428
Level 1 Expert
Are you a Trend Micro Computer and Internet Expert? Answer questions, earn points and help others
