Question about Electronics - Others
Speedometer showing high speed when going slow
Speedometer was working fine when parked 5 days later when i drove away i notice speedometer was showing 80 mph when i was doing 10 mph my trip was 200 miles and the odometer showed over 500 miles travelled.
Ticodude
  • 53 Answers
SOURCE: #5 cylinder misfire
I have a corolla and had #4 cylinder misfire also diagnosed at autozone. After changing the spark plugs, problem persisted, along with the same error code, so they recommended changing the spark plug wires, and that is what fixed it. I would have changed the rotor cap too, but was low on dough. Glad that was not the problem.
Posted on Dec 29, 2008
  • 99 Answers
SOURCE: speedometer works, but odometer/tripometer stopped working
speedomenter cable may be broke or speed gear may be bad
Posted on Jan 26, 2009
  • 186 Answers
SOURCE: odometer running to fast
Problem is in the guage cluster assy.The ODO is mechanical,serviced by replacing guage cluster.
Posted on May 13, 2009
  • 6 Answers
SOURCE: Odometer is not working
SOUNDS LIKE THE GAUGE CLUSTER IS BAD OR HAS A BAD GROUND
Posted on May 19, 2009
SOURCE: Speedometer not registering right speed.
replace a capacitor behind the panel (6.8uF 25V) with the new one.
Posted on Jun 11, 2009
I have a 1996 Honda Accord with 268k miles that sputters at the same timethe speedometer needle fluctuates wildly. But I do have a new Vehicle Speed Sensor. This typically only happens when the engin
I am no Honda expert, but a similar problem happened to my ex sister in-laws Ford Taurus. The speed odometer would jump around and it had trouble shifting (automatic transmission). After driving it I changed out the speed odometer sensor on the transmission and it's been fine ever since. I changed out the sensor because if the cars computer cannot tell how fast the car is traveling then fail safes in place go into effect and the computer will do it's best to keep the cars rpm's down based on the speed indicator and not let it shift or shift properly either. If it's getting false speeds then it will shut down the motor when the speed gets to high and allow it to run as the speeds fall (jumping speed odometer needle). It effects the transmission shift points also. It will either shift erratically or not shift out of say 2nd gear, so that the cars engine can't get damaged based on what signal the speed sensor is sending the computer.
Jan 23, 2014 | 1996 Honda Accord
Stuck in 4hi and hear clicking noise under hood
this all prove that engine and transmission co-ordination seems to be poor.
  1. check accelerator sensor.
  2. " accelerator pedal--transmission ctrl liver.
  3. " transmission oil level.
  4. " proper grade of transmission oil.
  5. " pressure ctrl walls
Mar 04, 2012 | 1995 Chevrolet Blazer
The mileageclock do not work and stayin one
I would check for a broken or loose wire at the speedometer sensor on the transmission, or a bad speedometer sensor (VSS. Vehicle speed sensor).
Feb 28, 2010 | 2001 Chrysler PT Cruiser
1994 honda prelude vtec speedometer tach problem
Possible speed sensor. I know the speed sensors are a problem with hondas. A new speed sensor is about $200 and can be easily replaced. It bolts to the top of the transmission on the firewall side. Do NOT buy an e-bay one. They are only about $30 but are junk
Jul 07, 2009 | 1994 Honda Prelude
Electronics - Others Logo
27 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
