Question about Intertherm P3RA-048K Air Conditioner
No water in the copper pipes in our baseboard
Our house has 8 Intertherm baseboard heaters. All are pretty old. There appears to be no water in the copper pipes in our baseboard heaters. I'm of course trying to increase the efficiency of these heaters. Can we just refill it or does it use something else other than water.
''Intertherm hot water select'' baseboard heater. Model: EBH2000
By the way the model in the product field is wrong. It wouldn't let me enter in the model above so I just picked the air conditioner.
    Sergeant:
  • 340 Answers
Water is fine. Tom
Posted on Jun 18, 2009
Original Intertherm heaters were filled with 80% water 20% antifreeze.
Posted on Jan 21, 2010
When I run hot water for the tub, it has a brown tint
10 year old homes today usually do not have galvanized pipe. They have copper or pex plastic pipe. These do not rust.
Is rusty water on both hot and cold line, or just hot line?
Just hot line, then check anode rod and flush tank:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
Are you on water well? Well casing can get rusted. Water can have minerals. Call local water well service and describe problem in detail.
Are you on city water or mudd district water? Is pipe coming into house made of galvanized? Look inside meter box or look at pipe coming into house. Sometimes the city water line at end of run can get filled with sediments that will discolor water. Have water company flush the city water line.
May 04, 2013 | Rheem Water Heaters
I replaced a 15 year old Rheem 40 gallon electric water heater with the same - a Rheem heater. After I replaced the old one, I was surprised that there was hardly any sediment build-up at the bottom of the...
These are interior metals, similar like rock used in a sauna, to help keep water hot longer. Here is somethings to check out.
Hello, dave
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about hot waterheaters and possibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/water-heater.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Dec 06, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a hotpoint hot water heater it's about 6 years old. When I turn the hot water on it runs very slowly the water pressure is very low and it's like this throughout the house how do I fix this problem...
You have clog in the water line.
Since all hot water pipes are involved, clog is probably near water heater.
Buy pressure gauge at hardware store that threads onto hose connection.
Brady BTG 100 at Amazon
Picture of gauge
Check outdoor pressure for baseline pressure in your home.
Turn off electricity to hot water heater for an hour or two so there is not scalding water.
Open drain valve on water heater to see if water heater is clogged with sediment.
http://waterheatertimer.org/Water-heater-will-not-drain.html
Put pressure gauge on drain valve and compare with outside pressure.
Open hot water spigot on bathtub and see if tank pressure drops ... if tank pressure drops significantly with bathtub spigot on, then clog is on incoming cold water before tank, and could be on outgoing hot water pipes too.
If tank pressure stays about the same, then clog is on outgoing hot water pipes.
Clog can be sediment caught in cold water shut off valve located above tank. Open and close valve and test pressure again. Take apart incoming cold water pipes above tank and check for sediment. Replace valve. Look at condition of cold water nipple on top of tank.
Sediment caught at hot water elbow near tank.
Sediment can fill up old pipes. Take apart hot water pipes above water heater and see condition.
Look at condition of hot water nipple on top of tank.
You may have to take apart pipes up to first or second elbow.
Pipes can decay at joint where copper pipe connects to galvanized pipe. Check for copper to galvanized connections on cold or hot pipes and replace section of galvanized pipe. Copper pipe will probably be good, the galvanized pipe will deteriorate. Replace copper-to-galvanized joint with 3/4" non-conducting union from hardware store
Dec 06, 2010 | Water Heaters
New rad installation
Baseboard such as Slant-fin is made with a bracket that will allow you to run a 3/4" dia copper pipe back over the top of the finned area as a return pipe giving you a supply and a return on the same side. Both the finned pipe and the housing can be cut to any length and come in a 3' section from the factory.
Jan 20, 2010 | Marley Electric Hydronic Baseboard Heater,...
EMPIRE MDL 215 VENTID NOT HOT ENOUGH
Sal,
the gas pressure test should be done. Propane should have an outlet(heater side of the regulator)of 7 inches of water column. the inlet side has to be higher than that to supply it the proper pressure. Also the heater should have been converted to LP with proper orfices and springs
Dec 13, 2009 | Rinnai RHFE-556WTA Direct Vent Heater NG...
Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Dec 31, 2008 | Rheem 81VP6S/430126 Water Heater
Can't find replacement parts
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Oct 22, 2008 | Fahrenheat Electric Convector Baseboard...
I have a hot water heater,for some reason it started leaking were the cold water goes in, it was leaking were the round white cover that cover the whole that the connection goes in the tank.Can you tell me...
To find out you need to cut away the white cover to see where the leak is coming from. This white cover is just cosmetic.
If the leak is on the connection where the supply line comes in, then is usually can be fixed.
If the leak is on the metal of the tank below the connection, then there is no fixing it. The metal just below the white plastic is part of the tank.
If the leak is on the connection, it can all be replaced. I recommend replacing the nipple going into the water heater with a 3/4" x 3" brass nipple. From there I recommend using a 3/4" x 3/4" x 18"-24" copper water heater flex. This assuming that you have a flex line installed now. If not I still recommend the brass nipple and the copper flex, but you can get a 3/4" Sharkbite Male adapter to adapt to copper pipe. (Use this fitting instead of having to solder. This fitting is found at Home Depot and Lowes. Be sure not to have any burrs on the copper pipe, because Sharkbites use an O'ring which can be damaged by any burrs.)
If you have a different plumbing installation, please contact me.
Please Rate this solution
Jun 18, 2008 | Hatco C 24 Compact Electric Booster Water...
Intertherm P3RA-048K Air Conditioner Logo
578 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
