Question about Cell Phones
Fender Vibrolux Reverb SR2035 guitar amp
Can't seem to find a schematic for this solid state fender amplifier. Do you have one availiable?
SOURCE: fender reverb mod both channels
This is a pretty simple mod which I have performed 3 times now with great success and even did it last night to my own super reverb. The mod is detailed and well explained in the latest edition of the tube Amp Book by Aspen Pittman of Groove Tubes!
Posted on Dec 05, 2008
  • 10 Answers
SOURCE: Fender Stage 100 dsp, solid state amp volume (or power) problem
The Deluxe may have more efficient speakers....which would cause it to sound louder. Also, the EQ settings could play a part in this. If the EQ's aren't set the same there could be a noticeable difference in sound.....usually the mids can have quite an effect on overall amp volume....
Posted on Aug 04, 2009
  • 1138 Answers
SOURCE: need instruction manual for a Fender 15g combo
Here is the page you need:http://www.fender.com/support/amplifier_schematics.php Look under hard copy archives if you can't find it in the newer section. I emailed them at cosumerrelations@fender.com for a manual and schematics for a Fender Sidekick 10 and they emailed me one right away and were really nice. Please let me know if this helps.
Posted on Nov 20, 2009
  • 506 Answers
SOURCE: Reverb problem
I highly doubt the reverb pan is dead, there are TL072 opamps on the input and output of the Reverb pan. Check those out. You can get the schematic from fenders website here. U6A and U6B are what you are looking for.
http://www.fender.com/support/amp_schematics/pdfs/Roc_Pro_1000_Schematic_B12.pdf
Posted on Dec 28, 2009
  • 57 Answers
SOURCE: Fix Reverb unit on Fender Hot-Rod Deluxe Amp
Could have broken a spring in the reverb tank, or a wire connecting it to the amp, or the reverb driver tube, or a few other things, but those are the most likely in this situation. Thats what I'd check first. Give it a little slap and if it vibrates like normal, your spring is probably ok, you can still open it up and double check though. Check your wires. Then pull your reverb driver tube and replace it. If that doesn't work, it is probably in the circuit somewhere, and you should not work on your amp unless you know what you are doing. They store large amounts of electicity in the caps and they can kill you.
Posted on Apr 24, 2010
No reverb on my fender ps 160 Vocal amplifier
Here is a link to the schematic drawing
http://www.prowessamplifiers.com/schematics/fender/ps160.pdf
items to check are
1-the footswitch and plug
2-the reverb unit ,usually found at the bottom of the box
3-the reverb unit is plugged in to the amp
4-V6 a 7025 valve
5- the reverb switch is in the on position
Hope this helps
Len
Oct 14, 2014 | Music
What year would a Fender Princeton Reverb with serial number A08011 be? Thanks!
Deciding the date depends on what part of the amp your serial number is.
This site might help:
http://www.fender.com/support/articles/amplifier-product-dating
Dec 17, 2011 | Fender 65 Princeton Reverb Electric Guitar...
The reverb channel on my fender twin feeds back
Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
May 10, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
Sometimes the reverb works, then next day it dont.i have a 1999fender hot rod deluxe
Fender Amplifiers are notorious for their reliability issues.However, I'm sure that amp will sound sweet once you get everything working again!
The problem is likely your "tank". The tank contains the springs which create reverb as the guitar's signal is sent through them. A broken spring could be causing your problem.
Luckily, any of the larger music stores should have them avalible.
Good Luck!
-Sheeves
Mar 02, 2011 | Fender Hot Rod Deluxe Guitar Combo...
Fender vibrolux. Very (loooud) loud hum/buzz All tubes but the 6l6's removed. History: bought this amp as a repair project. replaced all caps. originaly the amp was quiet but but had very little volume...
Here is the schematic:
http://elektrotanya.com/fender_vibrolux_6g11_schem.pdf/download.html
Check the quality of the DC bias as being free of ripple.across teh 25 mfd/50v cap filtering the bias.
If much ripple there, replace the cap. Also the .05 bypass on the swinger of the intensity control.
This should be an easy fix, but you might need an oscilloscope to diagnose it quickly... or just parallel caps across these to see if it kills the hum.
The main high voltage filter caps are also suspect as well as the bypass of power to the ealier inverter stage a 16mfd/450v
There are lethal voltages in this so use great caution when troubleshooting... the caps hold a nasty charge.
Feb 06, 2011 | Fender Custom Vibrolux Reverb Tube...
How do i connect the boss gt 10 to a fender blues deluxe amp and bypass the amps preamp
You can plug the output of the gt10 into the "power amp in" jack of the Fender. This bypasses the preamps in the Fender but uses a buffer amps in the Fender to drive the power amp. Please note that the reverb is STILL in the circuit when you do this. You can turn the reverb to zero if you wish to disable it.
Jun 09, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Reverb problem
Dec 26, 2009 | Music
Hot Rod Deville, reverb squeal...
Here is an article that might help:http://www.guitarplayer.com/article/reverb-troubleshooting/jun-09/97165 Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Hot_Rod_DeVille_Schematic.pdf Check to see if someone hasn't reversed the input and output cables at the reverb tank. Then troubleshoot the reverb section .
Aug 28, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
