Question about Echo 21.2 cc Gas Stick Edger PE-225
Just stick edger will run but not stay running
Stars up but in bogs down
3 Suggested Answers
  • 148 Answers
SOURCE: Echo leaf blower is bogging down at full throttle,
Have you tried cleaning the carb?
Posted on Aug 24, 2009
Testimonial: "Thanks for the suggestion, that sounds like what it may be. "
Healeyman
  • 1198 Answers
SOURCE: echo hedger bogs down after running for a few minutes
Keep a can of WD 40 handy, spray the workings regularly. Shrubbery is sticky.
Posted on Nov 27, 2013
Homelite gas edger cuts off after running about 10-15 seconds
The fact that is runs slightly longer on full choke may point still to a fuelling issue.. Does it actually Rev in those 10 seconds or does it just want to bog down and stall.?
May 18, 2016 | Homelite Garden
My stihl fs 56 rc was running great then just started bogging down and wont run right at all
Bogging issues tend to be fuel related. Check the fuel system from the filter to the carb, check the carb isn't blocked, check the exhaust is clear so that the gasses can escape.
Sep 12, 2015 | Stihl Garden
Ariens lawn edger bogs down and stall when the blade is engaged
sounds like you need to return it and get replaced should be warrantied sounds like the bearings are seizing up on the blade shaft .
Jul 26, 2015 | Ariens Wheeled Edger - 986103
Craftman 29cc weed trimmer does not stay on
Start by adjusting your carb 1 full turn out on the low and high side. This should start and let it run. Then if it bogs down while accelerating, turn the low side out another quarter to half turn. You could also have fuel line, fuel filter or other fuel issues.
Oct 04, 2014 | Garden
Poulan p2500 carb adjustment
Carb not set correctly. Screw down idle an fast run screws an then reset. Sometimes fuel gets clogged an needs adjusting
Jul 04, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
Yamaha f50 outboard motor
check fuel pump diaphrams ! primer bulb not sticking !
Jun 19, 2013 | Boating
Husquvarna weedeater starts and runs fine but bogs down when flipped to edge.
Check the fuel tank vent, and fuel lines for air leaks. could also be a problem with carb diaphram.
Jun 12, 2012 | Husqvarna Garden
MY RYOBI S430 WITH THE EGDE ATTCHMENT WILL NOT RUN UP TO FULL SPEED. IT BOGS DOWN AND STALLS. RUNS FINE WITH THE WEED EATER ATTACHMENT. THANKS RON
too much drag on the edger, try putting some oil or lubricant spray where the edger spins on the attachment.
May 03, 2010 | Garden
Engine starts and idles, give throttle, revs, bogs, revs, bogs
Check for a loose connection by the carb. Sounds like its sucking air.
Feb 25, 2010 | Garden
1986 190e mercedes done 240kms
Suspect a failing fuel pump might be the cause
Aug 23, 2008 | 1986 Mercedes-Benz 190
Echo 21.2 cc Gas Stick Edger PE-225 Logo
50 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
