Verifone fd55 Changing ip on a fd55
How do install new tape in a Verifone FD55 model?
you can simply place paper in cradle, making sure the end of the paper has about 3 inch "tail" that you will pull towards you, then close the door, no feeding needed.
Mar 05, 2014 | VeriFone Retail Supplies
Need to set a VeriFone Vx510 to Dial Primary from the start.
Verifone programming is different between countries and even between versions. In New Zealand the setting for internet or dial comms is in UTILITY/COMM CHANNEL. It will have a setting for IP, or DIAL, or IP/DIAL if using both where it will try internet and then use the dial if the internet is down.
Jan 18, 2014 | VeriFone VX510
I need a VeriFone Vx510 to start with Dial Primary first.
Verifone 3730 vx 510
Hello all, I have a pos Verifone Vx510I configured the IP, DNS and Gateway, I did a ping, and it worked.
I selected Troubleshooting and verify all OK responses are received.
When I try use the machine show me the message "Connection Failed".
When I try download TCP show me the message :Connection to Host Failed
*ZP=08447016306:0Comms Failure -56Help me please !!Thank youCoil McCoy
Jun 24, 2012 | VeriFone Omni 3700
How i can change the network settings on my verifone vx510 like IP, gateway etc?
1. Press the * key twice.
2. Press F2.
3. Press the right purple button by "Reports".
4. Press F2.
Mar 26, 2011 | VeriFone VX510
My Verifone vx670 needs to release and reestablish it's IP address frequently for wireless communications and after taking a vacation I forgot the key combinations to perform it!
I also need to change the network settings on my Verifone VX 670 as i have recently installed a new wifi connection. Any help would be appreciated!
Aug 31, 2010 | VeriFone VX570 Credit Card Terminal (Dual...
How do I place a decimal point with Vx570 Verifone
you have to press the #1 key and then the alpha key till the decimal point appears.
Mar 20, 2009 | VeriFone Omni 3700
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
