Question about Hoover S3670 Bagged Canister Vacuum
Power shows low power will not go up
My roomba wakes up in the middle of the night and makes wired noises
Is this a Roomba with, 1. low power, 2. one that had low power, but is now charged up and ready to go or 3. did your power go off briefly the night and when it came back on Roomba got a power surge and "responded". You might want to try unplugging Roomba when not charging or being used. I did this but it seemed to affect how long by Roomba could run later between battery recharges.
Jun 14, 2014 | iRobot Roomba Scheduler 4230 Bagless...
Its showing full battery then after 5minutes showing low battery...
You have a nearly-failed battery.
You'll need to replace your battery as soon as possible, or (like everyone does) use your laptop
while plugged into the wall outlet, because modern battery technology is so substandard, and
after 6 months of use, everyone's laptop battery goes marginal - just as yours has.
Sep 19, 2011 | Vacuums
Our Easy-Flo built in vacuum system will not turn off, even when the hose is disconnected. We have to turn it off manually. Could it be a short in one of the wall outlets causing this?
Some models have an on/off switch on the power unit itself. This switch is used to turn your power unit on when you are right at the machine.
If there is no switch on the power unit, unplug your power unit from the wall socket, look for two low voltage wires coming out of the power unit. These two low voltage wires are usually either attached with terminals or are tied to two wires coming out with plastic screw on wire caps. Disconnect the 2 low voltage wires. Plug your power unit back in. If the power unit does not come back on then yes, the problem is most likely a short in the outlet wiring. If the power unit still comes on with the 2 low voltage wires unattached, then the problem is in the internal circuitry of the power unit, usually a relay or some units have a circuit board with relay, circuit breaker and other components on it. The relay or circuit board will have to be replaced.
It's a little difficult to check for a short if you have multiple outlets, but if you've recently done some renovations you might start checking in that area.
May 19, 2010 | Easy Flo EF1400 Central System Vacuum
Nutone Scovill 350 will only turn off if unplugged
Some units have an on/off switch on the power unit itself. Check to make sure that is not turned on. Unplug your power unit and remove the 2 low voltage wires (not the power cord itself) . The low voltage wires start at the unit and run throught your home and attach to each hose inlet. They are usually attached to the unit by simple wire terminals or wire capped to small wires coming out. Just unlug the terminals or unscrew the wire caps and pull the connections apart. Plug your machine back in. If it still comes on the problem is the relay or circuit board/switch/ relay assembly inside the unit. If it doesn't come on with the low voltage wires unattached then you may have two wires touching somewhere in the low voltage wiring.
May 14, 2010 | Broan-NuTone CV353 Central Vacuum
My easy flo built in system wont turn on when the
If there is a switch on your hose, it may be broken.
Your system powers on from the inlets via two low voltage wires that run from the inlets to the switch/relay at the power unit. Each inlet has 2 spring loaded pins attached to the low voltage wires. In the photo below you should see these pins at the bottom of the opening, just above the door hinge. The receptacle at the top of the inlet in this photo supplies 110 volts to power your power nozzle. Not all inlets have this option, but if yours does, exercise extreme caution. Your hose must have a completely metal end or if it is a plastic end, it must have a metal band in order to short the 2 low voltage wires together to trigger the switch.
You can manually short the two low voltage pins together by using a metal pipe or needle nose pliers, just touch both pins at the same time. CAUTION: stay away from the 110 volt receptacle if present.
If your system powers on with this manual method then it would seem that the problem is in your hose.
If your system does not power on; your low voltage wires may be disconnected from the power unit or disconnected somewhere else . It's also possible that you have a bad circuit/controller board in the power unit.
May 11, 2010 | Easy Flo EF1400 Central System Vacuum
Will not turn off when hose is pulled out of wall
Jan 26, 2010 | Broan-NuTone CV450 Central Bagged Central...
Central vac won't turn off unless we unplug
Jul 18, 2009 | Broan-NuTone CV350 Central Vacuum
Power to operate beater bar
I am taking ashot at providing you with enough information that you will be able to work thru your problem with it.Here is a link to a standard installation kit http://www.thinkvacuums.com/instructionas.pdf
and this one
http://www.thinkvacuums.com/easyflo/install_wo.htm
If I understand your question, the two low voltage terminals should be shorted together in order to activate the 120VAC to the brush motor. As rge drawing indictaes, you may also press in the two terminals at the vacuum wall receptacle to short the low voltage circuit .. to activate the 120VAC to the motor. If you are measuring across the terminals and see 2.3 volts ..than that may be normal but try measuriung from each terminal to ground and see what you get.. I believe the low voltage circuuitry is 24VAC... Try these installation documents to see if they help you solve your problem.. Hope this helps..
Sep 29, 2008 | Easy Flo EF1600 Central System Vacuum
Scooba 5800 Power button Red Blinking (Continued)
As for which one has the problem, I would say it has to be the battery. Rechargeable batteries of all types are known to have similar characteristics, one of which is discharging the batteries to maintain good rechargeablility. At least one person has demonstrated this for the Scooba battery in the roombareview.com forums when he brought a "dead" battery back to life. He allowed the battery to slowly and completely discharge using a 12-volt automobile bulb, followed by recharging the battery on the Scooba external charger. This procedure brought his "dead" battery back to a full charge! However, other forum members have reported that many have experienced problems with Scooba battery life, and that as a consequence of this iRobot will replace your battery if you call them and report a short-life battery problem. You can contact iRobot at (800) 727-9077 if you would like to report a battery problem and request a replacement.
Aug 07, 2007 | iRobot 5800 Scooba Vacuum
Hoover S3670 Bagged Canister Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
