Question about Behringer 1202 Small Format Mixers
POWER SUPPLY PSU6-UL does not fit xenyx 1202 fx
  • Behringer Master
  • 3,368 Answers
That is what is connected to mine and it works great.
Posted on Nov 27, 2014
How dso I connect a seperate mixer to a Behringer B215D powered speaker
Use the two balanced outputs, intot he inputs on the back of the speaker, 1/4 inch jack should fit.
Alternativly you can do the same via xlr, for a balanced connection.
Jul 28, 2014 | Behringer Xenyx 1202 12-input 2-bus Mixer...
Power plug gets hot
It should be WARM, but definitely NOT HOT. More than likely, the unit may have a faulty transformer. Best to swap it out or replace it.
Apr 01, 2014 | Behringer XENyX 1202 FX Bundle
1202 fx phantom power swith will not stay engaged
The mechanical push on - push off latching mechanism may have broken. Probably the switch will have to be replaced.
Sep 02, 2012 | Behringer Xenyx 1202fx Mixer 12 Input 2...
I have a Behringer xenyx 1202 fx. I get static when I turn up the main fx to main control. I've had the unit for a year working fine until now.
Sounds very much like the control knob is dirty, needs a good cleaning!
Sometimes just giving the knob a good exercising (turn it up and down quickly a few times) can help it.
Some cleaners can leave behind a residue and make it worse, so ask at an amp repair place what product is best to use.
Hope this helps!
Jul 13, 2011 | Behringer XENyX 1202 FX Bundle
Have a Behringer 1202 Xenyx FX, balanced cable into a new windows 7 PC and keep getting hiss. When I raise the gain, mic or master volume the hiss is more awful. my internet broadcasts sound awful. what am...
You are running your balanced cable into a windows 7 PC? What interface are you using... not the line input on the PC I hope as it is NOT balanced... it is Stereo input with UNBALANCED input. If you tie the mixer using a balanced to 1/8 inch balanced connector you will get plenty of hiss since you are driving the stereo channels oppositely. For high quality, get a good audio interface that runs on the USB of the PC. If you can tolerate a bit of noise but wire it correctly, then you will need to use two UNBALANCED lines out of the mixer for L and R and merge them to a stereo 1/8 inch plug for the PC.
Jul 10, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
Can I use a footswitch for the reverb, to allow me to switch it off when talking ON MY Behringer Xenyx 1202 FX
Sorry, the Xenyx1202FX does not have a footswitch input. I would suggest if this function is needed to use an external FX unit which has a footswitch input.
Apr 26, 2011 | Behringer Xenyx 1202 12-input 2-bus Mixer...
Hi all i own a behringer XENYX 802 audio mixer. this device is powered by a power supply that as input to the mixer gives 18,5 x2 Ac, 150ma. i would like to know in which point of the circuit i can...
You would need TWO DC supplies as they use AC so they can create both a plus and minus 15 volt power source to run the internal op amps.
Here is a schematic for the 1202 which has same power supply configuration as the 802.
http://elektrotanya.com/behringer_xenyx_1202.pdf/download.html
Scroll down to the little link "Get Manual" and download the service manual and schematic. You will find the power input in the upper left corner of page 5.
Mar 29, 2011 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Behringer xenyx 2442fx : I need to know the correct voltages out of power-supply. Mixer has been seen by a previous tech and now FX area and mixer level leds are off (I've been a user of this mixer...
You should find pwer supply voltages of +/- 15 volts going to most of the op-amps.
You should find 48 volts for the phantom power source.
You should find 5 volts for the FX DSP or any other logic circuits.
You should find a +12 volt.
Here is a manual close to your unit (yours is an expansion of it):
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Feb 13, 2011 | Behringer XENYX 2442FX Mixer
Do I need to connect the Xenyx 1202 to an amp?
If you are the only person listening, you can use headphones with the headphone jack. Otherwise you will have to use some sort of amplification and speakers,e.g. P.A., stereo etc. I'm using a Xenyx 1222 FX and am quite happy with it.
Mar 22, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Behringer 1202 Small Format Mixers Logo
124 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
