Question about Microwave Ovens
Kenmore mfl39431005 carousel quit turning. no bad sounds
Sharp Carousel Convection microwave
Are there any display lights?
If not check your house circuit breaker. Check main
Fuse inside microwave. If fuse is blown check damper diode and HV capcitor, magnatron.
Dec 28, 2014 | Microwave Ovens
Sharp Carousel R-7A85 Won't Turn On
Yes! but the fuse went for a reason, the problem could be a bad door switch to a more serious problem.
May 29, 2012 | Sharp R-7A85 Microwave Oven
Magic Chef MCO160UQ Carousel turning slowly
The turnable motor is going, the buzzing indicates the magnetron is about to fail. I suggest using the microwave oven until it dies and replace it, not cost effective to repair.
Apr 14, 2012 | Magic Chef MCO160UQ Microwave Oven
The carousel turns but no light comes on inside, not is there any display light. Nothing works but the carousel. Thanks
That sounds like there is more than one fault, but maybe not. I suggest you get an appliance engineer in to take a look at it.
Jan 05, 2011 | Sharp R-820B Convection/Microwave Oven
Can i still use microwave if carousel does not turn but still heats food
You can but you may have uneven or hot and cold spots present in whatever you are heating. Sounds like the carousel motor has failed, those are replaceable. Good luck !
Jan 12, 2010 | Westpoint TV-201 Microwave Oven
How do you turn the carousel on/off on a Kenmore Microwave Oven model: 5658932580
Look at the owner's manual of similar Kenmore models there does not seem to be a setting that allows you to turn off the turntable. However if your microwave (sorry but I couldn't find your exact model number online) has the time of carousel that has a lift out glass plate with a notch (hub) in the center of the bottom side then you effectively turn of the carousel my removing this glass plate. (see pg 4 of the manual - above link) You can place a normal microwave safe plate in the microwave in it's place. Make sure to leave the rollers in place...just remove the turntable.
Nov 08, 2009 | Microwave Ovens
Carousel stopped turning
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
Dec 05, 2008 | Kenmore 63682 / 63684 / 63689 Microwave...
CAROUSEL STOPPED TURNING
Turntable motor req,Or drive shaft on top of this.
Oct 07, 2008 | Sharp R-1480 Microwave Oven
Microwave oven carousel won't turn
This may be a bad carousel motor problem. If it is, this is an easy problem to fix and rather inexpensive. Please provide me with the make and model number of the your microwave and I will attempt to locate a part number and price for you. I can also provide you will step by step instructions on how to repair. I hope this encouraging for you. Please post back with your information.
Jan 17, 2008 | Microwave Ovens
Turntable turns, but in a constant jerking motion. The plate ring turns free so there is no binding.
It sounds like your turntable motor may be going bad. It is located UNDER the carousel and easy to get to by removing a few screws from the bottom of the oven. You can try running the oven without the carousel tray and watch the spindle to see if you can detect the same jerking motion. This would confirm the motor has a problem. If the spindle runs smoothly with no weight on it, but begins to jerk with the carousel placed back on it, the motor could still be bad, but you may also have a spindle that is slipping. In either case, replacing both would probably be a good idea just to be sure. Make sure you place a glass of water on one corner of the oven. It's not recommended to run a microwave oven empty. If you determine the motor is defective and want to replace it, make sure you unplug the oven and remove the bottom panel of the oven. There should be a couple of wires connected to the motor and the spindle just pops off from the inside of the oven cavity. It's a fairly simple repair job and will run about $30-$40. Let me know if this helps.
Jul 30, 2007 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
