Question about Johnson Minn Kota Mk 25 & Mk 35 On Board Maintainersstyle: Mk 35
Batteries 1 and 2 will charge fully, but battery 3 will not fully charge
How do i determine if theirs a problem in the charger, the battery, or the wiring? ive checked all the wires and have a good connection on all 3 batteries, also i can have the right amount of current running to each. When i check each battery, they are all reading atleast 12 volts. But the charger for #3 battery remains at "charging" mode. and when i try to crank up the motor, it sounds like their is no power going to it to start it!
  • Johnson Master
  • 3,497 Answers
By reading this.. I am assuming #3 is the crank battery....
Try this.. (from experience) remove all wires (or big terminals) from the battery and see how that works.. I have a 3 bank and use a stand alone charger!! Works BETTER!!!
Posted on Jun 06, 2017
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Tip
How to Wire On-Board Marine Battery Chargers
Battery chargers are wired into a boat's electrical system. Wiring the charger to a battery switch permits the charging of the individual batteries or battery banks. The switch can be configured to charge both batteries or battery banks at once. Mounting the charger in the vessel keeps the charger where it will do the most good--connected to the batteries. This is useful if you are stuck with low batteries and need a recharge. Power from a generator, shore power or even AC power from another vessel can be used to get you going again
Instructions Things You'll Need:
Battery charger
Battery switch
Battery cable (sized)
Cable cutters
Razor knife
Battery terminal lugs
Lug crimper
Terminal kit
Terminal crimper
Hammer
Step 1
Mount the battery switch with the mounting kit provided by the manufacturer. The switch should be accessible but close to the battery or battery banks.
Step 2
Mount the battery charger in a location that will be accessible but protected from the elements. Mount the charger close to the battery switch to reduce the size of the charger leads.
Step 3
Connect the battery cables to the battery switch. Mount the battery cables onto their corresponding terminal studs on the battery switch.
Step 4
Lay out the battery positive cable from the charger to the switch and cut it to length with the cable cutters. Strip 3/4 inch of insulation from the cable ends with a razor knife. Splice the cable to the hot wire from the charger with a **** connector and the terminal crimper. Crimp a terminal lug onto the battery end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery switch positive output terminal.
Step 5
Lay out a battery cable from the charger to the battery negative terminal block. Cut the cable to length and strip 3/4 inch of insulation from the ends with a razor knife. Connect the battery negative cable to the charger negative power lead with a ****-splice and the terminal crimpers. Crimp a terminal lug onto the terminal block end of the cable with the lug crimper and a hammer. Connect the terminal lug at the battery negative terminal block post.
Tips & Warnings
Set the switch to "1," "2" or "both" to charge battery bank 1, bank 2 or both batteries at once.
on Jan 07, 2010 | Mercedes-Benz C230 Cars & Trucks
I bought a Ryobi 12V drill w/ lithium charger. Green light on charger never went solid....continues to blink & fade. Does this mean its in the energy saving mode? Is it fully charged?
How long have you left battery on charger? It will take about 3 1/2 hrs to fully charge. t is probably not a good idea to leave the battery in the charger for long periods of time though, so once it is fully charged put it back in the drill. When fully charged the green led will turn solid. This link will have more info on charger and battery.
http://powertool.manualsonline.com/manuals/mfg/ryobi/130155001.html?p=2 C
Apr 19, 2017 | Ryobi Drills
My camera not comming on
There are (2) common (non-terminal) issues that cause this problem.
1) the contacts inside the camera have become oxidized...., using the eraser on the end of a pencil..., rub (clean) the contacts inside the cameras battery compartment.
2) Modern Li-Ion batteries often last only (3) years...,(if you have good ones)...., so what happens is that as the batteries reach the end of their life span they quite often will work one day and not the next (but show that they are fully charged). Thus if you only have the (1) battery, you will not know if it is the battery, the charger or the camera. Go to your local camera store (with your camera & battery) and see if they are willing to put a new battery in your camera..., if it powers up it's your battery or charger. ask if they will then try to charge your old battery on their charger for 1/2 an hour..., this is enough of a charge to find out if your camera will turn on using the old battery.
Now you must ask yourself, if I need to purchase a new battery of charger..., is it worth it.
Sep 24, 2014 | Nikon Gorilla Pod Camera Tripod For...
1984 honda shadow vt500 no power
Probably Battery is too weak to turn over. Use a trickle/maintenance charger to charge or try a new or borrowed good battery. Dont use a car charger on more than 2 amp setting it will cook/destroy the battery.
Mar 23, 2012 | Motorcycles
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
I have a blue jet 3 ultra n i just put 2 new batterys on it and all it will do is flash a red light in the top left corner of the battery light on the joy stick and the horn works but will not move what...
Check your battery wiring on the Jet the wires from the circuit breaker need to connect the positive of the front battery to the negative of the rear battery and the other wires connected to the positive of the rear battery and negative of the front battery putting the batteries in series to generate 24+ volts. If you have a voltmeter before you check the wiring set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. If your batteries are wired correctly you should be reading 27+ volts without the charger plugged in and your batteries fully charged. If you are only reading 12 volts then the wiring is wrong and needs to be fixed. Leaving the voltmeter in the charger port plug in your charger and you should be reading 27 -30+ volts at the charger port anything less than 24 volts indicates your charger is not charging Hope this helps
May 22, 2011 | Jet 3 Ultra Power Chair
Included in my Ryobi printed instructions are the statements: 1-"Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode. 2-"To obtain the longest...
Any battery left in a charger is still hooked up to a circuit. Depending on the charger this can mean a slow discharge is possible. Ryobi's Maintenance Charge Mode means the charger will 'refresh' the battery at regular intervals, usually every 30 days. A battery's lifespan is determined by how many times it is discharged/recharged so to get 'the longest possible battery life' it is desirable to reduce the number of times a battery is recharged. One way is to use the battery until it is dead or near so another is to remove the battery from the charger when it's fully charged to reduce the number of times the charger refreshes the battery.
Dec 23, 2010 | Ryobi Multi-Volt Battery Charger
We have just put dads Sterling Classic back together after months standing idle. When we switch the battery charger on it says check but what do we need to check.
Hi. The main thing to check for is that the charger is actually connected to the batteries. If the charger has a 3-pin plug that plugs into the scooter, check that there is no broken wires in the plug. Also check the socket in the scooter with a multi-meter, you should be able to read the battery voltage from the meter.
Most chargers sense the voltage in the batteries, and base the charge rate on this voltage. If the charger is not connected to the batteries when it is turned on, it will drop out and go into a fault mode.
Good luck. Neil.
Jun 26, 2010 | Health & Beauty
Johnson Minn Kota Mk 25 & Mk 35 On Board Maintainersstyle: Mk 35 Logo
Top Johnson Boating Experts
kj henriksen
kj henriksen
Lawrence Oravetz
Are you a Johnson Boating Expert? Answer questions, earn points and help others
