Question about General Electric RanControl WB27T10077 R CS
Display does not work but range works well
Where to find schematics what component could be bad
How to fix my sharp aquos LC42D69U lcd tc
Use coldspray to find the bad component abad soldering or a few bad capacitors in the (mains) powersupply . knock and bend the electric print some little the beginning is the powersupply
SHARP LC 32D59U LC 42D69U Service Manual free download schematics eeprom...
Sep 24, 2015 | Sharp Aquos Televison & Video
Added new clock control panel to ge range model jsp38g0s3bg colck flashes but nothing else works on control panel
The description you have provided looks like it going to be a thermal limit switch that is bad (some of them are resettable). You need to remove the control board display. Once behind there you will see 2 limit switches. Try to test both of them with an ohms meter. Both should read infinite but I am sure one is bad. Here is a link to a schematic that may help you find the limits. The part numbers you are looking for is 158 and 159. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216517&diagram_id=21205724#d21205724.
Let us know if you were looking for something more else please accept the suggestion.
Thank You for contacting Fixya.com
Feb 14, 2010 | Kitchen Ranges
HORIZONTAL TRANSISTOR
There is no generic Horizontal Transistor for all Sony Televisions. Having repaired many different tyupes of sets over the years, the only thing that will help you is a set of schematics, and the model numbers on the transistor. You will need the schematics to find/check the other components in the display circuit that may also be bad. Very rarely did I just need to replace a HT without other power supply components as well.
Nowadays, it really does not pay to bother opening most CRT sets anymore. If you can get the schematics, you usually spend $25-$35 just on those, before you get into the actual repair.
May 22, 2009 | Sony Televison & Video
Oven digital display does not work after an electrical surge
You may want to put in a claim against the power company, a spike may have burned out the control board
Apr 29, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidare range glgf376dsm display not working
That's common for the burners to work since they & ignightors have nothing to do with the control board. The oven light is also run by the control board. Before replacing the control board, make sure you have both phases of the power coming in. One 1/2 of the 220 operates the burners and the other phase is the power to the controller. The controller then put both phases on the heating elements. There should be a tech sheet and schematic on the back of the stove or under the hood where the controller is. Good luck
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Bake element blew 2 weeks ago got new part...and still won't heat up
Depending on how the element blew, in some cases it will also ruin the Electronic Oven Control (EOC) board. This is your clock assembly. The EOC controls all the oven functions on electric ranges. There are separate relay controlled circuits on the board that control the BAKE and BROIL functions. The EOC will still display the time and the broiler may still work, but the bake feature will not. My bet, it the relay for the bake element, or a component in the bake circuit is blown. There should be a schematic diagram located inside the operator console, or on the back of the range for assistance in troubleshooting. I would recommend you inspect the EOC for any burned components or wires.
Now...there is a remote possibility you've purchased a bad element (it does happen). A resistance check from terminal to terminal should yield a high resistance in the K ohms range. Next, check the resistance between one terminal and the outer shield of the element. You should get an infinite reading. Anything else, you probably have an element that is shorted.
I hope this information is helpful to you in some way. If you have questions please let me know.
Nov 11, 2008 | Frigidaire Kitchen Ranges
Ge range display screen.
locating the trouble shooting schematic thats hidden somewhere on your range is the first step
May 13, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Blinking picture
Bad components in the horizontial/vertical output. High voltage (flyback), even a bad relay or weak component. These 'steady' failures are often thermal problems as some components fail, they work when cold, turn them on, they heat up, they fail, they cool off, they work. You can pinpoint with some cold spray. When it fails hit the chip or component you suspect with the spray, if it comes right back. Thats your circuit.
Mar 20, 2008 | Toshiba CN36G97 TV
Oven does not light
even if the ingitor glows, and the oven wont lite, the odds are that the ingitor is bad. it must draw 3.2 amps to open the gas valve. the only way to test the ignitor is with an amp probe. replacing the ingnitor is about 90% a sure thing.
Dec 08, 2006 | Hotpoint RGB745 Gas Kitchen Range
General Electric RanControl WB27T10077 R CS Logo
15 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
