Question about Refrigerators
Kenmore model 970 438 633
Parts list
2 Suggested Answers
  • 1937 Answers
SOURCE: Kenmore washer model #110.29842991 will not drain.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-110.29842991/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
The Sears site for your washer may have a section on the gearcase. Check in that section for a Neutral Drain repair kit.
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
http://www.fixya.com/support/r699497-replacing_gearcase
OR ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Aug 30, 2010
Kenmore upright freezer model 31205 .Needs a new evap fan motor.Sears parts says model doesnt come up cant help.
Recheck the model number on the fridge or try the Manufacturer web sites. A lot of fridges share the same parts, you should find a Kenmore model that is listed with the same part.
Nov 20, 2016 | Kenmore Freezers
Kenmore refrigerator model 25378832790
WIRING SCHEMATIC Diagram and Parts List for KENMORE ...
www.searspartsdirect.com/model-part/25360132993/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25360132993 Kenmore-Parts Refrigerator-Parts (11). Full Size ... Refrigerator ice door insulation Part #: 5303917276.
WIRING SCHEMATIC Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/25331614100/0582/.../00005.html
WIRING SCHEMATIC diagram for model # 25331614100 Kenmore-Parts Refrigerator-Parts (8) ... Refrigerator freezer door hot tube repair kit Part #: 5303918222.
WIRING DIAGRAM Diagram & Parts List for Model ...
www.searspartsdirect.com/model-part/2536580250a/0582/.../00006.html
WIRING DIAGRAM diagram for model # 2536580250A Kenmore-Parts ... Refrigeratordoor hole plug Part #: 240479601 Substitution: 240494001 Learn why ...
Kenmore refrigerator model 25378832790 - Fixya
www.fixya.com/support/t26040123-could_get_schematic_above
41 mins ago - Kenmore refrigerator model 25378832790 Where can I get a ... awiring schematics for a GE Refrigerator model TCC18JAAC type LB18,. Jul 29 ...
Jan 05, 2016 | Refrigerators
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
Where can i find a manual for a Kenmore Power spray carpet cleaner model number 175.8099?
There are more numbers in the model number than what you posted and Sears parts site come up with 4 possibilities. I assume that you are looking for an owners manual rather than a parts listing and it looks like all they have is a parts listing. I will include a link to the page that lists all 4 models in case you are looking for parts. Model Search Results
Jun 30, 2015 | Kenmore Vacuums
Kenmore model 911.95875790 code f5
The Kenmore 911 series ranges are built buy Whirlpool. An F5 error indicates an oven control error (clock or ERC). Sears Parts Direct lists this as part 16 here: http://parts.sears.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91195875790/0582/0124111/10052061/00001 . The part is listed as in stock for $171.99. If you had a 4 character trouble code, additional diagnostics could be done to locate the problem.
I hope this helps.
Nov 18, 2011 | Kenmore Kitchen Ranges
My mom has 3 machines ...needs instruction manuals on 2 ..kenmore..models 385.1664190 and model 158.17530... also needs a belt for this one.. the other machine is an..Euro-Pro model 9120...
The manual for the Kenmore 385.1664190 is available here: http://www.managemylife.com/mmh/owner_manuals/26171/KENMORE-Overlock-Machine-L9080230?brand_name_search=385.1664190 . You can purchase a copy here: http://www.sewingpartsonline.com/instruction-manual-kenmore-385-1664190.aspx . I didn't see the manual available at Sears Parts Direct on the parts lists that I checked.
An except of the manual for the 158.17530 is available here: http://www.managemylife.com/mmh/owner_manuals/13415/KENMORE-Mechanical-Sewing-L9090181?brand_name_search=158.17530 . Sears Parts Direct lists two belts (parts 26 and 27) here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-machine-Parts/Model-15817530/0582/1220000/00026091/00002?blt=06&prst=&shdMod= . You can probably get the belts in any Sears store. Ask for the part numbers 50013 (originally 28908) and 30083. The manual is not available at Sears Parts Direct. You can get the full manual for $13 here: http://www.sewingpartsonline.com/instruction-manual-kenmore-158-17530.aspx .
The Euro-Pro 9120 manual is not available as a free download. However, you can buy a copy for $15 here: http://www.sewingpartsonline.com/instruction-manual-euro-pro-9120.aspx .
I hope this helps.
Sep 17, 2011 | Kitchen Ranges
I need the electial diagram for my kenmore washer model 110.20702990.
See the following two documents:
The first is the Sears parts list including major component diagrams and parts / prices:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020702990/0582/0153200?pathTaken=
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
Jan 04, 2011 | Kenmore Washing Machines
Is there a service manual available for Kenmore Deluxe Water Purifier Model No. 34481?
Is this the right unit: http://www.managemylife.com/mmh/owner_manuals/14410/KENMORE-Reverse-osmosis-L0312270?brand_name_search=Kenmore+34481 ? The parts list and owner's manual are available but the the parts blow up doesn't show where the parts fit. The link to the parts list is on the right hand side of the page. No additional service manual appears to be available from Sears/Kenmore.
I hope this helps.
Jan 01, 2011 | Kenmore Microwave Ovens
Operator and parts manual for a Sears Kenmore washer 400 series
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The model number usually starts with 110.########
To the right of the sub-components list is usually a section where you can see and download PDF operating manuals.
If this is a basic Whirlpool / Kenmore top load, direct drive washer, following are two Whirlpool PDF locations.
The first is the installation and operations manual and the second is a parts list for their top load direct drive commercial washers, (consumer models use the same part numbers).
Oct 10, 2009 | Kenmore Washing Machines
Kenmore vacuum manuals
I tried what reddevil6 suggested and was not able to get Sears to produce a manual. I would prefer an online manual but at this point I'm desperate enough to try anything.
Dec 10, 2007 | Vacuums
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
