Question about Chevrolet Camaro V6 1998-2003 Pro-Kit Performance Lowering Sp
Coolant in my oil pan
Large amount of coolant going into my oil
    Genius:
  • Eibach Master
  • 1,013 Answers
Cylinder head gasket leaking needs new gaskets
Posted on Aug 17, 2014
Nissan maxima 2000. Oil dipstick level shows too high. Regular oil changes done and filter with proper amount added. White smoke alerted me to recheck things. Only thing I found was dipstick shows oil
If the oil level goes up, something has to be leaking into the engine oil pan.
That would either be gasoline from the injectors or coolant from the radiator. If you are not adding coolant, it could be a leaking injector.
Feb 04, 2013 | 2000 Nissan Maxima
Where is transmission filter located in 2001 mitsubishi diamante located and how do i change it?
transmission filter in the bottom of transmission bolted to valve body.you need a large drain pan.place drain plug under transmission oil pan.remove transmission oil pan drain plug.let all transmission fluid drain out then screw back drain plug in oil pan.then you need to remove transmission oil pan then remove filter and replace pan gasket also.make sure you have right amount transmission fluid on hand.buy extra because if you short of fluid you cant drive car if fluid level too low.make sure you get the right amount fluid.torque pan bolts to 96 inch pounds.
Nov 10, 2011 | 2001 Mitsubishi Diamante
1999 Dodge Caravan 3.0 on the right side there is a large square pan (larger that oil pan) looking underneath it appears antifreeze is pouring out in a steady stream from one of the bolt holes on this...
I believe u are referring to the tranny pan. And if u are loosing that much fluid I would start looking around the block for any sings of a blown head gasket. If u live in colder climate it could also be a freeze plug that is bad. In Minnesota I see this all the time. People think they can do there own coolant flush and end up putting to much water in and freezing the block partially and when it thaws loose coolant from that plug. I would suspect a bad rear seal in the motor or a bad oil pan gasket be the cause of the oil. But without seeing the vehicle and the leaks I cannot say for certain but those are the things I would think it to be. Now no offense to you at all, but I think I would take it in to a shop to find the problem, or a food friend that knows about cars, like what a tranny pan is. And like I said no offense to you. But to me this sounds like it could be a big deal of work not for the novice.
Mar 31, 2011 | Dodge Caravan Cars & Trucks
I have a leak from the oil pan ...of my 1992 mercury topaz and im needing to know what all i will need to do to repair it
You didn't list your engine size so please pick the approriate task:
2.0L Engine
  1. Disconnect the negative battery cable.
  2. Raise the vehicle and support safely with jackstands.
  3. Drain the crankcase of oil.
  4. Remove the attaching bolts securing the oil pan to the engine.
  5. Clean the oil and gasket mating surface completely, and allow to dry.
To install:
  1. Apply a 1/8 in. (3.18mm) bead of silicone sealer D6AZ-19562-B or equivalent between the oil pan and engine crankcase.
  2. Install the oil pan using the attaching bolts. Torque bolt to 5-7 ft. lbs. (7-10 Nm).
  3. Lower vehicle, and fill crankcase with correct amount of engine oil.
  4. Start engine and check for leaks.
2.3L Engine
  3. Drain the crankcase of oil, and drain the cooling system by removing the lower radiator hose.
When draining coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze, and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old.
  1. Remove the roll restrictor if equipped with a manual transaxle.
  2. Disconnect the starter cable.
  3. Remove the starter from the vehicle
  4. Unfasten the bolts securing the rear oil pan to the transaxle case.
  5. If equipped with a manual transaxle, remove the secondary air injection tube at the check valve.
  6. Remove the heater supply tube located at the lower water pump inlet tube assembly.
  7. Loosen the bolts and remove the brackets at the block and water pump inlet tube and A/C compressor line at the pan.
  8. Using a prybar between the engine and body of car, flex engine enough the remove oil pan.
  9. Clean the oil and gasket mating surface completely, and allow to dry.
  10. Clean both mating surfaces of oil pan and cylinder block making certain all traces of RTV sealant are removed. Ensure that the block rails, front cover and rear cover retainer are also clean.
  11. Remove and clean oil pump pick-up tube and screen assembly. After cleaning, install tube and screen assembly.
To install:
  1. Apply a bead of RTV E8AZ-19562-A sealer or equivalent, in the oil pan groove. Completely fill oil pan groove with sealer. Sealer bead should be 0.200 in. (5mm) wide and 0.080-0.150 in. (2.0-3.8mm) high (above oil pan surface) in all areas except the half-rounds. The half-rounds should have a bead 0.200 in. (5mm) wide and 0.150-0.200 in. (3.8-5.1mm) high, above the oil pan surface.
Applying RTV in excess of the specified amount will not improve the sealing of the oil pan, and could cause the oil pickup screen to become clogged with sealer. Use ad equate ventilation when applying sealer.
  1. Install oil pan to cylinder block within 5 minutes to prevent skinning over. RTV needs to cure completely before coming in contact with any engine oil. Ideally, about 1 hour at ambient temperature between 65-75°F (18-24°C) is recommended as a drying time.
  2. Install oil pan bolts lightly until the 2 oil pan-to-transmission bolts can be installed.
  3. Install 2 oil pan-to-transaxle bolts. Tighten to 30-39 ft. lbs. (40-54 Nm) to align oil pan with transaxle. Loosen bolts 1/2 turn.
  4. Tighten all oil pan flange bolts to 15-22 ft. lbs. (20-30 Nm).
  5. Tighten 2 oil pan-to-transmission bolts to 30-39 ft. lbs. (40-54 Nm).
  6. Install brackets for A/C compressor line and water pump inlet tube.
  7. If equipped with a manual transaxle, fasten the air injection tube.
  8. Install the starter and cable.
  9. Lower vehicle.
  10. Install engine oil and coolant.
  11. Connect the negative battery cable.
  12. Start engine and check for coolant and oil leaks.
Oct 12, 2009 | 1992 Mercury Topaz
How to change transmission fluid in a 2001 dooge stratus rt
loosen bolts on bottom of trans pan, pull one corner lower than others, drain fluid into large flat container. Remove gasket and filter. replace both. replace pan cover careful to keep gasket in position. check owner manual for amount of fluid to fill and type of trans fluid. DO NOT OVERFILL- EVEN 2 OUNCES OVER CAN RUIN SEALS
Sep 08, 2009 | 2001 Dodge Stratus
Engine oil dipstick shows water and rust mixed in with oil
Everyone always jumps to head gaskets. There are plenty of MINOR things that can be looked at first.
The Volvo 2.3, 2.4, 2.5 Inline 5 Cylinder dipstick tube is known to develop a large amount of condensationin winter months and stop and go driving. What you see on your dip stick is possibly just condensation. Take off your oil cap and look under the cap and inside the valve cover. Is there any thick foamy oatmeal like substance or noticeable amounts of water? If your oil was saturated with coolant, you would be able to see it up there too. Check your coolant for oil. Volvo coolant is typically brown to orange, however make sure there is no sludge. Start the car with the cap off and keep an eye out for alot of bubbles. A large amount of bubbles is a sign of a bad head gasket. A couple here and there is just air in your cooling system.
Coolant, Transmission fluid, and Oil have several places they can mix. If you have a turbocharged Volvo, the seals in the turbo can go bad and cause a mix of oil and coolant. Your transmission cooler is also in your radiator, and if it cracks your transmission fluid and coolant can mix. I believe turbo models have an oil cooler built into the radiator as well.
Overall if your car sounds fine, you dont see oatmeal, your not using coolant and oil in excessive amounts, dont have white smoke, and your turbo isnt whining you probably just have condensation in your dip stick. If you are overly concerned you can send a sample of your oil to a lab and have it tested for traces of coolant. Headgaskets rarely fail on Volvo's, even the old ones....I have seen many that have gone to replace them have not found a failed gasket and end up finding a bad transmission cooler or a bad turbo.
May 09, 2009 | 1999 Volvo S70
OIL LEAK ON TOP OF MANIFOLD
If it's on your intake manifold your distributor seal/o-ring is bad.
Apr 02, 2009 | 1994 Ford F350 Crew Cab
Hi i have a 1997 grand caravan with a 3.0 and i have fuel pouring out my exhaust and no power.the gas comes out in a large amount
ALSO it Is Dangerous to RUN this ENGINE if it has Fuel in the oil pan as this can cause a Pan FIRE Basically it can Ignite the fuel in the oil pan and cause it to EXPLODE I have seen this first hand and it Blew the Valve cover off an Old dodge dart slant 6 like a BOMB went off -----------------A misfire on one or more cyls. can cause fuel in oil All Preventive Maintenance Procedures Must be Eliminated on this Vehicle Major tune up all filters Oil changed check for trouble codes as something as simple as a Temp sensor will cause the Engine go to full Rich Mode and Over-fuel
Jan 06, 2009 | 2000 Dodge Caravan
Leaking engine oil
jack up the car and look underneth it , if it is a large amount it is probaly a front or main seal and a lot of work, if it is a small amount you need to tighton the oil pan the bolts tend to come lose overtime and need to tight
Dec 19, 2008 | 2001 Pontiac Grand Am SE
Milky oil in the air intake alot of it also in the oil pan
cheange your oil. runn it for awhile and change again
Jul 22, 2008 | 1991 Chevrolet Lumina
Chevrolet Camaro V6 1998-2003 Pro-Kit Performance Lowering Sp Logo
56 people viewed this question
Top Eibach Vehicle Parts & Accessories Experts
Timllfixit
Robert Rankin
 Mikey
Mikey
Are you an Eibach Vehicle Part and Accessory Expert? Answer questions, earn points and help others
