Question about Directv Televison & Video
Problem With DirecTV Signal with Samsung LN32 HDTV
I have a samsung ln32 hdtv. Have been able to watch DirecTV on it with no problem until tonight, when I turned on TV and saw a message on the screen that said "Weak or No Signal". The HDMI cable from DirecTV receiver unit to TV is securely attached. I believe maybe the channel was somehow changed. However, when I do the autoprogram for the channels, nothing comes up. I'm baffled. Help??
    Scholar:
  • 189 Answers
Have you went into your cable box's setup menu and see if there is a option for a software update? Also, check outside where all the cables are high up to see if squirrels have been chewing on them. That is a problem sometimes. Also check outside where any cables are joined together (where they screw to extend a cable) and check inside for corrosion and tightness.
Posted on Mar 21, 2014
3 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: No right channel audio when using HDMI connection to HDTV
Since it is easier to replace, I would go with the cable box first. Sometimes there are software upgrades for the TV's that fix such issues but, almost all HDMI issues are with the cable box not the tv.
Posted on Jan 27, 2007
  • 362 Answers
SOURCE: how I can connect my Samsung Home Theatre System
ideally you would simply add an hdmi source from each device to the surround receiver and send the output to the tv but im thinking your amp may be short on inputs from all devices and if indeed it was this simple you wouldnt be here seeking this info also note you may be able to use the output on the set to gain another signal tranfer but note there can be compatability issues on some sets whether they will decode hdmi in and rca out or optical out like i said some sets ok :) i wish you luck and wishin i had this all in front of me so i could be a greater help any q's drop me a comment here ok :)
Posted on Feb 26, 2011
I am try to stream Netflix from my computer to my Samsung TV
How to Watch Netflix Instantly on your HDTV
www.handymanhowto.com/how-to-watch-netflix-instantly-on-your-hdtv...
I have a samsung tablet i should b able to connect the usb port into the tv from the tablet and ... Am I spinning my wheels trying to connect this PC to that TV? .... I have a windows computer, that i play Netflix on through an HDMI on our TV.
How to Watch Netflix Instantly on your HDTV - Part 2
In this example I have my Windows 7 laptop connected to a Samsung HDTV with an HDMI cable. ... Watch Netflix - Computer Displays Blank or Screen Saver on TV .... It seemed like better quality sound kept trying to break through and then go back to whatever ... I am guessing the HDMI cable will give much better quality.
Dec 28, 2015 | Samsung Televison & Video
Turn off and on codes
samsung usually doesnt have a code. hide a switched power strip or something behind the tv or unhook it somehow when you're away. you can lock cableboxes and sat boxes sometimes, but i think that panasonic code is a rare thing
Jun 17, 2010 | Samsung UN55B8000 55 in. LCD HDTV
I turne on,LN32 LCD TV ,works 2 - 3 minutes and self turn off.
The Power supply board was bad. Actually, some capacitors on the board were failed but you need to change the whole board unless you can do-it-yourself.
Nov 12, 2009 | Samsung LN32A330 32 in. LCD TV
I have a new Samsung HD tv and have hooked up my DVD player. I have a Directv remote. How do I watch my movies now?
You will still need to use your SAMSUNG remote to switch the source inputs since I do not beleive the DIRECT-TV remote has full function of the SAMSUNG remote.
Nov 02, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Displays weak or no signal
To get any HDTV to work this is what you have to do;
CHANNEL section
1) Connect your antenna cable which you have done.
2) Go into the menu to the source option and select AIR/ANTENNA since you are using an antenna.
3) In the menu you will have to SCAN in the stations. This auto program will find all available stations.
Now you can watch tv by selecting the station you want.
The new generation of HDTV is different from the old analog sets. These have to be set up to work.
Exact information can be found in your Users Manual.
Feb 23, 2009 | Samsung Televison & Video
Motion problems
You need to contact cable company, first for this.
Because of tyhe picture quality is related cable box, cables ,connectors & etc.
Jan 22, 2009 | Samsung LN46A650 46 in. LCD HDTV
My ln32 450 samsung monitor shows pc and mode not supported in the middle when connected to my hp laptop
firststart it in safe mode and run the add hardware wizard anfter windows finds it and installs the monitor reboot then set the video adaptor at 600 by 800 mhz at 60 hz then adjust it from there
Dec 19, 2008 | Computers & Internet
Red in left sie of screen show up sometimes on 42 samsung SP P4251
What component(s) are you connected to this TV?And what type of A/V cables are you using?
Does it only happen when you watch cable or directv or dishnetwork?
solutiondoct
Nov 06, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung hpt4254
Are you using a cable box,directv,dishnetwork?High Definition?
I need more data to assist you.
solutiondoct
Nov 02, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Just set up a samsung 67in hdtv--all is fine except the image is cropped at top and bottom regardless of the picture setting at 16:9 or 4:3 or wide or just scan which should adjust the signal sent from...
We have the 61" Samsung. WE LOVE IT!!! We have a DirecTV DVR box. On the DirecTV remote there is a "format" button. It cycles through all the different options. (Pillar Box, Stretch, 720p,1080p, etc.) Adjusting the picture setting with the Samsung remote is not the same thing. Try using the cable remote......see if it works the same as mine.
Sep 04, 2008 | Televison & Video
Televison & Video Logo
69 people viewed this question
Top Directv Televison & Video Experts
john milligan
Ed
Level 1 Expert
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
