Question about Craftsman Garden
Install hour timer craftsman yt3500
Hour timer is optional and want to order and install on craftsman yt3500. Wanted to see difficulty of installation prior to order.
mikedurland
  • 481 Answers
SOURCE: whirlpool washer timer
no magic to it, but double check your wire harness and make sure it is plugged in all the way. it is sometimes easier to plug the harness in before mounting the timer to the control panel.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Posted on Jul 22, 2008
PABLOCSA
  • 1124 Answers
SOURCE: HP Deskjet 3650
No. If this happen probably your computer is not responding, cancel the installation.
Restart your computer and printer and try again.
If you choose to install all the software that comes with your printer the installation will be delaying more. Select only necesary stuff.
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Let me know if you have further questions about this issue.
Posted on Oct 18, 2008
yooperbud
  • 8637 Answers
SOURCE: Very long time to install lifecam 2.04
Did you use the CD software program that came with the camera?
Normal 0 Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 21, 2009
bob_computer
  • 3153 Answers
SOURCE: installing free map on Tom tom One XL
If it did fail and you are installing to an SD card then you might want to try another brand of card first. but before you do that make sure you back up your device to the PC. I have two large maps on mine, a whole heap of voices etc, and the backup alone takes over 2 hours
Posted on Aug 08, 2009
  • 396 Answers
SOURCE: Setting the timer
Click on the link below to download your manual if you see your model listed.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
You can install a photocell for six to ten dollars which you can wire in series with your timer output. The photocell that will bypass the daylight time cycle from 8am-12pm.
Posted on Jul 27, 2010
I have difficulty to see the numbers when is plug? What happen?
Plug timer in for 1 hour to charge battery...
Or if timer has battery located on back of unit, install battery.
Once battery is operable you can unplug timer from wall and program the timer while holding it in your hand.
Manuals and troubleshoot for many household timers appear on following links:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
http://waterheatertimer.org/How-to-troubleshoot-timers.html
Gene
Water Heater Timers Save Money
Mar 13, 2015 | Kichler PLUG-IN ACCESSORIES - DIGITAL...
Noma 052-8870-6
OUTDOOR DIGITAL BLOCK HEATER TIMER 052-8835-2 Instructions Plug timer into grounded outlet
To Set the Current Time: Press the HOUR button as many times as necessary to advance the display the correct time. Note, the time can only be set in 30 minute intervals. The LED display will display the hour (1-12) and on the half hour a light will illuminate in the upper right corner, next to the number 30. To change from AM to PM toggle 24 times, a dot will illuminate in the lower right corner of the display next to the letters PM.
To Program the Timer: Press the PROGRAM button once, the letter P will flash. Press the HOUR button to set the ON time. Press the HOUR button to set the ON time. Press the PROGRAM button again, the letter E will flash. Press the HOUR button to set the OFF time. Press the PROGRAM button to exit program setting mode. Press the HOUR button to review the ON/OFF setting.
To Connect/Operate the Timer: Plug device in to the timer and turn the device on.
To Revise the ON/OFF Setting: Unplug the timer and plug it back in. Repeat the programming steps above.
To Override the Timer: Press the PROGRAM button if you want the device to turn on before the preset time, but note the device will turn off at the preset time. For example, if the preset ON/OFF period is 3 pm - 4 pm, users can manually press PROGRAM to turn the device on at 2 PM, the timer will keep running until the preset off time at 4 pm.
Suitable for use with outdoor appliances. Raintight when mounted vertically with the receptacle facing downward. Use a three-conductor GFCI protected outlet. Do not immerse in water. DO NOT EXCEED RATED CAPACITY. Not for permanent installation. Do not install or use this product for more than a 90-day period per year.
Dec 02, 2013 | Hardware & Accessories
I need a light timer that I can set to be on for 50 minutes and off for 10 minutes, and repeat this over a 24 hour period.
Another timer that can be set this way is the Intermatic ET9000 series commercial programmable 365 day timer, which accepts any voltage, and rated 20-30 amp, and has 4000 set points for programming.
http://waterheatertimer.org/pdf/Intermatic-ET90000-Series-Spec.pdf
Another timer series might be useful, and can be programmed by computer and has small relays that install on a card that is installed in computer like installing a modem card, and can interface with zigbee wireless:
http://www.francisav.com/relay_controllers.htm
Nov 28, 2012 | Woods Indoor 24 Hour Night Light Timer...
I need instruction manual for TD126 timer
TD126 timer
I'm going to guess at these instructions since they're not posted anywhere yet.
It's a chance I will be wrong, and others can add a comment and refine the answer.
The other option is: you can buy timer and scan your manual into pdf format and post it on your website for free.
Then add a comment with manual web location so we fixyans can sell your manual and manual information to other folks who are wanting a manual to sell to other folks.
Another option: You can pay a fixyan to buy the timer and do the work for you.
My guess is that free is better:
Plug timer into outlet for 1 hour to charge battery.
Remove timer from outlet to program.
Timer appears to be a 24-hour repeat timer with 12 hour am-pm format
There are 5 buttons on face of timer: Reset SET + - Finger
-Press reset button to clear programming.
-Set current time: Push and hold finger button while pressing + and - until current time and am pm display. Or push and hold SET button while pressing + and -.
Program timer:
-Press finger until PROG 1 ON displays
-Press press + and - to set program1 ON Hour.
-Press SET to confirm hour
-Press press + and - to set program1 ON minute.
-Press SET to confirm ON minute
-Press finger until PROG 1 OFF displays
-Press press + and - to set program1 OFF Hour.
-Press press + and - to set program1 OFF minute.
-Press SET to confirm OFF minute
-Press finger until PROG 2 ON displays
-Repeat steps above.
-When programming is finished, push set button.
And you might have to push finger button, or push and hole finger button, and then set button.
-Timer appears to be in AUTO as default mode.
Timer may also have a switch located on side of timer. Move switch to timer if there is a switch.
Some timers also require you push two buttons at same time to enter different modes, or hold one button while pushing other button.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 10, 2011 | Hardware & Accessories
Have GE digital timer 15117. Can't figure out how to make the display show AM/PM so I can set it correctly. Clock hour/min just cycles through 12 hours without noting AM or PM setting. Can't program...
GE 15117 manual
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
You might try a new AA battery.
Some guy wrote in this week and said he bought 6 timers and all the batteries were bad except 1.
Some timers, like Woods TD1300, and others have the 12 hour or 24 hour option.
You press and hold Time button to choose 12 hour or 24 hour
But GE 15117 manual says nothing about this option.
GE 15117 timer is same timer as Woods 59403
Several folks have written in past couple weeks about the Woods 59403 timer skipping over functions.
The best I can guess is your timer is malfunctioning like the other people's timers.
Woods 59403 manual is identical to GE manual, and says nothing about 12 hour 24 hour option either
http://waterheatertimer.org/pdf/Woods-59403.pdf
I test timers for programming and wiring difficulties.
Yesterday 3 timers arrived here, and 1 didn't work.
I took it apart and tested the electronics, and something went bad.
When these timers don't work, you get your money back or throw them away.
Dec 04, 2010 | GE Hardware & Accessories
Setting the timer
Jul 27, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Unable to install Audio driver
After searching for an hour there are no diversfor your models sound card that support XP your only two options are:
A) Run Vista
B) Purchase an external usb sound device and disable your on board sound card. Here is a link to some:
http://www.nextag.com/Sound-Cards--a-Soundcard+Interface-_-USB--zzexternal+sound+cardz300013zB6z5---html
Cut and paste in your address bar to check out some external sound cards.
Hope this helps you out. I know its not what you wanted to hear but it's true. Please take a second to rate this fixya for the hour I spent frantically searching for a driver for you, Thanks
George
Jul 25, 2008 | HP Compaq Presario C500t Notebook
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
