Question about Apple iPhone Cell Phones
I forgot the passcode of my iphone and i dont know what to do?
I forgot the passcode and I cant used it
    Problem Solver:
  • 19 Answers
If your phone has been hooked to iTunes recently, it will have backed it up.... Simply wipe out phone in I tunes and reload ur previous info from backup ...
Posted on May 04, 2014
5 Suggested Answers
  • 20 Answers
SOURCE: I forgot my passcode to unlock my iphone
It depends on the severity and the settings you have given the iPhone and whether you have the computer that you synced your iPhone with... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
==If you have the computer you synced your iPhone with==
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It  can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
==If you don't have the computer you synced your iPhone with==
If you don't have the original computer the iPhone synced with, the only solution is to force your iPod Touch into recovery mode and then restore it. You will lost all the data on the iPod Touch, but after this method is done, everything will work. You can find the steps to solving this problem here:
http://support.apple.com/kb/HT1808?viewlocale=en_US
Posted on Feb 13, 2009
  • 12 Answers
SOURCE: i hv a iphone but i forgot the the passcode...i need some help..
You can call att or apple to help but if u cant wait and u have a backup saved just turn it off hold the home button then connect the usb for the iphone and restore
Posted on Aug 10, 2009
SOURCE: i forgot my passcode and now my iphone is disabled.....
how do i find out what my passcode is
Posted on Sep 11, 2009
  • 192 Answers
SOURCE: i forgot my apple iphone
Try the Restore procedure from iTunes If you have problems. But first try the recovery procedure.
1.
Disconnect your iPhone cable but leave connected the other USB end to the computer.
2.
Turn off your iPhone holding the Sleep/Wake button. The red slider bar appears. Slide the bar and wait until the iPhone turns off. Or you could hold the Sleep/Wake and Home buttons at the same time until the iPhone turns off.
3.
While pressing and holding the Home button connect the USB cable to your iPhone. It should power on. Hold the Home button until you see the "Connect to iTunes" message. Open iTunes if necessary. You should see the "iTunes detected an iPhone in recovery mode..." alert screen.
Choose " Restore"
Posted on Feb 21, 2011
How do i get my passcode back without using itunes?
The only option is to use iTunes or call them and have apple change it for you.
Feb 28, 2015 | Apple iPhone 5S
How to open my iphone if i forgot the passcode.?
If you can't remember your passcode, you'll need to erase your device using iTunes, Find My iPhone, or recovery mode. Then use a backup to put your data and settings back on your device. You can try plugging it into iTunes to see if it reboots itself
May 07, 2013 | Apple Iphone A1303 16gb
Need to change iphone passlock code
http://osxdaily.com/2011/01/16/forgot-iphone-passcode-how-to-reset/
this will help you!
nouvelle tablette pc
Feb 14, 2012 | Apple iPhone4 4G iPhone 4
I was out at the bar i was kind of intoxicated i put a passcode on my ipod touch now i dont know what it is and cant bypass it how can i reset my ipod touch???? or bypass the passcode i set???
There is no way to get around a password that you dont know. The best way to do it is to reset the device.
To reset:
Plug your iPhone into your PC or Mac with the USB cable
Press and hold the power button at the top and then slide to power off the iPhone
Press the power button to power the iPhone on and keep it held while simultaneously pressing the home button
After a few seconds a yellow alert triangle will appear and the iPhone will say it is iPhone Restore Mode.
Open up iTunes and click on the Summary tab
Click on Restore to restore your iPhone. This will reset all your iPhone's setting to the factory defaults, including the Passcode.
May 06, 2011 | Apple iPod touch
I locked my iphone 4 and forgot the passcode so i hooked it up to my computer tht i have itunes on my phone is disabled so i cant connect to itunes without the passcod i forgot and its permanently...
Sorry to read about your problem, I hope this helps you out.
you will have to put your phone in the DFU mode and reinstall the os...find somebody that knows what the are doing, or take to apple....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Apple iPhone Smartphone
I forgot my restriction code for my ipod touch
If you really can't remember your passcode, the your last resort is to restore your iPod touch. but before that, you should put it to recovery mode first.
For step by step instruction, click here.
Click here for more iPod touch / iPhone tips.
Feb 21, 2010 | Apple iPod touch
I hv a iphone but i forgot the the passcode...i need some help..
Aug 09, 2009 | Apple iPhone Smartphone
Cell Phones Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
