Question about Staples SPL1506X (CrossCut) Shredder
Stuck in overload
Spl1506x is stuck in overload. cutters are running in revere. unplugged for several hours but will not come out of overload mode.
Cleaning a shredder that has sticky paper stuck to the cutters. A EPS-611x.
FIRST MAKE SURE THAT YOU HAVE REMOVED POWER
UNPLUG IT
Using pick remove the paper that is stuck to the cutters,
also you could try shredder oil to assist after you have removed
a majority of the sticky paper...Take a piece of paper fold it
in half, apply a bead of shredder oil the length of the folded paper
Run it through the shredder like you would a plain piece of paper keeping it folded
Sep 05, 2017 | The Office Equipment & Supplies
When cutter's off/on switch is turned on, torch is active without pressing button on torch.
Turn the power off on the machine and check the continuity of the trigger wires with a continuity tester to make sure they aren't shorting together.
Oct 23, 2015 | Welding Tools
Power light will not come on
Check the bin/door sensor there might be paper stuck inside preventing activation, failing that check the main fuse
Aug 22, 2013 | Staples SPL1506X (CrossCut) Shredder
Spl-txc122a
The motor runs reverse even when in Auto mode, how do I fix it, and why did it happen
Mar 27, 2013 | Staples SPL1506X (CrossCut) Shredder
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
Tv stuck in service mode
Unplug for several hours, press and hold power button for 5 seconds, wait half hour more, plug back in and try. Or press and hold either channel buttons at same time or volume buttons at the same time to see if that exits the mode.
Nov 18, 2009 | Sylvania SRT2232S 32" TV
Jammed with gummed stickers
Always put stickers in the shredder between two layers of 3-4 plain paper sheets. That's for future.
Now I would suggest getting some "Label Off", "Label Killer" or similar spray product, that will dissolve the glue, spraying the cutters and stuck labels with it several times, trying to remove them with tweezers or thin long-nose pliers. Be gentle, try not to blunt the cutters' edges.
When you get rid of the labels, spray more of the stuff on the cutters and clean them with a brush, to remove glue residue between them. Do it several times, rotating the cutters to remove the glue all around.
Then lubricate the cutters as per manufacturer's recommendations.
Nov 14, 2009 | OfficeMax 0M96431 Shredder
Gestetner 5308bt copy printer error after switching on E-01 call service - How can I fix it I am on a ship at present
This is a cutter error. Check the following.
Master cut error occurred
Cutter switch
Cutter motor
Cutter drive mechanism
Open the side the master is loaded. Check that the cutter is in the home possition and that there is no used master stuck in the machine. Check the motor by entering sp mode
Function clear "107" press and hold C/clear
"131" #
"23" Start key
will return cutter to home position.
Press funtion clear to exit.
If the motor is not running you will have to replace it.
Nov 13, 2009 | Gestetner Office Equipment & Supplies
My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Mar 01, 2009 | Royal VF1012mx Shredder
MY magic chef CTB1922 IS NOT COOLING
Sounds like your compressor overload tripping. Compressor may be stuck from sitting. Start relay may be stuck from sitting. Try a new start relay after making sure all your wires and connections are good. Sometimes a wrap with a deadblow hammer on the side of the compressor can get it going. Don't pound on it just a light wrap. My guess is the relay or overload first. Unplug before fooling with any wiring!
Jun 02, 2008 | Magic Chef CTB1922 Top Freezer...
Staples SPL1506X (CrossCut) Shredder Logo
205 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Terry Hair
Tom Chichester
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
