Question about Sharp xe-a107 cash register
I cant get the tax rates set
I havedone everything it as ask me to do but it still wont set my tax rates. I have got as far as step 5
SOURCE: Set tax
To set your tax rate:
1. Be sure to switch to "rate set" from GT
2. Enter the tax amount like so - if your tax rate is 7% type in 7%
3. Go back to the GT setting and it should work...at least that is how I fixed mine! I did the same thing last week & have no manual!
Hope this helps you
Posted on Mar 24, 2008
SOURCE: TAX SET
Press +TAX
press the number you need to set it at
Press +TAX again then CA
worked for me!!
Hope this helps
Posted on Nov 06, 2008
SOURCE: SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
Posted on Jan 29, 2009
  • 68 Answers
SOURCE: How do you set the tax rate
Example: setting 5% tax rate
1. move mode switch to 'rate set '
2. press 5 (for tax rate ) followed by TAX+ button
3. Move mode switch to GT
to add tax to e.g 200 type:
200 TAX+, the result is 210
Posted on Feb 16, 2009
  • 3 Answers
SOURCE: Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Posted on Apr 10, 2009
How do i set the tax rate for Casio QT-6600?
go to PGM 3 then go to
1- Machine Feature
go to
9-Tax Table
go to
1- tax table 1
set tax rate to 5.0000
set Rounding to Round up
set singapore Rounding to Round up if you are not using the 1 cent anymore
set calculation Type to Table and Add on
Press ESC to go back to Tax Table window and choose
2- Tax Table 2
repeat the same steps as for Tax Table 1 but set the tax rate to 9.98
Jan 31, 2013 | Casio QT-6600 Cash Register Touchscreen...
How do you set the tax rate (GST) in the Casio 140cr cash register?
1) Turn Switch key to PGM
2) press the TAX PGM key
3) enter tax rate ( example 6% is 6 , 5.75% enter 5.75
4) press the Dept key you want that tax rate set too .
5) repeat steps 3&4 for diffrent tax rates or depts.
6) press Sub total key to end programming
http://www.casio4business.com/sa/products/downloads/manuals/140CR_user_English.pdf ====== USER manual
Jan 24, 2011 | Casio Parts Cash Register PC Desktop
How do you set the tax functio on a T 1210 calculator by Triumph Adler
step 1: Turn the calculator on
step 2: type in the tax percentage; the digits
step 3: push <TAX SHIFT>
step 4: push <+TAX>
step 5: just see the display blinking "RATE TAX %" while showing your input rate
step 6: when blinking has stopped, push <CE>
Now you're done.
You can check by entering the number "100" and then push <+TAX> to see the inclusive amount and then pus <-TAX> to see the exclusive amount again.
HTH
Dec 20, 2010 | Adler Royal T-1210 Basic Calculator
I CANT CHANGE THE TAX RATE
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
The above worked for my MS-80TV. I did have to do it a couple times. I noticed when I did it the time it worked I could see the word "SET" in the display. I think the key might be to hold the set button just until you see the word SET.
Best Wishes!
Mar 29, 2009 | Casio Office Equipment & Supplies
Tax Key
So just 5 easy steps to change the rate
1 press the AC button
2 hold down the SET /SET % / button for a few seconds
3 press the TAX + button
4 input the rate /in your case 6/
5 press SET button again
And you are done. You can also check it - press the Tax + button and the current tax rate will appear
Hope I helped !
Jan 05, 2008 | Casio MS-80TE Calculator
How do you set a tax rate?!?!?
1. Switch off the calculator
2. Switch it on again
3. Press and hold the tax button (set %) until the display changes
4. Enter the new tax rate
5. Press the tax button (tax +)
Any problems contact dave@techsoft.uk.com - he emailed the solution to me and it has worked.
Pam
Oct 10, 2007 | Casio HR-100TMPlus Calculator
Tax rate, user guide
hi Jocelynn As far as I can figure out, to reset ur tax rate, all u need to do is put the gt button to tax rate-- then type in the new rate -- set the gt button to off. eg:- gt button to tax rate- type in 5(5% tax rate)-- gt button off Hope this solves ur problem. For further contact arduff@shaw.ca
Jun 19, 2007 | Canon P170-DH Calculator
Tax Rate
1. Press the AC button to clear the screen
2. Press and hold the Set % key until Set appears
3. Press the Tax+ key
4. Type in your tax rate (including decimal point) you wish to calculate
5. Press Set %
Jun 06, 2007 | Casio MS-80TE Calculator
Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17­.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
Mar 13, 2007 | Casio MS-80TV Scientific Calculator
Tax Rate
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 6 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 6 should be displayed
Dec 21, 2006 | Casio JF-100TE Calculator
Sharp xe-a107 cash register Logo
70 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
