Question about Data Dynamics ActiveReports 2.0 Standard Edition (DDAR2SS) for PC
I want installation for ActiveReports 2.0 Standard Edition
RptDocument is not define
Just noticed you are using rptDocument and rpt.Document
Should the dot be in both or neither?
Sep 29, 2017 | Data Dynamics ActiveReports Standard...
RptDocument "is not defined"
just noticed you are using rptDocument and rpt.Document
Difficulty to open pdf files
1. Make sure that the system meets the requirements for the Acrobat product that you use.
Acrobat can't run correctly if the system doesn't meet the following requirements:
  • Intel Pentium processor
  • Microsoft Windows XP Professional or Home Edition with Service Pack 1 or 2, or Tablet PC Edition, or Windows 2000 with Service Pack 2
  • 128 MB of RAM (256 MB recommended)
  • 460 MB (Professional) or 360 MB (Standard) of available hard-disk space; optional installation files cache (recommended) requires an additional 300 MB of available hard-disk space.
  • 1024 x 768 (Professional) or 800 x 600 (Standard) screen resolution
  • CD-ROM drive, if installing from a CD
  • Internet Explorer 5.5 or later
Jun 16, 2011 | Adobe Acrobat 7.0 Professional
I can't install the service pack 3 of SQL server
Are you installing SP3 for SQL 2005 Standard or Express editions?
According to Microsoft, the standard edition will not work on XP Home.
See:
http://technet.microsoft.com/en-us/library/ms143506(SQL.90).aspx
Aug 01, 2010 | Microsoft Windows XP Home Edition
Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
Hi
To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
Windows Server 2003 R2 Standard Edition
Windows Server 2003, Standard Edition SP1
Windows Server 2003, Standard Edition SP2
Windows Storage Server 2003
Windows Small Business Server 2003
If you are using : Windows Server 2003, Web Edition
It will support only 2 GB of RAM
For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
(msdn.microsoft.com/en-gb/library/aa366778.aspx)
If you find it useful please do not forget to rate this solution.
Jul 14, 2010 | Microsoft Windows Server 2003 Enterprise...
Error 1335. The Cabinet file Data1.cab required for this installation is corrupt and cannot be used.
When you try to install Microsoft Office 2000 or Microsoft Office XP, you may receive the following error message: Error 1335-Cannot copy cab file Office1.cab. The file may be corrupt. When you start the computer in Safe Mode and then try to install Office, you may receive the following error message: The Windows Installer Service could not be accessed. This can occur if you are running Windows in Safe mode or if the Windows Installer is not correctly installed. You may receive this error message even when the Office CD-ROM package works correctly on another computer.
When you try to install Office while you are logged on to the computer with administrative rights, you receive the same error messages. uparrow.gifBack to the top CAUSEThis error can be caused by dirty media, CD-ROM read issues, or problems with me... loadTOCNode(1, 'cause'); This error can be caused by dirty media, CD-ROM read issues, or problems with memory allocation. uparrow.gifBack to the top WORKAROUNDTo work around this problem, try the following methods. Method 1: Clean the CD-... loadTOCNode(1, 'workaround'); To work around this problem, try the following methods. uparrow.gifBack to the top Method 1: Clean the CD-ROM loadTOCNode(2, 'workaround'); Use a soft cloth to gently clean the disc. uparrow.gifBack to the top Method 2: Change the memory settings for installation loadTOCNode(2, 'workaround'); To change the memory settings for installation, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the BOOT.INI tab, click Advanced Options.
  4. In the BOOT.INI Advanced Options dialog box, select the /MAXMEM= check box, and then change the setting to 256 (or lower if your computer has less RAM).
  5. Click OK to close the BOOT.INI Advanced Options dialog box.
  6. In the System Configuration Utility dialog box, click Apply.
  7. Click OK to close the System Configuration Utility dialog box.
  8. Click Restart to the following message: You must restart your computer for some of the changes made by System Configuration to take effect.
  9. After you restart your computer, install Office as a Complete Install.
  10. After you install Microsoft Office, follow steps 1 through 8 to clear the /MAXMEM= check box.
uparrow.gifBack to the top Method 3: Install Office by using a flat folder loadTOCNode(2, 'workaround'); To install Office by using a flat folder, follow these steps:
  1. Clean boot your computer. For additional information about how to clean boot Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 310353 (http://support.microsoft.com/kb/310353/ ) How to perform a clean boot in Windows XP
  2. Save a copy of the Microsoft Office CD-ROM to your computer's hard disk. To do this, follow these steps:
    1. Start Microsoft Windows Explorer. To do this, right-click Start, and then click Explore.
    2. Create a new folder at the root of a hard disk volume, and then name it "Flatfile" (for example, C:\Flatfile).
    3. Locate the drive that contains the Microsoft Office CD-ROM, and then copy all the contents of the Microsoft Office CD-ROM into the C:\Flatfile folder. To do this, follow these steps:
      1. In Windows Explorer, click the CD-ROM icon (or DVD-ROM icon) that contains the Microsoft Office CD-ROM.
      2. On the Edit menu, click Select All.
      3. Paste all the files into the new folder. To do this, drag the selected items on the right side of the Explorer window into the C:\Flatfile folder on the left.
        Note If you receive the "This Folder contains "X" hidden files" error message, follow these steps:
        1. On the Tools menu, click Folder Options.
        2. Click the View tab.
        3. Turn on Show Hidden Files and Folders.
        4. Turn off Hide Protected Operating System Files.
        5. Click Apply, and then click Ok.
        Note If there are errors during the copy process, this can indicate problems with the CD-ROM (media), a dirty CD-ROM drive, or a problem with your hard disk.
  3. Restart your computer the way that you typically do, and then install Microsoft Office from the C:\Flatfile folder onto your hard disk.
uparrow.gifBack to the top Method 4: Install only one Office program loadTOCNode(2, 'workaround'); Install only one Office program, such as Microsoft Access. To do this, select a Custom install, and then cancel the selection for all but one of the Office programs. If the Setup program is completed successfully, restart the Setup program. Restarting the Setup program will take you into Maintenance mode. Click Add/Remove Programs, and then click the programs that you did not install in the first installation of Office. uparrow.gifBack to the top Method 5: Contact Microsoft loadTOCNode(2, 'workaround'); If the previous methods do not resolve the problem, contact Microsoft. For information about how to contact Microsoft, visit the following Microsoft Web site: http://support.microsoft.com (http://support.microsoft.com/) uparrow.gifBack to the top APPLIES TO
  • Microsoft Office XP (Setup), when used with:
    • Microsoft Windows XP Home Edition
  • Microsoft Office 2000 Premium Edition
  • Microsoft Office 2000 Professional Edition
  • Microsoft Office 2000 Standard Edition
  • Microsoft Office 2000 Small Business Edition
  • Microsoft Office 2000 Developer Edition
  • Microsoft Access 2002 Standard Edition
  • Microsoft Excel 2000 Standard Edition
  • Microsoft FrontPage 2000 Standard Edition
  • Microsoft Outlook 2000 Standard Edition
  • Microsoft PowerPoint 2000 Standard Edition
  • Microsoft Word 2000 Standard Edition
Sep 15, 2009 | Computers & Internet
How do I reconfigure microsoft office standard edition 2003?
Try repairing your office installation. To do that you will go to your control panel and select Add Remove Programs. Find your Microsoft Office 2003 and click on it like you would remove it. There you should be able to select repair instead of remove. This will repair the installation and should fix your problem.
Nov 17, 2008 | Microsoft Office 2003 Pro (269-07387) for...
Computers & Internet Logo
130 people viewed this question
Top Data Dynamics Computers & Internet Experts
David Payne
David Payne
Are you a Data Dynamics Computer and Internet Expert? Answer questions, earn points and help others
