Question about whipper snipper stihl fs 38
Removing the head off an " outdoor " whipper snipper
No nut/ bolt in head, but the head still will not come off
2 Suggested Answers
anaheimflash
  • 8 Answers
SOURCE: sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
Also check to make sure the dogs are engaging when the cord is pulled. If not manually move the dogs in and out they might be stuck.
If not look at the pulley surface to see if the teeth are still pronounced
and able to engage if they are rounded off you will need to replace
the gear.
Posted on Nov 21, 2013
How to remove Rockwell whipper snipper cutting hub
cutting hubs on trimmers are held on by a left hand thread nut
turn the hub center / nut in the right direction ( as if doing it up)and it will come undone
Jan 09, 2016 | whipper snipper Garden
Where can I buy replacement line spools for this whipper snipper??
I think that might be a K-Mart line of products
Mar 31, 2015 | Garden
Restringing a talon hawk whipper snipper
There may be a latch that has to be released in order to rotate it.
Jul 19, 2014 | whipper snipper Garden
Whipper snipper revs but head doesn't turn
Englebert the most common thing would be that the inner shaft has sheared off. Remove the head and see if it spins then.
Dec 29, 2013 | Garden
Whipper Snipper
check to see that you have a left hand nut on the head as it requires it to tighten up as the shaft spins. Check to see if the shaft spindle turns the right way for your new head
Jul 04, 2013 | Cars & Trucks
I have just got sa new head for my whipper snipper and i would like yto know how to change it
take the spool off and then you will see a nut, it is left handed threaded, on the top side of the head unit there is a plug/bolt/screw remove that and wedge a flat tip screwdriver into the gears and remove the nut, replace with new unit tighten replace plug and it is a done deal. Good Luck Tim
Mar 22, 2011 | Garden
My whipper snipper starts well but has no power to
Battery is NO GOOD.... need new ones, these quickly go bad, if not religiously charged and discharged. You must charge a long time when first get them, and then as soon as flat must go back on charger, for at least 4hours... regardless what is said. If ever removed before properly charged, then it will "remain" at that level, next charge and so on... All batteries MUST be flat before recharge, and full before used again, no exceptions.
Mar 01, 2010 | Garden
Unable to get head of whipper snipper
After much mucking around I noticed a hole in the top shroud of the shaft. I placed a narrow screw driver through the hole until it made contact with the rotating part of the head and pushed until the head would not turn. I thern applied pressure clockwise until the head became loose. I did the reverse to tighten. The head of the unit will rotate anti clockwise to tighten as the shaft rotates clockwise during operation. I hope this explains the method.
Thank you any way for your interest.
Greg
Dec 21, 2008 | Echo Garden
Garden Logo
24 people viewed this question
Top whipper snipper Garden Experts
John Mayer
John Mayer
Level 1 Expert
richie46
ray gallant
Are you a whipper snipper Garden Expert? Answer questions, earn points and help others
