Question about Siemens WK61420GB Front Load Washer / Dryer
Where does the fluff go ?
Where does the fluff go on the drying cycle?
How does the air dry cycle work?
Are you asking about the fluff or no heat cycle?? It just blows room temp air through your clothes. It would be similar to hanging them outside but with the drum tumbling them. This will of course take much longer to dry than with heat.
May 10, 2015 | Dryers
The dial on the cycles never advances to the "off" position
The timer is shot. Replace it. Check around there are places that rebuild them, sometimes at half the cost.
Aug 10, 2014 | GE GTDL200EMWW 27" Front-Load Electric...
Dryer won't start
First, with the door opened, push and release the door switch. Does the light go on and off?
Dec 07, 2012 | GE GTDL200EMWW 27" Front-Load Electric...
How do you remove the water pump on an indesit idc75 condenser drier?
This easy to use white Indemnity condenser dryer will make a welcome addition to any kitchen. The 10 minute cool tumble and reverse tumble option will help keep creases in your fabric to a minimum. Energy efficiency ratings & performance: Energy efficiency rating: C. Maximum drying capacity 7kg. Condenser dryer features: 160 minute timer. Including 10 minute cool tumble. 2 dryness levels. Manual control. Reverse tumble option. Reservoir full indicator. Fluff filter. Size H85, W59.5, D58.5cm. Drying programmes Freshen up cycle. Manufacturer's 5 year parts and 1 year labour guarantee. Technical specifications: Energy consumption: 4.48kWh per cycle based on dry cotton cycle. Energy consumption: 336kWh per year based on dry cotton cycle.
please comment on my post or vote for the solution.
Dec 21, 2010 | Indesit Dryers
MDG4000BWW gas neptune dryer The timed dry/air fluff doesn't work until it gets to damp dry or wrinkle release. Works on the other cycles. Have removed lint screen & 4" hose cleaned and vacuumed.
on a timed dry cycle u are selecting the time it will dry
only after the time has run out will it tumble with no heat
on other setting the machine is stopping the heat and putting the machine into a cool down or air fluff mode
sounds like it isworking normally
(solv ya prob)
Oct 17, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Siemens WK61420GB Front Load Washer / Dryer Logo
80 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
