Question about Wolfgang Puck Food Processors
Can't remove lid
Lid will not come off
Lid stuck on work bowl of kitchen aid processor
This tip is used to remove a stuck bowl from the base of a Kitchen Aid tilt-head mixer. It might work for your situation. Fill the bowl with very hot water (use the food shoot as a pour spout). Now use either frozen gel packs, or a bag of ice cubes, and lay the ice on top of the lid. Wait for a few minutes. The hot water with make bowl expand, ice will make lid shrink, thus loosening the tight lid. I'm assuming that the lid edge fits inside of the bowl, like most food processors do. Try to gently move the lid, and see if it'll give.
Mar 20, 2017 | Food Processors
How do you unlock the lid on the food processor?
The locking happens at the handle. You need to turn the lid counter clockwise to take it off and clockwise to lock it into position.
Jun 01, 2014 | Krups XL6 Power Combi Food Processor
I can't figure out how to use it.. I just want to make a smoothie!
You can get a manual at WWW. euro-pro.com.
In order to use the blender the food processor bowl and lid must be LOCKED in place. Turn the lid on processor until it's locked. Then you are ready to use the blender. Select desired speed or pulse.
In order to use the processor, remove the blender and place the gray lid in its place. It should be locked. The lid keeps the blender shaft from spinning and allows the shaft on the processor to turn.
To remove the processor bowl, gently lift up on the lid to unlock it and then turn it away from processor. Bowl lifts off. That's it! Enjoy!
Hope I have been of some help to you.
Feb 10, 2011 | Bravetti Platinum Pro Quad-Blade Food...
I Cuisanart mini prep and removed the bowl, lid,
Make sure the tab on the lid is making contact with the "tower" in the back and that the work bowl is locked properly into place so that the plastic tabs show on each side toward the bottom of the work bowl.
Aug 12, 2009 | Cuisinart DLC-2 Mini Prep Plus Food...
Food processor not working
Latching seems to be a sometimes thing.
I have this problem and found that I could make it latch by holding the body of the machine firmly and turning the lid while forcing the machine and processor lid toward each other ( This worked 7 out of 9 times).
You can also manually trip the little lever (to the left) inside the slot the lid rotates into.
This will leave the machine's interlock switch always on ......... but this can change with removal and replacement of the processor lid.
May 06, 2009 | Bravetti Platinum Pro Quad-Blade Food...
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
I put all parts on just do a simple and it won't turn on.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Mar 21, 2009 | Cuisinart DLC-10S Pro Classic Food...
Often it is difficult to unlock the bowl on the cuisinart food processor
Have you tried removing the lid first? Mine has an interlock where I have to remote the lid before I can unlock the bowl from the machine. Good luck!
Sep 20, 2008 | Cuisinart DLC-5 Food Processor
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
Euro-Pro EP91 Quad-Blade 6 Won't Start
My wife was given this unit from an elderly gentleman that was done trying to make it work.
I just fixed the same problem as above. Note - I do not have a manual for this unit.
True above about the bowl cover being locked in position but found the key to make it work is also the white lid to the left of the bowl cover. I was locking and unlocking this white lid with no results. Then I removed the bowl cover and found the white lid cover was loose and easily removed this white lid to inspect inside ( why this cover removes I have no clue).
Anyway I was able to snap the white cover firmly on and turn counter clockwise to lock in place ( six o’clock position), then after putting the bowl cover back on and snapping in place it works.
Note - I do not need to turn the white lid cover to install or remove the clear bowl cover, this could be because it looks like one of the clear tabs might be broken on the locking area of the clear bowl cover. If you have two tabs the same shape on the bowl cover you may need twist the white lid clockwise to install and remove the bowl cover and counter clockwise to lock in place so the unit works, but now that my white lid is snapped firmly in place it hardly moves with the force of both hands trying to turn it.
Hope this helps someone.
Good Luck !
Dan L. P.
Jan 05, 2008 | Euro-Pro EP91 Quad-Blade Food Processor
Food Processors Logo
24 people viewed this question
Top Wolfgang Puck Food Processors Experts
richie46
Are you a Wolfgang Puck Food Processor Expert? Answer questions, earn points and help others
