Question about Traulsen G20010 Commercial Refrigerator
My Traulsen G-series is leaking water from the duct inside the refrigerator. How can I fix this?
There is a leak inside the refrigerator. It seems to be coming from the duct inside the refrigerator. Could there be a drain that is plugged?
3 Suggested Answers
  • 93 Answers
SOURCE: Leak to under ice cube tray causing drawer to freeze shut.
May be your freezer evaporator drain hole is frozen. If this is the case, you can try to install a low heat drain hole heater into the drain hole and connect the wires with the defrost heater.
Posted on Mar 03, 2010
  • 1151 Answers
SOURCE: the refrigerator is working but the freezer don't.
check for either a bad evap fan motor or a bad fan delay. It could be an under charged freon level too, but I would check the other items first as they usually go bad more frequently.
Posted on Jun 26, 2010
Why do I get blobs of water on the inside of my salad drawer in my Fridgemaster. Fridge/Freezer
Leaking Refrigerators
I hear a lot of complaints from people that see water leaking into their refrigerator from seemingly nowhere. Water appears in different places and even inside or under a refrigerators that does not have a water or a ice dispenser! Frost free refrigerators defrost the ice that collects on the evaporator coil on the average of about every 8 hours so the water that accumulates during defrost has to go somewhere right?
APPLIANCE 911
Dec 15, 2015 | Refrigerators
My traulsen refrigerator is warm not cold
the pump unit is burn
or you have a leakage on the cooling fluid !!
all your dealer and ask the sometime the answer those question with no charge $$ !
Apr 05, 2015 | Traulsen RDT332NUT-FHS Reach In...
Fix leak inside Samsung refrigerator
water may not be leaking inside? What u may have is water condensation? this happens when u have a clogged or plugged evaporator drain plug line or bad seals on the door which allow air and moister to come in and CONDENSATE, THEREFORE WATER IN THE FRIDGE. U NEED TO CLEAN THE DRAIN LINE USE HOT WATER, AND A SOFT FLEX TUBING OF SOME TYPE
Feb 15, 2015 | Samsung Refrigerators
Water leaking inside the vegetable drawer
What is your model number? Also what year, series etc.
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Leaking water in back refrigerator wall
You have to pull the refrigerator out and track down the leak. Leaks are usually really obvious. Usually it will be leaking from a tubing connector, or possibly a crack in the tubing itself.
Disconnect them by pressing the plastic ring (like a collar around the tube) into the connector, then simultaneously pull the tube out. (be sure to turn off the water supply first!)
Sometimes you may be able to fix a connector issue by cleaning it out and putting it back together, but you may need to replace it.
If you have a burst tube just replace the whole piece. No amount of duct tape will fix it.
Mar 09, 2014 | Refrigerators
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Lg refrigerator leaks water inside
Probably water reservoir is leaking. It or tubing going to it probably is cracked.
Sep 28, 2017 | LG LSC26905TT Side by Side Refrigerator
There's water spewing out of the top of my Kenmore
yes you do have a blocked drain,you need to remove the inside back wall and melt out the ice with a hair dryer,shut the control off so the fan isn't running and don't forget to turn it back on when you're done,now you have to clean out the drain,i use a steamer,they cost around 50 bucks,blow out the drain line with the steamer and if the air ducts are iced up below the fan melt that out also,try not to keep the heat in one spot for a long time,you can damage the styrofoamwith overheating,you might have to heat up underneath the air ducts from inside the refrigerator,when you think the drain is clear pour hot water down the drain if it goes down you know it's clear,there's a heater kit you can buy to put into the drain,it's called a heater probe,you rap one end onto the heater and the other end goes down the drain hole,when the heater comes on the metal heats up stoping the ice from forming at the mouth of the drain,if you have a piece of electrical house wire you can use a piece of the ground wire around 5 inches long,stick it in the drain till it stops,leave enough to bend around the heater and cut off the rest and you should be good to go
Feb 11, 2010 | Kenmore Refrigerators
Intermittant water leak front left hand side and ice build up on inside base of freezer compartment, but no evidence of water leaking out from door it seems to come from underneath the appliance.
Sounds like the drain hose from fridge unit to evaporator pan built on top of compressor is plugged. The drain holes are small and clog easily. I like to make the holes bigger. A pipe cleaner helps to clean the inside of the drain hose.
Make sure water is dripping onto evap tray.
Nov 25, 2009 | Refrigerators
Water seems to leak from right side of refrigerator on an intermittent basis.
Water leaking from inside the refrigerator or freezer is most likely due to a blocked or frozen over defrost condensate drain. I have put together a long page full of information on why and how to resolve the problem. My thanks to fixitnow.com and appliancejunk.com for all their great work and professional approach to solving the problem. Please click on the link below and choose the part that applies to your situation and let me know how I may help you resolve the problem, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Refrigerators
Traulsen G20010 Commercial Refrigerator Logo
99 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
