Question about Craftsman Garden
Craftsman rear tine tiller
I have front tine 5.0 craftsman tiller.Model # is 917 291480.I was tilling under some small brush area with roots.suddenly the tine stopped rotating.There was some squeaky kind of noise .I stopped the gear throttle whch engages the tine to move. I stopped tge engine.I tried to to manually rotate the tines in forward direction.It won't move .I tried the other way .IT moves with difficulty.But it does the same with forward movement. I do fix the problem. I really need to to prepare my gardens.I just moves in this area last month.
    New Friend:
If you cant move the tines by hand then I wouldn't think you sheared the pins, more like a gear box problem.
Posted on Mar 21, 2014
3 Suggested Answers
harlan301
  • 205 Answers
SOURCE: Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Posted on Oct 13, 2009
heatman101
  • 43501 Answers
SOURCE: Own a "Craftsman Rear Tine
Can you move the tines by hand???
They should turn by hand if you try to move them...if not then they are bound up by something...
either a bearing has gone bad, something has wrapped around them, or there is something stuck in there that will not let them turn...check for a rock stuck between one of the tines and the housing around them...
Get the tines moving freely and you will be okay again...
heatman101
Posted on Mar 31, 2011
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
I purchased a Craftsman 205cc dual rear tine tiller (17" width) in 2009. I used it very little to break ground for a small garden (32'x12') after purchase then to till it a couple of times a...
It appears that the gear case on your model is not capable of being serviced. The cost is over 300 dollars. There is a shear pin or similar connection in the case where the shaft connects to the pulleys. It has broken off and the shaft has no torque now.
Mar 05, 2017 | Craftsman 205 cc 13" Dual Rotating Rear...
Tines stop under load
you have to get someone with a big tractor to "break" the ground up first. A tiller is just that...Not a plow
Jul 26, 2009 | Ryobi ZRRY46501 Factory-Reconditioned 12...
Help, new craftsman rear tine tiller stopped tilling.
It sounds like the belt just stretched. Now you need to move the belt tensioner over to put more pressure on it.
Apr 25, 2009 | Craftsman 8.50 Torque Rating Rear Tine...
Craftsman 6.5 tiller model 486.252444
Not sure about this tiller but some others just need oil in the crankcase - tillers tend to lose oil because of the harsh conditions they work under. If you hear squeaking down their it might be a good idea to check it out.
Apr 19, 2009 | Craftsman Cultivating Shield
I need a mannual for a craftsman 5 h rear tine tiller
Try this website.  http://c.managemyhome.com/mmh/ You will need to register.... and go to home page... manuals.... put in Craftsman and serial number. Pdf should come up, you can download or print.
I worked for me on a mower manual that no one could track down
Hope it works for you
John Elsegood
Apr 06, 2009 | Craftsman Cultivating Shield
Craftsman rototiller 3 5 model 917 299130 leaks
Sounds like you are speaking of the float bowl.
It should not have a hole in it.
You could purchase the part from Sears or a small engine shop.
If it were mine, I'd remove the bowl, clean it, and patch with a gasoline impervious material such as JB weld.
Apr 05, 2009 | Craftsman Garden
I bought my troybilt rear tine used. When I use it to till new ground (sod) it cuts fine for a few feet, then without warning, it gets on top of the ground, and I can't do anything to make it cut. The...
Hello, I think if you look at the depth setting bar you will find it clogged up with grass and roots. Once it clumps up you can't get it to drop to depth to make the cut. There are two speeds for the rear times for the toller which will make it go forward more slowly and allow the dirt clods to break up better. Also cut the grass as short as you can, make a shallow pass with the tiller 1" to 2 " to cut the heads off the roots and then go to depth with your next cut. This should pretty much break up the cloding when doing the tilling. Also watch it because it is hits a rock it will jump up and drag you away at the speed of the tines, because it lifts the drive wheels off the ground and the times drive the tiller instead. Other than that mine used to chew up everything including wet DG. Good Luck, RAC
Mar 31, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
307 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
