Question about Swatch Touch Purple - Jewelry
Blinking I cant stop my swatch touch from blinking
I have a swatch irony chrono, but when I stop the stop-watch and push the bottom button, the sweep hand ends up at the 11 o'clock and not the 12 position. My quartz Parnis does this, and its driving me...
Assuming the mechanics work ok (thay all do 360 degree turns) it's just a calibration issue: download from SWATCH support a PDf which describes how to zero the watch hands, it's simple as taking the crown out to 3rd step, the pushing the buttons repectively till they point 12 direction. Exact details in the PDF.
Dec 11, 2010 | Swatch Irony Chrono #YOS414G Watch for Men
Tip
SWATCH - TOUCH watch settings
Follow this link and see how to set your TOUCH watch:
http://www.swatch.com/templates/zz_en/pdf/manuals/originals_touch.pdf
on Aug 04, 2010 | Watches
Suddenly its stops so i bought a new battery but still it wouldn't work even with a new battery
You are not in luck - Irony watches are not made to be serviceable and therefor you will have to send it back to Swatch or one of their dealers - hopefully it is under warranty.
Sep 20, 2010 | Swatch Irony watch
My swatch model is swatch irony YSS112G. It stops working and when i took it to swatch shop the assistant told me its due to the mechanical problem since a new battery was restored. i was told that it was...
mcdevito75 here, Once any Quatrz mechanism goes, it"s ususlly gone. New replacement Quartz mechanisms are sold but just the mechanism itself could cost $30.00---$70.00 then the labor to have it installed, A Swatch watch is a COLLECTABLE item, it may be worth the expense of a new Quartz Mechanism, spaek with the watch shop about details.
Jun 27, 2010 | Watches
How to set time for aquastar N0 4095
When looking at the face, you have 4 pushers. Top left is for regatta function countdown. Top right is regatta function start-stop-reset. Bottom left is Hours-Minutes and Nite Lite. Bottom right is regatta function "catch up". Assuming that you want to set Hours and Minutes, press and hold the bottom left for 3 seconds...Hours will start blinking, press the pusher successively until the desired hour is reached. Then wait until it stops blinking. To set minutes, press and hold for 3 seconds, the hours will again begin to blink, then release and re-press for an additional 3 seconds and the minutes will blink, Then press successively until desired minutes have been reached. Stop pressing and wait until the blinking has stopped. Once it has stopped blinking your time has been successfully registered. Good Luck. Hope this helps!
Nov 02, 2009 | Watches
Put in new battery and it does not run.
It is because some 317 batteries have their negative terminal plate flashed a little bit into the positive side plate and some are a bit thicker thus the negative plate of the skin swatch touches the side of the battery. sometimes battery cove/lid cannot be closet when the battery is a minute thick. renata battery is just right for the skin swatch.
Oct 20, 2009 | Swatch Skin SFK254 Watch
Hye...my watch swatch stop functioning even i already changed the battery.
Could be Following Reason
1, Watch movement required overhaul
2, Circuit or coil warn out
3, Battery connection are not on right place
4, Test new battery to check its strength
If watch has only battery cover on the back and does not has backcase
like most of swatch watches are then watch can not be overhaul.
hope this information is helpful
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 25, 2009 | Swatch Irony Chrono Unisex Watch #YMS400G
Hi I have a swatch with coil type bracelet that I cant get the sp
well you can buy it from any jewllery stores and you also can get it repair it from any watch makers.
Jul 22, 2009 | Watches
Tissot T33.1.588.51 T-Touch Black Dial?
If the functions dont work from moisture I can repair it.
if the sensor damaged the watch is unrepairable and only the swatch group service center can repair this watch.please check my Blog i have many posts about these problems for all Tissot T Touch Series
Watchmaker Video Review For Watchmakers and Watch Fans
Sep 08, 2008 | Tissot T33.1.588.51 T-Touch Dial
Cant set time
Press and hold the top left button (mode) until the numbers start blinking. On mine this is the alarm time set. Press the mode button one more time to get to time set. The hour will be blinking. Press top right button (start/stop) to cycle through hour, minute, date, etc. and press bottom right button (adjust) to change the number which is flashing. Press mode to finish
Apr 01, 2008 | Timex 1440 Nylon watch
Swatch Touch Purple - Jewelry Logo
238 people viewed this question
Top Swatch Watches Experts
ray gallant
Jerry Kramer
Jerry Kramer
Are you a Swatch Watch Expert? Answer questions, earn points and help others
