Question about Cuisinart Coffee Bar DCC-200
Auto off problem
Coffee bar stays on all the time doesn't auto off
Can not get the auto on/off to stay on
hold the auto button down for 6 to 8 seconds.
Jan 10, 2013 | Keurig Platinum B70 Coffee Maker
It doesn't work. Got it for Christmas and love this coffee maker but it doesn't work half time. No. Most of the time
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 14, 2011 | Keurig Platinum B70 Coffee Maker
How do I program the stay or go coffee maker to turn on at a certain time, I worked the past few evenings, but the green light will not come on, I did have trouble the other times also
To Program Automatic Brew
1. Make sure clock is set for correct
time of day.
2. Press PROG button and digits will
flash.
3. Press H and M buttons until desired
brewing time is reached.
4. Press PROG button to confirm setting.
Digits will stop flashing and
return to set time of day.
5. Once brewing time has been set,
follow this procedure:
• Follow steps in "How to Make
Coffee."
• Push AUTO-ON-OFF button once
and "Auto" will be shown in display
indicating the brew cycle will begin
at the set time.
NOTE: If AUTO-ON-OFF is pushed
twice, the light will glow and brewing
will begin immediately. Press AUTOON-
OFF once to turn off and once
more to set programming mode.
Jan 13, 2011 | Hamilton Beach Stay or Go 45234 Coffee...
Coffee maker DCC-2000 will not keep coffee hot,have change the auto off time no effect.
Well the procedure to set the auto button off would be as follows. First set to 0 so it shut off as soon as it started brewing. Once the switch is turned to auto off, then when the numbers are blinking hit the hour button until you get the desired hours you want the heating element to stay on. If this does not keep the coffee warm then most likely you have a heating element down and will need to replace it. Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
Mar 03, 2010 | Cuisinart Microwave Ovens
After brewing coffee does not stay hot.
Unplug the coffeemaker for one full hour.
When you replug it, go to Auto-Off - change the time from "2:00" to "4:00", and then brew another pot. Immediately after the brewing is done, set the coffeemaker back to Auto-Off and see if your problem is resolved.
If not, it may have deeper problems. These coffeemakers have a 3-year warranty - call Cuisinart to see if you are still in-warranty.
-Tha Mp3 Doctor
Jan 31, 2009 | Cuisinart DCC-1200 Coffee Maker
Francia
Make sure the clock is se tfirst. Then press the Program button - change the hours button - make sure it doesn;'t say 6PM - then press the program button one more time - then press the Auto-On button. Voila!
-Tha Mp3 Doctor
Dec 03, 2008 | Cuisinart DGB-600 Coffee Maker
Coffee maker shuts off too quickly
It seems this coffeemaker insists on shutting itself off after 4 hours,
or whatever "auto-off" time you've programmed in. The only work-around I've found is to switch it to "Brew" and cycle the power switch off and on every time you pour a cup. That will start a new
4-hour timer cycle. Since the pot's still hot, it will go quickly to the
"brewing done" state and render 5 beeps.
Jan 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Coffee pot warmer is not working
I called Cuisinarts repair center and they had me set my auto off button. It had been set to 0 so it shut off as soon as it started brewing. If you turn the switch to auto off, then when the numbers are blinking hit the hour button until you get the desired hours you want the heating element to stay on. Then when you stop hitting it it will remain at that time after you brew your coffee. If that doesn't work you can call the help line at 800-726-0190, just give them your model number and serial number, the device carries a 3 year warentee
Nov 14, 2007 | Cuisinart DCC-1200 Coffee Maker
Coffee brews and then immediately shuts off Cuisinart DCC-1200
To program the Variable Auto Off: 1. Turn the FUNCTION KNOB to the ?Auto Off? position. Press and hold the ?Hour? button for 2 seconds. The clock display will start blinking. 2. Program the coffeemaker to shut off from zero to four hours after brew cycle is finished by using the ?Hour? and ?Minute? push-buttons. (see ?To set the time?)
May 20, 2007 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Coffee Bar DCC-200 Logo
18 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
