Question about Vaultz VZ01002 Locking Cash Box
Cannot open vaultz file box lost combination
Cannot open lock
Combination to the safe it's three numbers and their rotate number brand number is vaultz.
Sorry can't help with this, combinations would never bee online.
Nov 08, 2016 | Home Security
I lost the combination and I need to know how to open it without the combination. Help!!!
man I hate this when it happens . to destroy a perfectly good case . saw or grind the lock off .
Dec 09, 2015 | Vaultz Locking VZ01353 SLR Camera Case
How do i fix lost combination?
sorry but you need to contact the mfg of it to get combination . we do not have them here
Jun 23, 2015 | Home Security
How do i open my vaultz storage chest with it locked, since i forgot my combonation
Try all the combinations. To save wear on your fingers, use a small screwdriver to dial the numbers. Try to move the little slide after changing each digit. You can try all 1000 combinations in about twice the time it takes you to count to 1000 out loud, but unless you chose a combinations like 998, you will probably open it long before that time.
Dec 13, 2014 | Locks & Locksmithing
Vaultz cash box combination
If it's open you move the handler to the left and move the numbers to whatever combination you decide, as you finish just release the handler! Try it fist before you lock it! Good luck!
Jul 10, 2013 | Office Equipment & Supplies
Vaultz VZ01002 locking cash box, lost combination
I Lost the combination to the vaultz lock box (vz01002). I followed the instructions on how to open it using a flashlight and small screw driver. it worked like a charm. only difference was i had to push each dial to the right instead of the left. and the grove to look for is a little tricky. inside you can see a white piece of plastic which turns with the dial. and you need to look close because the groove is on that white plastic and is kind of hard to see as the groove is white as well. so its very easy to miss it. once you find one you know exactly what to look for. good luck. this site is great for tips, tricks, and solutions to just about anything.
Jan 10, 2012 | Vaultz VZ01002 Locking Cash Box
Misplaced instructions on how to reset combo on Vaultz cash box with 3 digit combo & latch
Directions for setting combination locks
1. With the lock open, push button (to the left, yes opposite of the arrow) and hold until the second operation has been performed.
2. Set number wheels to the desired combination (numbers roll down)
Do not forget the combination you have set!
3. Now release button. Press the button again as a check.
Apr 15, 2011 | Office Equipment & Supplies
Lost combination to nu set lock box . I would like to open the box and be able to reuse it.
You can dial all the combinations (1000) in a couple of hours while you watch TV. I just did one (2012 version with letters) and hit about half way through. The problem is going to be a lack of a key. You won't be able to open the shackle on some versions and won't be able to reset the combination (same key for both functions).
Nov 20, 2009 | Locks & Locksmithing
Vaultz VZ01002 Locking Cash Box Logo
113 people viewed this question
Top Vaultz Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Vaultz Office Equipment and Supply Expert? Answer questions, earn points and help others
