Question about LG enV VX9900 Cellular Phone
Want to clear contatcts but it wants a code is there a preset code?
  • 3 Answers
Its usually the last 4 digits of your phone number.
Posted on Jun 15, 2009
I bought sherlock holmes collection pc games but cannot play them as the serial number is not recognised help
Contatct the publiser for new code and also make sure you have enter the code in properly.
Jan 21, 2017 | The Video Game Consoles & Games
I have lost code for Becker Indianapolis be 7922 SN75015043
code :::::::becker 4 presets ::::::::::::: 24131 ::::::::::::::::::: smile.gif
code :::::::becker 5 presets ::::::::::::: 53434 ::::::::::::::::::: smile.gif
code :::::::becker 6 presets ::::::::::::: 42333 ::::::::::::::::::: smile.gif
code :::::::becker 7 presets ::::::::::::: 31232 ::::::::::::::::::: smile.gif
code :::::::becker 8 presets ::::::::::::: 28131 ::::::::::::::::::: smile.gif
code :::::::becker 9 presets ::::::::::::: 18939 ::::::::::::::::::: wink.gif
Feb 26, 2014 | Car Audio & Video
What proceedure to apply radio code
  • When the radio displays CODE, you may enter the code using the preset radio station buttons
  • For instance, my number is 1615, so when I get the CODE on the radio's display, I press the radio preset button 1, then the radio preset button 6, then the radio preset button 1, then the radio preset button 5.
  • If your radio says OFF, leave the ignition on in the first position for 2 1/2 to 3 hours in order for it to display CODE. In certain models you can clear the OFF state by pulling the fuse for the radio (#7 in my car). That's a bit simpler than leaving the ignition in the first position for a couple of hours - particularly if you don't have a garage.
Jan 04, 2011 | 1998 Volvo S70
Custom programing the radio
To set Radio options, press submenu in Radio
mode.
?? Select Add Preset to save current frequency
into presets.
?? Select Delete Preset to remove current
frequency from presets.
?? Select Delete All Preset to clear all presets, and
next time when you enter Radio Mode, Sansa
e200 will search automatically.
?? Select View All Presets to view all preset
frequencies. The autoscan option will replace
existing presets.
Jun 28, 2010 | SanDisk Sansa e250 MP3 Player
Need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
How do you enter simulation mode and the code when you replace developer on lanier 7313.
Press C00C or C interupt key 0 interupt key and 41 for developer counter display 42 for developer counter clear 46 for exposure level adjustment 72 for maintenance preset counter setting 25 for automatic developer adjustment. 40 for developer preset counter display.
Nov 10, 2009 | Lanier Office Equipment & Supplies
1991 plymoth voyage comes uyp with code 12 and 21
If the engine is running fine and you disconnected the battery recently then don't worry about it. To clear the check engine light and the code�s you can do one of two thing�s. One pull the negative battery post off the battery for 30 second�s. This clears the computer codes and the light. However it also clears your radio presets and clock. Another way is to pull the fuse labeled �Fuel Pump�. This fuse is in a box under the hood behind the battery (See photo to the left), Should be the only yellow 20AMP fuse in there. This fuse also disconnects power to the PCM "computer" as well � Kind of a secret to the general public� Just leave this fuse out for 30seconds or so. Then replace. This will keep your clock and radio presets. The engine might be a little hard to start or die the first time since the computer has to relearn everything again
Jul 27, 2009 | 1991 Plymouth Grand Voyager
Stereo not working, and slidind doors either. need fuse diagram
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Digital audio compact disc changer
  • Antenna and two-piece antenna cable or electric antenna
  • Radio speakers mounting/speaker cones
  • Capacitive suppression bond wire and radio receiver hood bonding strap
  • Central junction box (CJB) fuse:
    • 6 (15A)
    • 2 (25A)
  • Ignition switch
  • Circuitry
  • Audio unit
  • Video system
Audio Unit Self-Diagnostic Mode
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, depress the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.
  1. If the concern remains and the fault is not detected, proceed to the Symptom Chart to continue diagnostics.
  1. The audio unit self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. If the system is OK, SELF PASS will be displayed.
    • Preset button 2 = View/clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • NOTE: Always DOCUMENT, CLEAR and CARRY OUT the audio unit on-demand self-test again.
      Preset button 4 = Software configuration level. This test queries each audio unit system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    • Preset button 5 = DISPLAY TEST. This test will light all the audio unit display segments for five seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
May 25, 2009 | 2002 Ford Windstar Cargo
Son cdx m800 code contatcts
pleace send pin code cdxm800 sony
Jan 23, 2009 | Sony CDX-M800 CD Player
2000 Honda Accord EGR Valve Error P0401
Jason,
-after you change the part you have to reset/clear the code
-this can be done by either:
(1) using the OBD2 code reader that Autozone used OR since option 2 (below) is very quick
(2) disconnecting the battery for about 30 seconds (this will delete all codes/radio presets/etc) but it will also clear the 'check engine' code
-this is what I do AFTER i write down my radio station presets :)
-hopefully the new EGR valve resolves your issue after you CLEAR the code
...but that code just means a an insufficient amount of Exhaust Gas recirculation (pressure difference) used to keep the emissions in check
-if it comes back, then there are a few other fixes to try also
-let me know if you need further assistance
-please remember to rate me `fix-ya`if it works
thanks
Nov 03, 2008 | 2000 Honda Accord
LG enV VX9900 Cellular Phone Logo
449 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
