Question about Baby Gear
Lights not working on animals suspended from discover n grow twinkling projection mobile
Light works on projector, but not on individual suspended animals on mobile
SOURCE: projector automatically shuts off immediately after turning it on
If your comfortable w/surface mount troubleshooting and soldering, download the service manual from elsewhere online. Part of the troubleshooting tree for this type of problem is to check the surface mount fuses on the underside on the Main PWB (schematic page 1/8). On mine, the 12V surface mount fuse, F3004 (2.3A) was open (quadrant C1 on the schematic). Replaced it, reassembled the projector (3 interlocks don't 'cha know) and it came up just fine.
Doug
Posted on Dec 10, 2007
  • 3422 Answers
SOURCE: Projection is so dim
Click HERE for the user manual.
I hope this helps.
Goodluck,
Please don't forghet to rate the solution
Posted on Mar 22, 2008
  • 29 Answers
SOURCE: USB Keyboard not working
the lan light will obviously keep blinking bcoz of the data packets keep on transferring.......thats normal.....thats not a problem.
for ur key board switch off the num lock
Posted on Feb 28, 2009
projdoc
  • 2236 Answers
SOURCE: Projecting in green.
lamp may be on it's way out. if the mercury vapor burns at a different temperature than it's designed to, you will get a different color. also check the lamp for bulges, black spots or fogging. if it has any of those, replace it. if the lamp is ok, replace the ballast.
Posted on Dec 16, 2009
SOURCE: I have put together my
likely faulty - refer:
http://www.amazon.com/review/R2608UGVM8FMVE/ref=cm_cr_pr_viewpnt#R2608UGVM8FMVE
many other people report motor burns out and projector stops working. Apparently Fisher Price acknowledge this fault. It has a 1 year guarantee.
Posted on Sep 10, 2011
Where is the remote sensor located on the Toshiba TN55X81 TV? (I need to locate for placement of IR transmitter.) Thanks!
a neeto hack to do this is to use a electronic video camera (your phone works too) , just set camera to no back light or low light , and using your remote pointed at tv , view the tv thru the cameras view finder , ahhh there it is !!! it twinkles at you !!!
how this works is that electronic video cameras for low light can see wider spectrum of light than human eye they then interpret it and send it to the monitor or screen , and hey infrared remotes are "wide spectrum "
Dec 13, 2016 | Toshiba Televison & Video
Little lights like twinkling stars on my projected pictures
it depends on the brand and model number of your set
Mar 17, 2012 | Televison & Video
After a few months use there is a green algae like growing in the bottom of the water container. I am using filtered water. Is this normal and Is there a solution?
Using filter water of course helps keep things clean and so forth. To help solve this algae problem when you descale and clean machine use vinegar and that should help from algae building up. Thanks Mike
Sep 14, 2011 | Keurig Elite B40 Coffee Maker
I hooked up my Think Pad laptop to an Epson EMP-74 and the image projected is upside down. How do I fix?
Do the following for setting the screen.
1. Press the Menu button
2. Select Projection
In the Projection option,
Select Front : When the projector is in front of the
screen.
Select Front/Ceiling : When the projector is in front of the
screen and suspended from the ceiling.
Select Rear : When the projector is behind the
screen.
Select Rear/Ceiling : When the projector is behind the
ok
Apr 06, 2011 | Epson EMP-74L Multimedia Projector
One string of 50 mini led twinkle lights. plugged into a timer and when timer comes on , lights twinkle 30 sec. and fuse blows. what type of light should i get? outdoor use.
What timer do you have.
Problem sounds like bad timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 13, 2011 | Hardware & Accessories
Water pump quit working ???
mind did this i held the light button down for 5 secs til light went off the reselected the seed type and all was well i discovered this when i changed seed selection when light on some seetings pumped worked others not guess its memory gets confused
Apr 22, 2010 | Aerogrow AeroGarden
Our project seems to have lost a color. The
may have fried fly-eye (diffuser) lens and fried light filter on one or more of the lcd panels. both due to excessive dust and heat. unfortunately, you'll have to replace the entire optical engine. toshiba doesn't sell individual parts.
Aug 19, 2009 | Toshiba TLP T70M Multimedia Projector
No picture
send it in for repair. try av solutions in ny. they're pretty good.
Apr 02, 2009 | Office Equipment & Supplies
Feb 28, 2009 | Intel D945GCCR Motherboard
INfocus X1 does nothing after bulb replacement
first off, make sur you have the right lamp (sp-lamp-009, 2 white wires. not the sp-lamp-018, one white, one red. the wires are in different locations in the plug). if you don't hear the colorwheel whirring, that'd be the next step. however, you cannot buy just the colorwheel. infocus does not sell individual parts of the optical engine. but that wouldn't matter, seeing as how they don't sell the engine anymore. also make sure the lamp door is completely closed. there is a peg on it that activates a switch to let the projector know it's closed. if you remove the lamp and use a flat-head screwdriver to activate that switch, turn on the projector. look inside the lamp housing and see if the colorwheel spins. if not, i think you need a new projector. if it does, check the fans. they can be replaced.
Dec 19, 2008 | Apple InFocus X1 Multimedia Projector
Baby Gear Logo
69 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
